  2. Announcements
  3. MySensors 2.2.0 released
33 Posts 16 Posters 13.8k Views 16 Watching
  • user1306U
    user1306U
    user1306
    Thanks all for the help
    @flopp i added the line like you mentioned.
    i added it as S_SOUND, V_LEVEL seem to be working fine, thanks. Lets hope Domoticz will include it soon.
    • user1306U
      user1306U
      user1306
      i have another simple question regarding the RF24_PA level.
      in the config file i see that its default to RF24_PA_MAX. does this mean that if i dont include anything in my sketch the node will default to MAX?
      i read somewhere that this could cause the node to fail sometimes if there's not enough current going through, since most of my nodes are run on battery i would like to know if its necessary to modify this?
      F 1 Reply Last reply
      • user1306U user1306
        F
        F
        flopp
        @user1306
        Correct, if you don't define RF24_PA LEVEL in your sketch it will use default values from Config, which in your case seems to be MAX
        • user1306U
          user1306U
          user1306
          Really appreciate your help thanks @flopp
          just wondering for normal nrf24l01+ not the PA LNA one, what level are you using? (no sure if mine are original since i bought them from Aliexpress i have my doubts).
            F
            F
            flopp
            @user1306
            I am using LOW and HIGH. LOW should be enough. I was testing HIGH with some nodes but I dont know if that helped.
            I also using nRF from AliE.
            I think most of MYS users are using nRF from China, i don't know how to see if it is real or fake.
            • ZwaZoZ
              ZwaZoZ
              ZwaZo
              I have a Strange problem appearing since I have started to upgrade my network from 2.1.1 to 2.2.0
              I am using a Domoticz v.3.8153 / Raspbian + a serial GW on NRF.
              Some of the devices are communicating to the GW through a repeater node equipped with a nrf24l01 PA LNA since they are just too far from the GW.
              Not all of the nodes are upgraded to 2.2.0, some are still running 2.1.1
              • the battery level reporting disappeared from all of the connected node (but one is still working : a senserblender micro with the original TempHum sketch)
              • The repeater node sometime stopped relaying the connection to the GW (on random time ?). Only thing I found is to restart this node)
              Any ideas ?
              Thanks a lot.
              Jef
              • maghacM
                maghacM
                maghac
                I've noticed that since the upgrade to 2.2.0 my nodes are now sending some new internal messages every now and then. I'm using a MQTT gateway and sometimes I see these messages coming through:
                mysensors-out/1/255/3/0/33 600000
                mysensors-out/1/255/3/0/32 500
                What are internal messages types 32 and 33? Can't find them in the list on https://www.mysensors.org/download/serial_api_20#internal
                AnticimexA 1 Reply Last reply
                • maghacM maghac
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @maghac Hi,
                  documentation is best found here: https://www.mysensors.org/apidocs/
                  It is always covering the latest release. Specifically, for message types: https://www.mysensors.org/apidocs/group__MyMessagegrp.html
                  jjkJ 1 Reply Last reply
                  • clio75C
                    clio75C
                    clio75
                    Thanx for 2.2.0
                    But I have a new feature that I did not have before.
                    I'm using VERA edge and my plugin reports that i don't have any connection to the Gateway.
                    Please advice :)
                    korttomaK 1 Reply Last reply
                    • clio75C clio75
                      Thanx for 2.2.0
                      Please advice :)
                      korttomaK
                      korttomaK
                      korttoma
                      @clio75 please try setting the "CommFailure" Variable to 0 under "Advanced" for your MySensors Plugin Device in Vera to see it the message disappears.
                      • Tomas
                      clio75C 1 Reply Last reply
                      • korttomaK korttoma
                        clio75C
                        clio75C
                        clio75
                        @korttoma
                        I switch "CommFailure" to 0 And reloaded engine. and error measure disappear.
                        But is this a new feature that you have implemented ?
                        • AnticimexA Anticimex
                          @maghac Hi,
                          jjkJ
                          jjkJ
                          jjk
                          @anticimex said in MySensors 2.2.0 released:
                          @maghac Hi,
                          Is there a way to disable these messages?
                          • jjkJ jjk
                            @maghac Hi,
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @jjk yes, by avoiding to use smartSleep: https://www.mysensors.org/apidocs/group__MySensorsCoregrp.html#gab5f84c4227e3478af4b6600d5e8d8b15
