  3. MySensors Hydroponics Greenhouse project
23 Posts 7 Posters 9.3k Views 10 Watching
  • ThucarT
    ThucarT
    Thucar
    wrote on last edited by Thucar
    So, I’ve been using MySensors all around the house as test devices. I also set up a solar powered Beehive node last autumn, to monitor my hives conditon (went a bit overboard with a total of 6 temp sensors and a humidity sensor.) By the way, the sensors ended up saving my bees.
    Anyhow, I’m now tackling my biggest project yet. A 6.6m2 greenhouse which I’ll be converting to hydroponics. 44 dutch buckets for tomatos, cucumbers, radishes and a vertical NFT system for herbs.
    The goal for now is to monitor the following:
    • Nutrient solution pH levels - a kit from Aliexpress
    • Nutrient solution EC(parts per million) - a probe from Aliexpress
    • Nutrient solution temperature - NTC thermistor 10k
    • Nutrient solution level in the tank - ultrasonic transceiver
    • Dutch bucket substrate moisture - Moisture pitchfork
    • Ambient air temperature - NTC thermistor 10k
    • Ambient air relative humidity - SHT21
    • Ambient light levels - BH1750
    • Some way to monitor if the water is flowing?
    As for the actuators, my greenhouse ventilation windows are operated by sylinders with heat expanding gas. So I will have no direct control over them. The only thing I’m thinking that needs operating, are the circulation pumps. I’ll be using a simple dual relay module for that at first with the possibility of switching to a mosfet later on, as it seems the pumps might respond well to a variable input voltage and thus, allow me to fine tune the rate of liquid flow.
    The brains for the operation will be Arduino Mega with a sensors shield. I only later realized it's an Uno shield, but luckily the pinouts match and I should be able to use it without much hassle. Might actually be a good thing because I can use a dedicated header for the radio and whatever else I need to connect to the 22+ ports.
    Controller: Node-Red
    Gateway: SerialGateway & GSMMQTTGateway
    MySensors: 2.2.0
    YveauxY 1 Reply Last reply
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      I look forward to seeing this project progress. Go get it!! :)
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      • ThucarT Thucar
        YveauxY
        YveauxY
        @thucar nice project!
        That ultrasound transducer needs some electronics to work, but you probably already knew that ;-)
        • ThucarT
          ThucarT
          Thucar
          I just realized there is no MysBootloader for the Arduino Mega 2560. Which means I'm going to try and use the trusty Pro Mini with ATmega328p instead. (I have a version with all analog pins available for use) If I run out of pins or features, I'll switch to the 2560.
          So while I'm waiting for the bulk of the sensors to arrive, I'm just creating the general sketch structure.
          MySensors: 2.2.0
          • ThucarT
            ThucarT
            Thucar
            So, a quick update. First of all, I’m considering falling back to the tried and true Dallas temperature sensors instead of the thermistors. At first I figured the thermistors would be an interesting alternative to familiarize myself with but as they require extra components, I’m gonna take the shortcut.
            The same goes for the ultrasonic sensor. I’m going to try and find an affordable waterproof distance sensor to use instead.
            So far I have the relay, light level sensor, soil humidity sensor and the temp sensors hooked up and working. Working on getting the EC sensing part set up. Still waiting for the actual probe, but I should be able to get the firmware done using any random stainless steel rods. It should boil down to calibration in the end.
            I currently have 4 digital pins left- hopefully it will be enough.
            MySensors: 2.2.0
            • ThucarT
              ThucarT
              Thucar
              This is where I'm at right now. Support for 2 relays with push buttons, light level and soil moisture measurements. Customizable measurement interval for entire device and each sensor individually. Also a change threshold (a change greater than given threshold in two consecutive readings triggers an immediate report).
              Everything is running off interrupts to ensure smooth operation.
              NB! I have not yet managed to do live tests with the BH1750 as it has not yet arrived.
              Next up are the temperature sensors and EC meter. Or whatever sensor will be the next to arrive.
               * Version 1.0 - Rait Lotamõis
               * First iteration of a Hydroponic greenhouse controller sketch.
