  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 817.0k Views 27 Watching
  • dbemowskD dbemowsk
    @andrew When it homes itself to the left and stops, it appears to lock itself in position. Do you know of any software that I could use to test the serial connection if it in fact it does speak grbl?
    NeverDieN
    NeverDieN
    @dbemowsk said in CNC PCB milling:
    It looks like older generation equipment. If you can find evidence that it was made before 2009, then there's no chance it speaks grbl.
      andrewA
      andrewA
      andrew
      @dbemowsk the serial console should provide a promt like this
      • andrewA andrew
        @dbemowsk any serial console could do the job. I usually use command line tools on OS X or linux, such as minicom or screen, but you can find graphical tools pretty easy. if you are working on windows then e.g. PuTTY could be a good solution.
        dbemowskD
        dbemowskD
        @andrew I am using linux. There are plenty of serial console softwares out there. I would just need to know some commands to send it. I'll see if I can google a grbl command list.
        andrewA 1 Reply Last reply
          andrewA
          andrewA
          andrew
          @dbemowsk that is not a big deal. for first, if you get a promt like on the pic above, then it is a good indicator. then you can use "$" to get a text help. for the commands you should browse the grbl repo on github, which I already linked, it has a wiki as well.
          dbemowskD 1 Reply Last reply
          • andrewA andrew
            dbemowskD
            dbemowskD
            @andrew Thanks, I'll give that a try later today and report back. IF by chance it is grbl, is there a CNC software that I can use to do a mock run of something to test it further?
              andrewA
              andrewA
              andrew
              @dbemowsk sure, e.g. bCNC on linux could the jon.
              dbemowskD sundberg84S 2 Replies Last reply
              • andrewA andrew
                dbemowskD
                dbemowskD
                @andrew Thanks, I'll check that out.
                • andrewA andrew
                  #68
                  @andrew - what would you say is the limitations of cnc drilling a PCB? I often use quite thin tracks (0,2mm) for everything except GND and VCC.
                    So I picked this thing up at our local university surplus store. It is a Lachat instruments XYZ auto sampler After some research, it appears to be a piece of lab equipment for sample testing. Not exactly sure how it works, but for the $20 US that I paid for it, I though it might be worth trying to build a CNC machine from it. The video clip shows the machine homing the X, Y and Z axis' when powered on.
                    https://www.youtube.com/watch?v=OYuLQs5Cm7E
                    Here is the label from the back panel:
                    The motors for the X, Y and Z axis' do not appear to be stepper motors though:
                    Found this one on ebay that appears to be a match. https://www.ebay.com/itm/Used-Good-MAXON-motor-2028-945-13-131-025-30-1-E-N2-/171548411580
                    It appears to use rotary encoders to deal with position. Here is a pic of the encoders:
                    If you look at the image above you will see that the X axis rails and linear bearings are pretty beefy at 16mm diameter.
                    It would be nice if I could figure out the serial interface to see if I could make it do anything. Just wondering what the thoughts are from the group.
                    NeverDieN
                    NeverDieN
                    @dbemowsk Looks like it may be a liquid handler: http://www.mansci.com/pdfs/pdfid56.pdf
                    • sundberg84S sundberg84
                      andrewA
                      andrewA
                      andrew
                      @sundberg84 I often use 0.4mm drill bits for vias without any issue. 0.3mm should work as well. The drill set I linked before contains the most frequently used drill bits for PCB drilling (0.3 – 1.2mm).
                      regarding to the traces, I have stable and reliable results with 6 mil (0.1524mm) traces / 6 mil clearance, which is also a limitation factor of several PCB manufacturer’s hobby/proto package.
                      • scalzS
                        scalzS
                        wrote on last edited by scalz
                        #71
                        stop teasing me! :grin:
                        I'm kidding I don't think I really need one (I usually have multiple things to do while I wait for my pcb) . I would need a bigger, I'm tempted by a mpcnc someday, not for pcb.
                        just curious, how do you handle small vias?? I imagine it can be some labor to make them connect both side?
                        • scalzS scalz
                          andrewA
                          andrewA
                          andrew
                          @scalz Well, in fact, at home I don’t make real but fake vias only, so basically I just use thin wires through the via’s hole and solder it on both side.
                          • NeverDieN NeverDie
                            dbemowskD
                            dbemowskD
                            @neverdie That looks similar, but my connections on the back are different. Mine has 4 connectors, 2 of them are DB9 9 pin serial connectors. I think that is what this was for though. It is called an XYZ auto sampler. I think it is much like this one:
                            https://www.youtube.com/watch?v=hrmiXsZX2ec
                            I am sure it was used in one of the science labs at the university. When I saw it, they had $30 US marked on it for a price. I told one of the workers that I might be interested but wasn't sure. She said that she could mark the price down to $20 but that she had no idea what it was or what it did. I figured for that price I could at least get some useful parts off of it.
                              @vince I think it's meant for prototyping, not production. At least for that purpose, the reduction in turnaround time should be huge. If, instead, you send everything to the fab at every step, then you need the patience of a saint to iteratively evolve a PCB design.
                              V
                              V
                              Vince
                              @neverdie
                              Yes i know, like i said in the first line for 1 or 2 its nice but when you need more its not a great way to do it.
                              or the pcb's are very small.
                              • NeverDieN
                                NeverDieN
                                #75
                                According to FedEx package tracking, I may be receiving the CNC2418 as early as this Friday. Weighs 5 kilograms. Just posting this because some people here seem concerned about picking a seller who is not based in China. Maybe you don't need to.
                                • scalzS
                                  scalzS
                                  grrr :)
                                  I think people concerns are about import fees (customs+vat) when using fedex, dhl.. if you don't get any fee, you're lucky! in France for example, they wouldn't miss me.
                                  • scalzS scalz
                                    grrr :)
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @scalz Ditto here...
                                    • NeverDieN
                                      NeverDieN
                                      #78
                                      Hmm... Not sure if there are any applicable import fees here in the US. Anyone know the rules? They recently opened one of my PCB packages "as a security check," but there were no fees I had to pay.
                                      EU has the VAT tax, which presumably they force upon you no matter where the seller is.
                                      • dbemowskD
                                        dbemowskD
                                        I am in the US and I myself have never had any fees for things that I buy from china. One big one I got beginning of this year was my Anet A8 3D printer from Gearbest, and there were no customs fees or anything with that.
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @neverdie VAT is applied across the EU by the receiving country, by purchasing from another EU country VAT is already paid therefore no additional tax is due.
