  2. Bug Reports
  3. Repeater does not accept V_VAR1
3 Posts 2 Posters 1.7k Views 2 Watching
  • Peter F. von FehmarnP Offline
    I have an power meter node (like the example script).
    It works fine with FEHM :-)
    But i need an repeater.
    So i used the repeater example an changed the power meter "parent ID" to 10
    define the Repeater as node id 10
    Now it works but only 2 of 3 values are transmitted:
    The relay does not accept the V_VAR1 message from the power meter node :(
    Serial Log
    powermeter:
    72954 TSF:MSG:SEND,13-13-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:2546
    73091 !TSF:MSG:SEND,13-13-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=NACK:9
    73105 TSF:MSG:SEND,13-13-10-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=1,st=OK:0.1200
    repeater:
    679303 TSF:MSG:READ,13-13-0,s=1,c=1,t=17,pt=5,l=4,sg=0:75
    679309 TSF:MSG:REL MSG
    679407 TSF:MSG:SEND,13-10-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:75
    679452 TSF:MSG:READ,13-13-0,s=1,c=1,t=18,pt=7,l=5,sg=0:0.1200
    679458 TSF:MSG:REL MSG
    679471 TSF:MSG:SEND,13-10-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:0.1200
    • H Offline
      H Offline
      This is a classic powering problem in the repeater node. Add a capacitor on it or introduce a small delay between the messages you send out from the powermeter node (so the radio have some time to recover between transmissions).
        Thank you very much :-)
        I'm using an 22uF capacitor on the RFM69HW (MY_RFM69_TX_POWER_DBM 20) between Gnd an 3.3V.
        Is it to small ?
        12.1k