               * Supports:
               * 2 relays with individual push buttons
               * BH1750 Light sensor
               * Moisture sensor
              #define MY_REPEATER_FEATURE
              #include <Vcc.h>
              #include <ResponsiveAnalogRead.h>
              #include <BH1750.h>
              #include <Wire.h>
              #include <TimerOne.h>
              // Measurement and reporting settings
              #define REPORT_INTERVAL 600 // define report interval in seconds for all sensors. This is when a full report is sent, no matter what
              #define MOI_MEASUREMENT_INTERVAL 10 // Time in seconds, between consecutive measurements
              #define MOI_REPORT_THRESHOLD 5 // The difference in % between two consecutive readings to send an immediate report
              #define LUX_MEASUREMENT_INTERVAL 15 // Time in seconds, between consecutive measurements
              #define LUX_REPORT_THRESHOLD 100 // The difference in Lux between two consecutive readings to send an immediate report
              // Relay settings. TODO: Make it easy to use more than two relays
              #define RLY_PIN_1  4
              #define RLY_PIN_2  5
              #define RLY_BTN_1 2 // Pin to use for a pushbutton switch. NB! Needs an interrupt pin
              #define RLY_BTN_2 3 // Pin to use for a pushbutton switch. NB! Needs an interrupt pin
              #define RLY_ON 0  // GPIO value to write to turn on attached relay
              #define RLY_OFF 1 // GPIO value to write to turn off attached relay
              #define RLY_ID_1 1 // MySensors Child ID
              #define RLY_ID_2 2 // MySensors Child ID
              // Soil Moisture settings
              #define MOI_SENSE_PIN A0 // Analog pin connecting to the probe
              #define MOI_POWER_PIN 6 // Pin for powering the humidity sensor
              #define MOI_0_PERCENT 0 // Probe output voltage at 0% moisture
              #define MOI_100_PERCENT 2.5 // Probe output voltage in a glass of water
              #define MOI_ID 3 // MySensors Child ID
              // Lux sensor settings
              #define LUX_ID 0 // MySensors Child ID
              // General settings
              #define VCC_VOLTAGE_READ 5.0 // Actual supply voltage going to the VCC. Use a multimeter to check
              #define VCC_VOLTAGE_REPORTED 4.97 // Set this to the same as above for your first boot. Then insert the value reported in the Serial window during boot
              #define ONE_SECOND_IN_MICROS 500000 // Depends on your crystal. 8MHz crystal:500000, 16MHz crystal:1000000, etc. If your time intervals are off, this is the reason
              // Soil Moisture variables
              float cal0 = MOI_0_PERCENT;
              float cal100 = MOI_100_PERCENT;
              ResponsiveAnalogRead analogMoi(MOI_SENSE_PIN, false);
              MyMessage msgMoi(0,V_LEVEL);
              float lastMoisture = 0;
              // Relay variables
              MyMessage msgRly(0,V_STATUS);
              bool rlyState1 = false;
              bool rlyState2 = false;
              // Lux sensor variables
              BH1750 luxSensor;
              MyMessage msgLux(0, V_LIGHT_LEVEL);
              uint16_t lastLux = 0;
              // VCC Monitoring for calculations
              const float VccCorrection = VCC_VOLTAGE_READ/VCC_VOLTAGE_REPORTED;
              Vcc vcc(VccCorrection);
              // General variables
              bool receivedConfig = false;
              bool metric = true;
              long reportTimer = REPORT_INTERVAL;
              long moiTimer = MOI_MEASUREMENT_INTERVAL;
              long luxTimer = LUX_MEASUREMENT_INTERVAL;
              const unsigned long debounceTime = 50;
              void before()
                // Initialize the timer interrupt for sending sensor reports
                Timer1.initialize(ONE_SECOND_IN_MICROS);
                Timer1.attachInterrupt(countDownOneSecond);
                // Initialize and set relays to last known states (using eeprom storage)
                pinMode(RLY_PIN_1, OUTPUT);
                pinMode(RLY_PIN_2, OUTPUT);
                rlyState1 = loadState(RLY_ID_1);
                rlyState2 = loadState(RLY_ID_2);
                digitalWrite(RLY_PIN_1, rlyState1?RLY_ON:RLY_OFF);
                digitalWrite(RLY_PIN_2, rlyState2?RLY_ON:RLY_OFF);
                // Set the interrupts for relay buttons
                pinMode(RLY_BTN_1, INPUT_PULLUP);
                pinMode(RLY_BTN_2, INPUT_PULLUP);
                attachInterrupt(digitalPinToInterrupt(RLY_BTN_1), toggleRly1, FALLING);
                attachInterrupt(digitalPinToInterrupt(RLY_BTN_2), toggleRly2, FALLING);
                // Initialize Soil Moisture power pin
                pinMode(MOI_POWER_PIN, OUTPUT);
                digitalWrite(MOI_POWER_PIN, LOW);
                // Initialize the Lux sensor
                luxSensor.begin();
                // Take and report voltage readings
              #ifdef MY_DEBUG
                Serial.print("Measuring VCC voltage as: ");
                Serial.print(vcc.Read_Volts());
                Serial.println("V");
                sendSketchInfo("Greenhouse Node", "0.3");
                // Register Relays
