  3. Need help with ESP8266 Node in MQTT Network
6 Posts 3 Posters 2.4k Views 3 Watching
  • siodS
    siodS
    siod
    Hi guys,
    I would like to add an ESP8266 WIFI Node to my existing NRF24 MQTT Network. I´ve set up a Mosquitto broker on my LAN connected Raspberry pi with openhab2 running on it acting as the controller.
    Unfortunately I have no idea where to start to include the new WIFI node to talk to my controller. Does someone know a tutorial could give me some code examples of where to start?
    Thanks in advance!
    still learning...
    K 1 Reply Last reply
    • siodS siod
      Hi guys,
      Thanks in advance!
      K
      K
      kimot
      @siod
      https://www.youtube.com/watch?v=Kp4KJVbOWd0
      https://www.youtube.com/watch?v=xQltSHSVleI
      • siodS
        siodS
        siod
        wrote on last edited by siod
        well, this looks quiet interesting, but I think I´m quicker if I just use my actual Arduino IDE setup and some lines of code to achieve my goal because I feel more comfortable wit this IDE...
        But I will have a look at ESPEasy anyway, thanks for that!!
        edit: Do I have to upload the ESP8266 Gateway Code to every ESP8266 Node?
        What I actually want to achieve is to build a IR Sender which sends IR commands to my TV or other IR devices that where sent by openhab.
        still learning...
        K T 2 Replies Last reply
        • siodS siod
          K
          K
          kimot
          @siod
          Maybe your task is done by somebody:
          IR_MQTT_OPENHAB
          Or with ESPeasy look at this post:
          link text
          And this thread:
          link text
          • siodS siod
            TimO
            @siod
            Yes, you do have to. Just use seperate MQTT topics for every node/gateway.
            I suppose you're looking for the MySensors / MQTT integration in general?
            1. Is the ESP8266 flashed and working? Are you able to see the MQTT messages on the broker?
              (https://www.mysensors.org/build/mqtt_gateway)
            2. You may connect the Mosquitto with OpenHAB via the (generic) MQTT binding (search the forum about how this could be achieved) or via the MySensors binding for OpenHAB2.
            • siodS
              siodS
              siod
              Hi guys,
              thanks to both of you! Thanks @TimO for the general information and thanks to @kimot for finding the exact solution for what I was looking for. Awesome!!
              I will give it a try as soon as possible...
              still learning...
