  3. ATSHA204 with Wemos D1 Mini
35 Posts 4 Posters 6.8k Views 3 Watching
  • E
    E
    elcaron
    wrote on last edited by elcaron
    Now, this is probably a stupid question, since there are PCBs and all around, so it seems to work, but how are the experiences on the ESP8266/Wemos D1 Mini, especially with the ATSHA204?
    I made an RFM69HCW/ATSHA204A breakout, it works with an Arduino Pro Mini, but I am completely unsuccessful with my Wemos D1 Mini that was supposed to be the gateway.
    With the ESP8266, I saw one successful run from the SecurityPersonalizer, but could never reproduce it.
    • I soldered the jumper cables to the pins to rule out breadboard issues (with the Pro Mini, solderless breadboard works)
    • The ATSHA does have a pullup and a close-by bypass cap with 100nF
    • I hardcoded the pin in the personalizer sketch. (This works with the Pro Mini )
    I am a little bit out of ideas. The error, "Failed to wake device. Response: E7", stays the same when I change to a different pin.
    The only other lib I found was the Sparkfun lib, which only compiles after one change of uint8_t->uint32_t in the header file, but also does not give successful results.
    I DO remember, though, that I also have mixed results with the DHT22, so it seems the timing required for one-wire devices on the ESP8266 is a bit rubbish.
    Any experiences?
    And if not: is there even a security advantage in an ATSHA on the gateway, which is stored safe in my attic, or would software signing on the comparably fast ESP be just as good?
    AnticimexA 1 Reply Last reply
    • E elcaron
      Any experiences?
      AnticimexA
      AnticimexA
      Anticimex
      @elcaron you might want to check that you stay within timing requirements on the single wire bus since it is bit banged and might be off if timers are not running as expected.
      And yes, for a gw, it is typically less critical to have readout protection of the keys.
      • E
        E
        elcaron
        I'll hook up my oscilloscope next week end. I hoped to get some response if people have the ATSHA running with the ESP8266 and if it was in any way tricky. If it is, it maybe should be documented somewhere to save other people some time, given that the ESP is e.g. part of the main wiring documentation and probably the choice for a gateway.
        I haven't changed anything but the pin definition in the Personalizer sketch, so if there is a problem in that regard, it is a general one (and even if people have it running out of luck, they may not have a stable config).
        • E elcaron
          AnticimexA
          AnticimexA
          Anticimex
          @elcaron the personalizer relies on the driver. So it is the driver you should focus on. There is nothing in the personalizer that configure how to communicate with the atsha except for the pin to use.
          • E
            E
            elcaron
            Ok, this is madness. With the default SecurityPersonalizer sketch, it fails pretty reproducably.
            If I add another Serial.print statement at the end of the setup funktion (I initially printed "Looping", but copying "Serial.println(F("Personalization is now complete."));" also works), it works pretty reliably.
            In the oscilloscope I see reproducable timing of the wakeup pulse and the first following pulse in the second version, but in the first, original version, the two measurements had different timings. Qualitatively, in the nonworking version, the first pulse after the wakup is longer than the following one, in the working version, it has the same length.
            Again, the only difference is commenting and uncommenting the additional Serial.print statement. ATSHA is on D2.
            If nobody has an idea how o reliably prevent this, I conclude that I cannot use the ESP8266 with the ATSHA, since I might run into the issue any time again under uncleared circumstances.
            AnticimexA 3 Replies Last reply
            • E elcaron
              AnticimexA
              AnticimexA
              Anticimex
              @elcaron I have no such hardware so I am not sure what the reason can be, but it looks like timing is different on that device. The atsha driver should not need adapting since it works fine on samd devices which also have different timing, but perhaps the corresponding low level i/o drivers work differently on esp. Perhaps @Yveaux has an idea.
              YveauxY 1 Reply Last reply
              • E elcaron
                AnticimexA
                AnticimexA
                Anticimex
                @elcaron if the only thing causing problem is after the setup or wake up, please consider adding something in the driver for esp targets so that this delay is ensured. If it works for all the other things, the i/o timing is fine, the esp is probably just too quick in starting to communicate after a wakeup. This should be handled by the driver. Just be aware that there are two versions of the driver. One in the sketch folder that contains all the needed logic to do personalization, and a different optimized one under drivers which is used by the MySensors library. The same fix is probably needed in both, but the fix should only apply to esp targets.
                • AnticimexA Anticimex
                  YveauxY
                  YveauxY
                  @anticimex said in ATSHA204 with Wemos D1 Mini:
                  Sorry, not really. I don't have an ESP/ATSHA setup, so I'm unable to replay.
                  @elcaron Did you verify timing on your oscilloscope w.r.t. the ATSHA datasheet?
                  • E elcaron
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @elcaron if you can confirm the i/o timing, I have a strong suspicion that the issue here is the time after a wakeup command and the next command. The esp is probably too quick to attempt it, so the driver need a extra delay after wakeup to ensure this does not happen. I can implement something, but I am going to have to rely on you to test and verify the fix.
                    So it would be helpful if you
                    1. Measured the delay in the working and non working code.
                    2. Checked the datasheet if there is a statement on wakeup delay
                    3. Personalized a gw and a node (the node could use sw signing) so we can test both variants of the driver.
                    I will give you some suggestions for adapting the driver for the tests. We can take it in a chat instead of littering the thread with experiments.
                    • E
                      E
                      elcaron
                      I have little time this afternoon, but I'll try to find more tomorrow. For documentation purposes, timing counted in ms from the triggering falling edge of the wake pulse:
                      Working, reproducible
                      0 falling
                      0.0725 rising
                      3.1638 falling
                      3.1694 rising
                      3.1790 falling
                      3.1846 rising
                      Non working, not exactly reproducible, only in the fact that the middle pulse is longer, instead of equal to all following pulses.