                present(RLY_ID_1, S_BINARY);
                present(RLY_ID_2, S_BINARY);
                // Register Soil Moisture sensor
                present(MOI_ID, S_MOISTURE);
                // Register Lux sensor
                present(LUX_ID, S_LIGHT_LEVEL);
                // Update the relay outputs
                updateRelays();
                // Get Soil Moisture levels if it is time
                if (moiTimer == 0){
              #ifdef MY_DEBUG
                  Serial.print("Taking Moisture measurements: ");
                  readMoisture();
              #ifdef MY_DEBUG
                  Serial.print(lastMoisture);
                  Serial.println("%");
                // Get Lux level if it is time
                if (luxTimer == 0){
              #ifdef MY_DEBUG
                  Serial.print("Taking Lux measurements: ");
                  readLux();
              #ifdef MY_DEBUG
                  Serial.print(lastLux);
                  Serial.println("lux");
                // Send reports it if is time
                if (reportTimer == 0){
              #ifdef MY_DEBUG
                  Serial.println("Sending reports.");
                  sendReports();
                if (message.isAck()) {
              #ifdef MY_DEBUG
                   return;
                if (message.type==V_STATUS) {
                    // Change relay state
                    int outputPin = (message.sensor == RLY_ID_1)?RLY_PIN_1:RLY_PIN_2;
                    digitalWrite(outputPin, message.getBool()?RLY_ON:RLY_OFF);
                    // Store state in eeprom
              #ifdef MY_DEBUG
                    // Write some debug info
                    Serial.print("Incoming change for relay:");
                    Serial.print(message.sensor);
                    // Update the state variables
              // Check if a button has been pressed, meaning we should flip the relay
              void updateRelays(){
                bool oldState1 = loadState(RLY_ID_1);
                bool oldState2 = loadState(RLY_ID_2);
                if (oldState1 != rlyState1){
                  saveState(RLY_ID_1, rlyState1?true:false);
                  send(msgRly.setSensor(RLY_ID_1).set(rlyState1?true:false), false);
                if (oldState2 != rlyState2){
                  saveState(RLY_ID_2, rlyState2?true:false);
                  send(msgRly.setSensor(RLY_ID_2).set(rlyState2?true:false), false);
              // Send all reports using last known values
              void sendReports(){
                // Send Lux
                send(msgLux.set(lastLux));
                // Send Moisture
                send(msgMoi.set(lastMoisture,1));
              // Get the light level values
              void readLux(){
                uint16_t lux = luxSensor.readLightLevel();
                // Check if the difference between previous reading and this one is enough to warrant an immediate report
                if ((abs(lux-lastLux) > LUX_REPORT_THRESHOLD) && reportTimer > 0){
                  send(msgLux.set(lux));
                lastLux = lux;
              // get the soil moisture values
              void readMoisture(){
                float v = vcc.Read_Volts();
                int aRead = readSoil();
                float voltage = (aRead * v / 1024.0);
                float moisture = voltage * 100/cal100;
                if ((abs(moisture-lastMoisture) > MOI_REPORT_THRESHOLD) && reportTimer > 0){
                  send(msgMoi.set(moisture,1));
                lastMoisture = moisture;
              // Perform the actual powering up and measurement process for Soil moisture sensor. TODO: Does it really need a separate function?
              int readSoil()
                int val;
                digitalWrite(MOI_POWER_PIN, HIGH);
                delay(10);//wait 10 milliseconds
                analogMoi.update();
                val = analogMoi.getValue();
                return val;
              // Interrupt Service Routines
              // TODO: Would love to use the same ISR for both (all?) relays
              void toggleRly1(){
                static unsigned long previousStateChangeMillis = 0;
                bool pinState = digitalRead(RLY_BTN_1);
                if (pinState == LOW) { // only falling events
                  if ((millis() - previousStateChangeMillis) > debounceTime) { // debounce
                    rlyState1 = !rlyState1;
                previousStateChangeMillis = millis();
              void toggleRly2(){
                bool pinState = digitalRead(RLY_BTN_2);
                    rlyState2 = !rlyState2;
              void countDownOneSecond(void) {
                if (moiTimer > 0){
                  moiTimer--;
                if (luxTimer > 0){
                  luxTimer--;
                if (reportTimer > 0) {
                  reportTimer--;
              MySensors: 2.2.0
              • ThucarT
                ThucarT
                Thucar
                Got carried away. Added thermistor temperature readings and EC measurement. I have no idea if EC is working correctly at this point, without having the probe yet. I referenced the code by Michael Ratcliffe who did amazing job on utilizing an US power plug as a probe.
