  2. Announcements
  3. MySensors 2.2.0 released
33 Posts 16 Posters 13.9k Views 16 Watching
  • user1306U
    user1306U
    user1306
    wrote on last edited by user1306
    thank you very much for the hard work
    i'm very interested in #define MY_SIGNAL_REPORT_ENABLED
    So apologies for the stupid question but do i need to just enable this on the Node side or also the Gateway, or Config.h (because i saw it was commented out)?
    Do you know if this is supported by Domoticz?
    thanks in advance
    F 1 Reply Last reply
    • user1306U user1306
      thanks in advance
      F
      F
      flopp
      wrote on last edited by flopp
      @user1306
      I couldn't find any Signal value in Domoticz
      What I did was to send that information as a seperate Child
      use variable transportGetSignalReport(SR_TX_RSSI) to get the value
      send(RSSIMsg.set(transportGetSignalReport(SR_TX_RSSI)));
      • F flopp
        @user1306
        zboblamontZ
        zboblamontZ
        zboblamont
        @flopp There was always a RF signal level column under Devices in Domoticz, never did try to find out how it was used....
        • zboblamontZ zboblamont
          F
          F
          flopp
          @zboblamont
          It is still there, but I don't think DZ has implemented MYS RF signal, yet :)
          • user1306U
            user1306U
            user1306
            Thanks all for the help
            @flopp i added the line like you mentioned.
            i added it as S_SOUND, V_LEVEL seem to be working fine, thanks. Lets hope Domoticz will include it soon.
            • user1306U
              user1306U
              user1306
              i have another simple question regarding the RF24_PA level.
              in the config file i see that its default to RF24_PA_MAX. does this mean that if i dont include anything in my sketch the node will default to MAX?
              i read somewhere that this could cause the node to fail sometimes if there's not enough current going through, since most of my nodes are run on battery i would like to know if its necessary to modify this?
                F
                F
                flopp
                @user1306
                Correct, if you don't define RF24_PA LEVEL in your sketch it will use default values from Config, which in your case seems to be MAX
                • user1306U
                  user1306U
                  user1306
                  Really appreciate your help thanks @flopp
                  just wondering for normal nrf24l01+ not the PA LNA one, what level are you using? (no sure if mine are original since i bought them from Aliexpress i have my doubts).
                    F
                    F
                    flopp
                    @user1306
                    I am using LOW and HIGH. LOW should be enough. I was testing HIGH with some nodes but I dont know if that helped.
                    I also using nRF from AliE.
                    I think most of MYS users are using nRF from China, i don't know how to see if it is real or fake.
                    • ZwaZoZ
                      ZwaZoZ
                      ZwaZo
                      I have a Strange problem appearing since I have started to upgrade my network from 2.1.1 to 2.2.0
                      I am using a Domoticz v.3.8153 / Raspbian + a serial GW on NRF.
                      Some of the devices are communicating to the GW through a repeater node equipped with a nrf24l01 PA LNA since they are just too far from the GW.
                      Not all of the nodes are upgraded to 2.2.0, some are still running 2.1.1
                      • the battery level reporting disappeared from all of the connected node (but one is still working : a senserblender micro with the original TempHum sketch)
                      • The repeater node sometime stopped relaying the connection to the GW (on random time ?). Only thing I found is to restart this node)
                      Any ideas ?
                      Thanks a lot.
                      Jef
                      • maghacM
                        maghacM
                        maghac
                        I've noticed that since the upgrade to 2.2.0 my nodes are now sending some new internal messages every now and then. I'm using a MQTT gateway and sometimes I see these messages coming through:
                        mysensors-out/1/255/3/0/33 600000
                        mysensors-out/1/255/3/0/32 500
                        What are internal messages types 32 and 33? Can't find them in the list on https://www.mysensors.org/download/serial_api_20#internal
                        AnticimexA 1 Reply Last reply
                        • maghacM maghac
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @maghac Hi,
                          documentation is best found here: https://www.mysensors.org/apidocs/
                          It is always covering the latest release. Specifically, for message types: https://www.mysensors.org/apidocs/group__MyMessagegrp.html
                          jjkJ 1 Reply Last reply
                          • clio75C
                            clio75C
                            clio75
                            Thanx for 2.2.0
                            But I have a new feature that I did not have before.
                            I'm using VERA edge and my plugin reports that i don't have any connection to the Gateway.
                            Please advice :)
                            korttomaK 1 Reply Last reply
                            • clio75C clio75
                              Thanx for 2.2.0
                              Please advice :)
                              korttomaK
                              korttomaK
                              korttoma
                              @clio75 please try setting the "CommFailure" Variable to 0 under "Advanced" for your MySensors Plugin Device in Vera to see it the message disappears.
                              • Tomas
                              clio75C 1 Reply Last reply
                              • korttomaK korttoma
                                clio75C
                                clio75C
                                clio75
                                @korttoma
                                I switch "CommFailure" to 0 And reloaded engine. and error measure disappear.
                                But is this a new feature that you have implemented ?
                                • AnticimexA Anticimex
                                  @maghac Hi,
                                  jjkJ
                                  jjkJ
                                  jjk
                                  @anticimex said in MySensors 2.2.0 released:
                                  @maghac Hi,
                                  Is there a way to disable these messages?
                                  • jjkJ jjk
                                    @maghac Hi,
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @jjk yes, by avoiding to use smartSleep: https://www.mysensors.org/apidocs/group__MySensorsCoregrp.html#gab5f84c4227e3478af4b6600d5e8d8b15
