  3. MySensors Hydroponics Greenhouse project
23 Posts 7 Posters 9.0k Views 10 Watching
  • ThucarT
    ThucarT
    Thucar
    Disconnecting the load eliminates the issue flat out.
    I think your previous question just triggered a lightbulb. While the module does have optocouplers in place, I have the VCC bridging jumper in place. So essentially Arduino is still sharing the power with relay coils. I'll install a step-down to get a 5V line from the pump power supply and use that to drive the relays. I believe that should eliminate my reboot issues.
    Controller: Node-Red
    Gateway: SerialGateway & GSMMQTTGateway
    MySensors: 2.2.0
    • ThucarT
      ThucarT
      Thucar
      Confirmed. Removing the jumper and using a power supply separate from the arduino’s has cured it from reboot issues.
      MySensors: 2.2.0
      • ThucarT
        ThucarT
        Thucar
        wrote on last edited by Thucar
        #23
        A quick video update: https://youtu.be/vnUFV_amSPQ
        The tomatos and peas are trying to go through the roof. Cucumbers are close to follow. They are all aiming for the ventilation hatches - I think they are planning a grand escape...
        The NFT system pump stopped working coupe weeks after setting it up. Have not gotten around to ordering a new pump. That will be a project for next year.
        MySensors: 2.2.0