                Another addition was to make all values poll-able. So you can get a fresh reading when needed without having to wait for the report time to tick over.
                 * Supports:
                 * Moisture sensor
                #include <Vcc.h>
                #include <BH1750.h>
                #include <Wire.h>
                #include <SmoothThermistor.h>
                #define TMP_MEASUREMENT_INTERVAL  15 // Time in seconds, between consecutive measurements
                #define TMP_REPORT_THRESHOLD      1 // The difference in degrees between two consecutive readings to send an immediate report
                #define PPM_MEASUREMENT_INTERVAL  10 // Time in seconds, between consecutive measurements
                #define PPM_REPORT_THRESHOLD      50 // The difference in ppm between two consecutive readings to send an immediate report
                #define RLY_PIN_1   4
                #define RLY_PIN_2   5
                // Temperature sensor settings (NTC Thermistors)
                #define TMP_SENSE_PIN   1 // Analog pin the first thermistor connects to NB! Use numeric values only. so instead of A0, A1, etc just use 0,1
                #define TMP_MAX_SENSORS 1 // Number of thermistors connected. They need to be attached to sequential pins
                #define TMP_USE_AREF    false // If your Arduino has the ARef pin available, you should use it
                #define TMP_NOMINAL_RES 10000 // Nominal resistance of thermistors being used
                #define TMP_SERIES_RES  12000 // Value of the voltage divider resistor
                #define TMP_BETA        3950 // You will get the Beta coeficent from your thermistors datasheet
                #define TMP_NOMINAL_T   25 // Nominal temperature for the thermistor
                #define TMP_SAMPLES     10 // Number of samples to take
                #define TMP_ID          10 //Mysensors Child ID
                // PPM sensor settings
                #define PPM_SENSE_PIN   A7 // Analog pin used for the probe
                #define PPM_POWER_PIN   7 // Digital pin used to supply power to the probe
                #define PPM_RESISTOR    560 // No less than 300 and no more than 1K resistor should be used. Around 500 gives the best resolution
                #define PPM_CALIBRATION 1.38  // EC value of Calibration solution in s/cm
                #define PPM_TEMP_COEF   0.019 // 0.019 is generaly considered the standard for plant nutrients [google "Temperature compensation EC" for more info]
                #define PPM_TEMP_SENSOR 10 // Temperature sensor ID that is measuring your solution temperature
                #define PPM_ID          4 // MySensors Child ID
                // General settings
                // PPM variables
                int ppmR1 = PPM_RESISTOR;
                int ppmRa = 25;
                float ppmTempFinish = 0;
                float ppmTempStart = 0;
                float lastEC = 0;
                int lastPPM = 0;
                ResponsiveAnalogRead analogPpm(PPM_SENSE_PIN, false);
                MyMessage msgPpm(0,V_EC);
                // Relay variables
                BH1750 luxSensor;
                // Temperature sensor variables
                float lastTemperatures[TMP_MAX_SENSORS];
                MyMessage msgTmp(0,V_TEMP);
                bool metric = true;
                long tmpTimer = TMP_MEASUREMENT_INTERVAL;
                long ppmTimer = PPM_MEASUREMENT_INTERVAL;
                void before()
                  luxSensor.begin();
                  // Initialize the PPM sensor
                  pinMode(PPM_POWER_PIN , OUTPUT );
                  digitalWrite(PPM_POWER_PIN , LOW );
                  pinMode(PPM_SENSE_PIN,INPUT);
                  ppmR1=(ppmR1+ppmRa);
                #ifdef MY_DEBUG
                  // Register Relays
                  // Register PPM sensor
                  present(PPM_ID, S_WATER_QUALITY);
                  // Register temperature sensors
                  for (int i=0; i<TMP_MAX_SENSORS; i++) {
                     present(TMP_ID+i, S_TEMP);
                  updateRelays();
                  if (moiTimer == 0){
                #ifdef MY_DEBUG
                    readMoisture();
                #ifdef MY_DEBUG
                  if (luxTimer == 0){
                #ifdef MY_DEBUG
                    readLux();
                #ifdef MY_DEBUG
                // Get PPM level if it is time
                  if (ppmTimer == 0){
                #ifdef MY_DEBUG
                    Serial.println("Taking PPM measurements: ");
                    readPPM();
                #ifdef MY_DEBUG
                    Serial.print(lastPPM);
                    Serial.println("ppm");
                    Serial.print(lastEC);
                    Serial.println("s/cm");
                  // Get Temperatures if it is time
                  if (tmpTimer == 0){
                #ifdef MY_DEBUG
                    Serial.println("Taking Temperature measurements: ");
                    readTemperatures();
                #ifdef MY_DEBUG
