  3. Sensor Node V2.0
Sensor Node V2.0
23 Posts 9 Posters 15.0k Views 6 Watching
  • D
    Dennis van Velzen
    Nice PCB design...
    Suggested boards:
    • 4 PWM logic FETs (dimming RGB W LED strips, 12V lights) Some FETs are easily capable of doing 8 amps and have almost no excess heat.
    • 230V AC triac dimmer module (200w that fits in a EU wall box) EU net frequency.
    • 0-10V input module (that fits behind a 0-10V dimmer in a wall box. Round max 60mm, thick approx. 15mm) power from 230VAC line.
    • 0-10V output module.
    • 1..4 channel opto input 3-250v module.
    • 1..2 channel solid state relay module.
    Can add nice usable parts, example schema's later... main goal good/better cheap(er) open source products!
    • T
      Tommy Sharp
      Being able to buy something like this that is "all in one" will be great for us newbies! A more accurate temperature sensor would be ideal and worth the extra dollar!
      axillentA 1 Reply Last reply
      • T Tommy Sharp
        axillentA
        axillentA
        axillent
        @Tommy-Sharp "all in one" is one of our goal while working on the project boards
        Thanks all for ideas. We plan to have several project specific boards.
        First one will be the battery operated board designed for wireless sensors.
        Bellow is updated picture, should look better now.
        Sensor will be the digital one with precision 0.5C or better and very low power consumption
        Should we seriously support 5V from battery? For many applications 3.3V are sufficient and it will consume much less power from the battery.
        Relays, dimmers, SSRs will be managed by another board.
        sense and drive
        • axillentA axillent
          We are going to have a set of Mysensors PCB for different purposes. The first one will be powered from a single AAA alkaline battery and will also have MCP9700 on board
          Regardless DevDuino it will have radio on board and will have some more benefits
          It is a good time now before the production to change something. There is no problem to install a precise and low power I2C temperature sensor on board.
          But are you ready to pay $1-1.5 more for the board to get ± 0.5 ° C precision instead of ± 2 ° C?
          clippermiamiC
          clippermiamiC
          clippermiami
          @axillent How is this project coming along? Looking forward to a standardized PCB version.
          • clippermiamiC clippermiami
            axillentA
            axillentA
            axillent
            @clippermiami we are currently in discussion with possible partners, we discussing production of the PCB and assembled PCB
            in parallel I'm doing a prototyping of the battery operated board
            Battery operated board will came first, later we plan to release a set of stackable boards ready be used for switching, dimming and integration behind a wall switch
            sense and drive
            clippermiamiC BulldogLowellB 2 Replies Last reply
              clippermiamiC
              clippermiamiC
              clippermiami
              @axillent LOOKING forward to it, a nice PCB makes a good clean project.
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                North American wall switch?:ballot_box_with_check:
                  axillentA
                  axillentA
                  axillent
                  @BulldogLowell from electrical side it is a clear plan to be universal between 110/220V 60/50Hz etc. to support both US and EU standard
                  from the form factor point of view I have a view to EU standard but not US.. Hopefully we can be universal too but I will need your input on this.
                  Even I'm not sure what is "North American" stands for :) is it common for US only or for Canada too?
                  While for battery board the design is almost 95% clear the wall board is still under discussion.
                  Most likely it will be stackable form factor with universal MCU -board and many different power&switch&dimm sub-boards
                  All feel free to provide your inputs, to share ideas or wishes.
                  sense and drive
                  clippermiamiC 1 Reply Last reply
                    clippermiamiC
                    clippermiamiC
                    clippermiami
                    @axillent North American standard is common to both US and Canada.
                      axillentA
                      axillentA
                      axillent
                      @clippermiami what can be the maximum acceptable form factor?
                      sense and drive
                        clippermiamiC
                        clippermiamiC
                        clippermiami
                        @axillent From my recent experience the Jasco/GE switches are about the biggest thing you can got in a North American wall box and even that can be a challenge. Depending on the number of circuits that come into the box and the number of connections (wire nuts, or whatever you use for the connections) can create quite a bit of congestion in the box. It can sometimes be a challenge to fit even the Jasco switch :-)
                          Malx
                          Basic sensors that you are using for logging and alarm are ok. However, when starting with power/switch/dimm, then security starting to be a big issue. (Also when using the sensors to control something)
                          I hope this boards will be sold with a big warning on that point.
                          (I'm not negative to mysensors and using those myself, why would I else be here :). I'm just not a fan of people seeing this as a complete HA solution)
