  3. Temp sensors showing as Celsius, looking for Fahrenheit
4 Posts 3 Posters 3.6k Views 1 Watching
  • C
    C
    cleight
    New to MySensors and finally got my sensor working correctly with my iBoard Ethernet gateway with the exception of my temperatures showing up in Celsius instead of Fahrenheit? I did some research on the issue on the forums and have tried changing my controller (vera) from Imperial to Metric and back again and it didn't fix the issue.
    Controller: Vera Lite
    Gateway: Ethernet - iBoard
    Library Version: 1.4.1
    Plugin Version: 1.4.1
    Sensor Board: Arduino Nano
    Further information to the problem can be found in this thread: Hot Tub Temp Monitor
    • P
      P
      pete1450
      Just starting with the basics: Assuming you used the example temp sketch, did you set the metric boolean to false?
      C 1 Reply Last reply
      • P pete1450
        C
        C
        cleight
        I used a combination of the Humidity sensor sketch and the Temperature Sketch. Metric Boolean was set to true, I just changed it to false but doesn't appear to have made a difference.
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          http://forum.mysensors.org/topic/872/waterproof-temp-sensor-with-dht-humidty-temp-sensor/7