                      0 falling
                      0.0685 rising
                      3.1557 falling
                      3.1653 rising
                      3.1748 falling
                      3.1804 rising
                      What is strange is that my change in the code is the LAST line of the setup function. It happens AFTER the "Personalization complete" line. I don't see how it should change anything, without any serious compiler voodoo.
                      I have commented and uncommented the additional line at least 10 times, with multiple subsequent resets each, and there is no doubt it's that effect.
                      • E elcaron
                        0 falling
                        0.0725 rising
                        3.1638 falling
                        3.1694 rising
                        3.1790 falling
                        3.1846 rising
                        0 falling
                        0.0685 rising
                        3.1557 falling
                        3.1653 rising
                        3.1748 falling
                        3.1804 rising
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @elcaron compiler woodo is always a possibility, it is the first delay difference i think is the key here. We just need to define a way of ensuring proper delay, and I think it will be more stable.
                        • E elcaron
                          0 falling
                          0.0725 rising
                          3.1638 falling
                          3.1694 rising
                          3.1790 falling
                          3.1846 rising
                          0 falling
                          0.0685 rising
                          3.1557 falling
                          3.1653 rising
                          3.1748 falling
                          3.1804 rising
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @elcaron may i ask what library version you are using? "Personalization complete" is not printed by the current personalizer. Could you please do a test with the beta/development branch, or the 2.2.0 release?
                          • E
                            E
                            elcaron
                            I have been using 2.1.1, just updated to 2.2.0 with the Arduino library manager.
                            It seems I am still getting
                            |                                  Execution result                                  |
                            | FAILURE (last ATSHA204A return code: 0xE7)                                         |
                            with the unaltered (only hardcoded const int sha204Pin = D2;) sketch. Have to check with oscilloscope this evening., will report back.
                            • E
                              E
                              elcaron
                              Correcxtion: My bad, seems to work. Still really weird and looks random. How did code that is not called before everything should be finished influence the result?
                              • E elcaron
                                |                                  Execution result                                  |
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @elcaron I see. That code indicate that the chip is not responding as expected. We can experiment with various delays but best is to have an oscilloscope to get a working baseline. If you have a AVR node or similar with an ATSHA, you could run the same sketch on that and grab the timings, so we are sure to compare apples with apples.
                                • E elcaron
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @elcaron oh, ok. Not sure about why it affected the result to modify the last lines in the old sketch. But the compiler might do some sketch things when optimizing the code.
                                  What is it that appear random now, with 2.2.0?
                                  • E
                                    E
                                    elcaron
                                    2.2.0 looks fine by now, but the hardware in general still behaves randomly until it is at least halfway clear why this very strange behavior in 2.1.1 occures.
                                    Anyway, its just the gateway, not lots of nodes. I'll go ahead with this, Can still change it if more issues come up.
                                    Thanks for the great work on this.
                                    • E elcaron
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @elcaron Ok. Just let me know if you notice any erratic behavior with esp and atsha204a using the current (or future) versions of the library. The driver should take care of any timing requirements of the device, but you never know what the compiler might be up to...
                                      • E
                                        E
                                        elcaron
                                        Spoke too soon.
                                        I tried to generate AES and HMAC keys, but I think it it cannot hold the connection reliably:
                                        |                           MySensors security personalizer                          |
                                        |                               Configuration settings                               |
                                        | * ATSHA204A based personalization                                                  |
                                        | * Will generate HMAC key using ATSHA204A                                           |
                                        |                           Hardware security peripherals                            |
                                        | Device       | Status       | Revision     | Serial number                | Locked |
                                        | ESP8266      | DETECTED     | N/A          | A6EE1400EF401800AA           | N/A    |
                                        | ATSHA204A    | NOT DETECTED | N/A          | N/A                          | N/A    |
                                        |                                   Key generation                                   |
                                        | Key ID | Status | Key                                                              |
                                        | HMAC   | FAILED | FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF |
                                        |                                  Key copy section                                  |
                                        #define MY_HMAC_KEY 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
                                        |                                       EEPROM                                       |
                                        | HMAC   | RESET  | FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF |
                                        | AES    | RESET  | FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF                                 |
                                        | SERIAL | N/A    | Device unique serial, not stored in EEPROM                       |
                                        |                      This nodes whitelist entry on other nodes                     |
                                        {.nodeId = <ID of this node>,.serial = {0x01,0x23,0xD7,0xA6,0xFB,0x0C,0x55,0x23,0xEE}}
                                        |                                  Execution result                                  |
                                        | SUCCESS        |
                                        I see more data transmitted here than when it fails immediately. It is also different from when I just pull the cable:
                                        |                                  Execution result                                  |
                                        For a while I was able to also read the serial number of the ATSHA, but I cannot get there anymore. Electrically, everything seems fine, flanks have rise and fall times of <5ns.
                                        After the setup, my ESP tries to connect to an SSID which I don't have anymore every second. This is despite the fact that I ran the ClearEepromConfig sketch. Maybe that one also is not ESP8266 compatible
                                        • E elcaron
                                          Spoke too soon.
                                          |                                   Key generation                                   |
                                          |                                  Key copy section                                  |
                                          |                                       EEPROM                                       |
                                          |                                  Execution result                                  |
                                          | SUCCESS        |
                                          |                                  Execution result                                  |
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @elcaron in both cases it fails to detect your atsha device so something is not healthy with the driver and your esp board. I am afraid I have no clue what it might be. The driver is designed to ensure device timings are kept. I also double checked that it ensures proper delay after wakeup. So either the esp port timer is lying or there is something else that is dodgy.
                                          I am sorry to say I have no statistics on atsha users so I don't know if anyone else have been using it successfully with esp or if you are the first to ever attempt it.
