  3. Sensor Node V2.0
Sensor Node V2.0
23 Posts 9 Posters 14.8k Views 6 Watching
  • clippermiamiC clippermiami
    @axillent North American standard is common to both US and Canada.
    axillentA
    axillentA
    axillent
    @clippermiami what can be the maximum acceptable form factor?
    sense and drive
    clippermiamiC 1 Reply Last reply
    • axillentA axillent
      clippermiamiC
      clippermiamiC
      clippermiami
      @axillent From my recent experience the Jasco/GE switches are about the biggest thing you can got in a North American wall box and even that can be a challenge. Depending on the number of circuits that come into the box and the number of connections (wire nuts, or whatever you use for the connections) can create quite a bit of congestion in the box. It can sometimes be a challenge to fit even the Jasco switch :-)
        Malx
        Basic sensors that you are using for logging and alarm are ok. However, when starting with power/switch/dimm, then security starting to be a big issue. (Also when using the sensors to control something)
        I hope this boards will be sold with a big warning on that point.
        (I'm not negative to mysensors and using those myself, why would I else be here :). I'm just not a fan of people seeing this as a complete HA solution)
