  3. How to get battery volt / percentage message send to mqtt?
15 Posts 3 Posters 3.1k Views 3 Watching
    Mr_sensor
    I Build a temp / hum sensor with the easyPcb board and Am able to get the temp and hum send to the Mqtt broker.
    Next thing is to get the battery voltage and % send to the Mqtt broker as well.
    Now that is giving me some problems. I merged the two scripts together, and tried to learn form other topics. But I'M not getting is right dough. This is my script right now:
    Also the output of the serial monitor.
    I have the feeling I am nearly there :) Any help would be great!
    [code]
     * Version 1.0: Henrik EKblad
     HTU21D Humidity Sensor
     Hardware Connections (Breakoutboard to Arduino):
     -VCC = 3.3V
     -GND = GND
     -SDA = A4 (use inline 330 ohm resistor if your board is 5V)
     -SCL = A5 (use inline 330 ohm resistor if your board is 5V)
    #define MY_NODE_ID 2
    #define MY_PARENT_NODE_ID 0
    // Enable debug prints
    //#define MY_RS485
    #include <SparkFunHTU21D.h>
    #include <Wire.h>
    //static const uint8_t FORCE_UPDATE_N_READS = 10;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_BATTERY 2
    //#define CHILD_ID_VOLT 2
    #define CHILD_ID_PRCNT 3
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    boolean metric = true;
      sendSketchInfo("Humidity", "2.0");
      present(CHILD_ID_HUM, S_HUM);
       present(CHILD_ID_BATTERY, S_MULTIMETER);
      //metric = getControllerConfig().isMetric;
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    //Create an instance of the object
    HTU21D myHumidity;
    MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
    //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRCNT);
        myHumidity.begin();
        analogReference(INTERNAL1V1);
    #else
        analogReference(INTERNAL);
      float temperature = myHumidity.readTemperature();
      //if (!metric) {
      //    temperature = (temperature * 1.8) + 32.0;
      Serial.print("T: ");
      Serial.println(temperature);
      float humidity = myHumidity.readHumidity();
      Serial.print("H: ");
      Serial.println(humidity);
       // get the battery Voltage
    //SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
    #ifdef MY_DEBUG
        float batteryV  = sensorValue * 0.003363075;
        Serial.print("Child ID ");
        Serial.print(CHILD_ID_BATTERY);
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print("Battery Percent: ");
        Serial.print(batteryPcnt);
        Serial.println(" %");
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
      sleep(SLEEP_TIME); //sleep a bit
    [/code]```
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=2
    38 TSF:SID:OK,ID=2
    40 TSM:FPAR
    43 TSM:FPAR:STATP=0
    45 TSM:ID
    47 TSM:ID:OK
    47 TSM:UPL
    51 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    59 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    65 TSF:MSG:PONG RECV,HP=1
    69 TSM:UPL:OK
    69 TSM:READY:ID=2,PAR=0,DIS=1
    75 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    81 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    90 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    100 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2111 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Humidity
    2119 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
    2129 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2138 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    2146 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    2154 MCO:REG:REQ
    2158 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2179 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2185 MCO:PIM:NODE REG=1
    2187 MCO:BGN:STP
    2189 MCO:BGN:INIT OK,TSP=1
    2244 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.2
    T: 19.20
    2277 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.7
    H: 42.68
    127
    Child ID 2Battery Voltage: 0.43 V
    Battery Percent: 12 %
    2289 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:12
    2297 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2304 TSF:TDI:TSL
    2306 MCO:SLP:WUP=-1
    2308 TSF:TRI:TSB
    2363 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.1
    T: 19.14
    2396 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.7
    H: 42.71
    Child ID 2Battery Voltage: 0.00 V
    Battery Percent: 0 %
    2406 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2414 TSF:TDI:TSL
    2416 MCO:SLP:WUP=-1
    2418 TSF:TRI:TSB
    2473 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.3
    T: 20.33
    2506 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:55.9
    H: 55.90
    2516 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2525 TSF:TDI:TSL
    2527 MCO:SLP:WUP=-1
    2529 TSF:TRI:TSB
    2584 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.6
    T: 19.59
    2617 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:45.1
    H: 45.06
    2627 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2635 TSF:TDI:TSL
    2637 MCO:SLP:WUP=-1
    2639 TSF:TRI:TSB
    2695 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.4
    T: 19.39
    2727 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:43.9
    H: 43.87
    2738 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    2746 TSF:TDI:TSL
    2748 MCO:SLP:WUP=-1
    2750 TSF:TRI:TSB
    2807 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.3
    T: 19.30
    2838 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:43.5
    H: 43.48
      @mr_sensor said in How to get battery volt / percentage message send to mqtt?:
      I think this needs to be a global variable, not inside loop, otherwise you set it to zero on each loop. I don't have my code with me at the moment to compare, but I think there is an error on the voltage and percentage calculation
      YveauxY 1 Reply Last reply
        YveauxY
        YveauxY
        @gohan said in How to get battery volt / percentage message send to mqtt?:
        Or prefix it with the 'static' keyword to indicate its value should persist over multiple runs.
        M 1 Reply Last reply
        • YveauxY Yveaux
          Mr_sensor
          @yveaux changed the position of int oldBatteryPcnt = 0; outside of the loop and added the static prefix static int oldBatteryPcnt = 0;
          Still not giving me the right result the first message seem ok but than it only has 0 ?
          2304 TSF:TDI:TSL
          2306 MCO:SLP:WUP=-1
          2308 TSF:TRI:TSB
          2363 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.6
          T: 19.56
          2396 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:39.7
          H: 39.69
          2408 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:0
          2414 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
          2420 TSF:TDI:TSL
          2422 MCO:SLP:WUP=-1
          2426 TSF:TRI:TSB
          2482 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.6
          T: 19.57
          2512 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:39.5
          H: 39.52
          2523 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
          2531 TSF:TDI:TSL```
            it looks as the analogread keeps returning zero
              Mr_sensor
              @gohan Tried to find out what causing that but can not figure it out. I'm bot a real coderer so its trial and error :) and trying to understand form other sketches / posts. Any idea where to look for?
                try adding a delay(500) before the analogread
                  Mr_sensor
                  delay(500)
                  Hi, tried that (already tried it with wait). Now I added it here:
                  delay(500);
                  Also tried it here:
                          delay(500);
                    sleep(SLEEP_TIME); //sleep a bit  ```
                  Both did not help still ending up with 0 .
                  So what should be the best place the right place to put the delay?
                    the second one is useless. It is odd that it misses the analog reads. What AVR boards version are you using?
                      Mr_sensor
                      @gohan I'm using the EasyPCB board with an arduino pro mini 3,3v
                        I mean in Arduino IDE library manager
                          Mr_sensor
                          @gohan
                          Arduino Pro or Pro Mini
                          Programmer AVR ISP
                          ATmega328P (3,3v 8mhz)
                          • M Mr_sensor
                            @gohan
                            Programmer AVR ISP
                            Mr_sensor
                            Still not getting it working! Any thoughts on this?
                              Try a simple example sketch that reads the analog pin just to make sure the hardware is OK, or try another pro mini
                                Mr_sensor
                                @gohan Ok will try that see if I made a fault somewhere