                for (int i=0; i<TMP_MAX_SENSORS;i++){
                  Serial.print(TMP_ID+i);
                  Serial.print(": ");
                  Serial.print(lastTemperatures[i]);
                  Serial.println("C");
                #ifdef MY_DEBUG
                    sendReports();
                #ifdef MY_DEBUG
                     return;
                #ifdef MY_DEBUG
                  } else if (message.type==V_TEMP){ // Return temperature readings when queried
                    readTemperatures();
                    send(msgTmp.setSensor(message.sensor).set(lastTemperatures[message.sensor-TMP_ID],1));
                  } else if (message.type==V_LEVEL && message.sensor == MOI_ID){ // Return moisture readings when queried
                    readMoisture();
                  } else if (message.type==V_LEVEL && message.sensor == LUX_ID){ // Return Light level readings when queried
                    readLux();
                  } else if (message.type==V_EC){
                    readPPM();
                    send(msgPpm.set(lastPPM));
                void sendReports(){
                  // Send Lux
                  // Send Moisture
                  // Send PPM
                  // Send Temperatures
                  for (int i=0; i< TMP_MAX_SENSORS;i++){
                    send(msgTmp.setSensor(TMP_ID+i).set(lastTemperatures[i],1));
                // Get the PPM levels
                void readPPM(){
                  float EC = 0;
                  float EC25 = 0;
                  long PPM = 0;
                  float raw = 0;
                  float Vin = vcc.Read_Volts();
                  float Vdrop = 0;
                  float Rc = 0;
                  float val = 0;
                  digitalWrite(PPM_POWER_PIN, HIGH);
                  wait(10);
                  analogPpm.update();
                  raw = analogPpm.getValue();
                  Vdrop = ((Vin * raw) / 1024.0);
                  Rc =(Vdrop*ppmR1)/(Vin-Vdrop);
                  Rc = Rc-ppmRa;
                  EC = 1000/(Rc*PPM_CALIBRATION);
                  EC25 = EC / (1 + (PPM_TEMP_COEF * (lastTemperatures[PPM_TEMP_SENSOR - TMP_ID] - 25.0)));
                  PPM = EC25 * 1000 / 2;
                  if (abs(lastPPM - PPM) > PPM_REPORT_THRESHOLD && reportTimer > 0){
                    send(msgPpm.set(PPM));
                  lastPPM = PPM;
                  lastEC = EC25;
                void readLux(){
                  lastLux = lux;
                // Get the temperature values
                void readTemperatures(){
                  int i;
                  bool sendReport = false;
                #ifdef MY_DEBUG
                    Serial.println("Temperatures:");
                  for (i=0;i<TMP_MAX_SENSORS;i++){
                    SmoothThermistor smoothThermistor(TMP_SENSE_PIN+i,              // the analog pin to read from
                                                  ADC_SIZE_10_BIT,             // the ADC size
                                                  TMP_NOMINAL_RES,             // the nominal resistance
                                                  TMP_SERIES_RES,              // the series resistance
                                                  TMP_BETA,                    // the beta coefficient of the thermistor
                                                  TMP_NOMINAL_T,               // the temperature for nominal resistance
                                                  TMP_SAMPLES);                // the number of samples to take for each measurement
                    smoothThermistor.useAREF(TMP_USE_AREF);
                    float temp = smoothThermistor.temperature();
                    if ((abs(temp-lastTemperatures[i]) > TMP_REPORT_THRESHOLD) && reportTimer > 0){
                      send(msgTmp.setSensor(TMP_ID+i).set(temp,1));
                    lastTemperatures[i] = temp;
                int readSoil()
                  int val;
                  analogMoi.update();
                  return val;
                void toggleRly1(){
                void toggleRly2(){
                  if (ppmTimer > 0){
                    ppmTimer--;
                  if (moiTimer > 0){
                    moiTimer--;
                  if (tmpTimer > 0){
                    tmpTimer--;
                  if (luxTimer > 0){
                    luxTimer--;
                    reportTimer--;
                MySensors: 2.2.0
                • Nick WillisN
                  Nick WillisN
                  Nick Willis
                  This looks very interesting! I also want to get my gardening more automated as I live in an apartment with a roof terrace which makes using soil hard work (no lift/elevator and we're on the 5th floor!). I grow tomatoes, peppers, chillies etc but keeping up with the watering on my south facing terrace is hard work. Fertilising regularly is even more hard work. I installed a basic irrigation system but I've not been successful in mixing in liquid fertiliser at the right concentrations. So I'm back to measuring it into a watering can which takes forever.
