  3. Info about String Payload
string payloadpayload
3 Posts 2 Posters 2.6k Views 1 Watching
  • A Offline
    A Offline
    adrianmihai83
    I am intrigued by the following thing, I want to send a string to the controller, tried in many things but I don't seem to get one thing. To be short, I want to send to the controller a string containing 14 bytes, more exactly the ID of the RFID Tag. If I am sending this way:
    gw.send(msgRfTag.set("24848484852515754685348483"));
    everything goes well.
    But if I want to do the following:
    String strTag = "24848484852515754685348483";
    gw.send(msgRfTag.set(strTag));
    it does not compile, error: no matching function for call to 'MyMessage::set(String&)'
    I use Arduino 1.5.8, on Windows enviroment, latest library.
    B 1 Reply Last reply
    • A adrianmihai83
      B Offline
      B Offline
      BulldogLowell
      wrote on last edited by BulldogLowell
      @adrianmihai83
      try using a C string
      char *strTag[] = {"24848484852515754685348483"};
      that will probably work for you...
      • A Offline
        A Offline
        adrianmihai83
        @BulldogLowell
        Spot on, thank you!
        Best regards,
        Adrian
        12.2k
