  3. ATSHA204 with Wemos D1 Mini
35 Posts 4 Posters 6.2k Views 3 Watching
  • E Offline
    E Offline
    elcaron
    I'll try another D1 Mini tomorrow. I have already tried it before when it just failed with 2.1.1, but this time, I'll investigate further.
    I think the ESP looses sync at some point. in 2.1.1 immediately, when I first tested with 2.2.0 between detection of ATSHA and key generation, now between wakeup acknowledgement and ATHSHA detection (serial and such)
    A 1 Reply Last reply
    • E elcaron
      A Offline
      A Offline
      Anticimex
      @elcaron it might be that something takes too long time and the atsha watchdog kicks in. But I find that highly unlikely as the esp is far more powerful than a atmega328p. I appreciate that you dig more at some point. I'll gladly assist any way I can.
      • E Offline
        E Offline
        elcaron
        Some more findings:
        • On my Wemos D1 Mini Pro, I can reliably (3 alternating uploads, multiple resets each) read the serial number when I flash with 160MHz setting in the IDE, but not with 80MHz. Key generation fails with both frequencies. I think if looses sync later, but eventually, it does.
        • I could reproduce this with 2 Wemos D1 Mini from different batches. One of those fresh from that back, the other two where used for MySensors tests before and try to connect to my old Wifi every second after the sketch.
        ESP8266 board code now fresh from Github. Again, I had similar issues with the ESP and the single wire interface of the DHT22. The ESP is a single core that runs wifi functions in the background. It just might not be up to the task of keeping these timings accurate.
        I ordered an ESP32 module last week, that should have one core dedicated to the sketch. Until then, I will use soft signing on the gateway. If anyone would like something tests, I can try, though.
        • E elcaron
          Some more findings:
          A Offline
          A Offline
          Anticimex
          @elcaron thanks for testing. So it might be that the wifi thread cause the atsha watchdog to bark, which nukes any ongoing session. I can have a look if adding some kicking of it or sleeping the atsha between accesses might help. Is there any way of disabling the wifi in the sketch? Or make it execute in a critical section so that personalization is done undisturbed?
          E 1 Reply Last reply
          • A Anticimex
            E Offline
            E Offline
            elcaron
            @anticimex WDT resets are usually indicated on the console. They happend a lot after the 2.1.1 sketch, but I haven't seen them after.
            I was more optimistic about the Wifi thing, before I tested a module that wasn't contaminated with an old MySensors config and didn't obviously try to connect.
            Are you using interrupts in the driver? If not, maybe disable them? As soon as I find time, I will try with calling
              WiFi.disconnect();
              WiFi.mode(WIFI_OFF);
              WiFi.forceSleepBegin();
            At the beginning of the setup function.
            That doesnt yield an immediate solution though, because we will need signing to work with Wifi. But it could give a hint.
            • E elcaron
                WiFi.disconnect();
              A Offline
              A Offline
              Anticimex
              @elcaron I am talking about the internal watchdog in the atsha. It ensures not too long idle activity is present between chained commands. Wifi is not needed for personalization and during normal operation, operations to the atsha should be pretty much atomic. We need to test that of course, but personalization needs to work first.
              zboblamontZ Y 2 Replies Last reply
              • A Anticimex
                zboblamontZ Offline
                zboblamontZ Offline
                zboblamont
                @anticimex "...operations to the atsha should be pretty much atomic" :scream:
                • A Anticimex
                  Y Offline
                  Y Offline
                  @anticimex said in ATSHA204 with Wemos D1 Mini:
                  According to the datasheet Twatchdog has a minimum value of 0.7sec and 1.3sec typical. That's ages in embedded-land, even for an esp that gets rescheduled by the wifi stack.
                  A 2 Replies Last reply
                  • Y Yveaux
                    A Offline
                    A Offline
                    Anticimex
                    @yveaux I know, but something on esp is not healthy with the atsha since 80 and 160 MHz operations differ
                    • zboblamontZ zboblamont
                      A Offline
                      A Offline
                      Anticimex
                      @zboblamont I don't think 'atomic' in programming language means what you think it means based on your reaction ;)
                      • Y Yveaux
                        A Offline
                        A Offline
                        Anticimex
                        @yveaux @elcaron I think a plausible explanation for the problem could be that the esp wifi interrupts, when unchecked, can break the bit banging protocol in the atsha driver and cause timing problems. If it helps to turn off the interrupts in the personalizer (which will not need wifi so that is a valid fix) the driver might need some critical sections to ensure timing is ensured with respect to the atsha during "normal" operation.
                        • E Offline
                          E Offline
                          elcaron
                          Haven't managed to do more tests today. Was trying to get a simple sensor + Gateway2MQTT config running, but the gateway just didn't receive any messages, despite the fact that Radiohead can use my RFM69HW hardware with at least 2.4GHz Wifi range. But let's not highjack my own thread :) I'll start a new one next weekend when I'll also try to run the personalizer without Wifi.
                          • E Offline
                            E Offline
                            elcaron
                            wrote on last edited by elcaron
                            #33
                            Found some time again. Could not solve the issue with disabling Wifi. Further, I got a bunch of ESP32, which should have a dedicated core for Wifi, and I still cannot get it working.
                            I have recorded the traces with a logic analyzer, compared to a Pro Mini and after the initial pulse, the timings seem to be vastly different. I only have sigrok pulseview available, and I find it hard do do any further analysis with it (including exporting it into any sensible format to import it to e.g. MATLAB ...)
                            Here are the Sigrok session files for a Wemos LOLIN32 and an Arduino Pro Mini, if anybody is interested.
                            I have also scoped the waveforms, they are pretty fine in both cases. The Pro Mini is on the same breadboard and powered by the LOLIN, they both have the same code fresh from Github (only change is ATSHA pin to pin 4) and the only thing I did between the two recordings is plug a jumper cable from pin 4 of one device to pin 4 for the other.
                            • E Offline
                              E Offline
                              elcaron
                              Over two years have passed and I have started another try, with no more success than last time. There seems to be a Sparkfun library that very close to the one in the SecurityPersonalizer script, but doesn't run with the ESP32 at all, despite being marked so in PlatformIO. ow are these related and could there be other version that are better adjusted to the ESP32?
                              Has anyone ever made any progress on this in the past 2 years?
                              • E elcaron
                                A Offline
                                A Offline
                                Anticimex
                                @elcaron I do not have the necessary hardware (or the time) I am afraid. I hope the community can help.
                                12.1k