                  So I'm wondering if hydroponics might be the way to go. What sort of equipment are you using for hydroponics? Would it work if left outside without protection in the rain etc? If not then maybe I'm better trying to improve on my irrigation system.. and somehow finding a way to operate it with fertiliser at a specific concentration.
                  Will follow this all with interest...
                  • ThucarT
                    ThucarT
                    Thucar
                    First of all let me emphasis that this is going to be my first hydroponic setup. So I have no experience to draw on. That being said, I am seeing a lot of information on outdoor hydroponic setups. Rain water getting into your solution is to be prevented as much as possible, but it’s no disaster if some does end up in your tank.
                    For tomatoes, peppers, cucumbers and other tall plants, people seem to prefer something like the Dutch bucket system. If you get buckets with lids, you can just drill a 2 inch hole for the plant to poke through and keep most of the rain out.
                    For smaller plants like leafy greens, herbs and such, the PVC pipe system seems great. You could set it up either as a NFT or a Flood&Drain system. The benefit again is that the rain water will not have a way into your nutrient solution.
                    MySensors: 2.2.0
                    • ThucarT
                      ThucarT
                      Thucar
                      To quote the classics - “Well, that escalated quickly.”
                      While waiting for the sensors to arrive, I started mulling over the entire project in my head. And I started thinking about scaling. My greenhouse is only 3 meters long but my parents greenhouse is almost 30 meters. Routing wires for soil sensors around the place is no fun.
                      So that got me thinking - does it need to be one node? And that in turn got me thinking - does it even have to be a node? Maybe a gateway would be the way to go?
                      So this is my current plan - a GSM/Wifi gateway with the general and more power hungry components( pH, EC, relative air humidity and ambient temp, relays). The gateway would be located near the pumps, sumps and other tech in the greenhouse.
                      Then the rest of the greenhouse can be filled with any number of sensors to monitor soil moisture, temperature and light levels at different places.
                      GSM gateway is almost finished, hopefully I can wrap it up tomorrow.
                      And as a final touch, I realized a controller of that kind of functionality could use a local user input. So it’s going to have a LCD and some buttons for set-up and things like starting/stopping pumps for maintenance.
                      MySensors: 2.2.0
                      • ThucarT
                        ThucarT
                        Thucar
                        Update:
                        LCD + rotary click encoder working
                        ArduinoMenu4 in place and easily expandable.
                        Relay control works 100%
                        EC/ppm measurement in place, not yet 100% working
                        SHT21 code in place, can confirm if working or not once the darn thing arrives
                        Some eye candy:
                        0_1521972951209_P3251112_v1.JPG 0_1521972959027_P3251113_v1.JPG 0_1521972966435_P3251114_v1.JPG
                        MySensors: 2.2.0
                        • E
                          E
                          elcaron
                          A thought I had recently: Those moisture pitchforks are usually HASL coated. Do I really want that in the soil of a plant I probably want to eat? Any thoughts anyone?
                          Nca78N 1 Reply Last reply
                          • E elcaron
                            Nca78N
                            Nca78N
                            @elcaron said in MySensors Hydroponics Greenhouse project:
                            The answer is no :)
                            • ThucarT
                              ThucarT
                              Thucar
                              HASL
                              The pitchfork i'm currently using has solid copper traces on the forks. For more long term use I'm planning on switching to capacitive soil moisture sensors. Those can be additionally coated with epoxy resin for example for added longevity.
                              MySensors: 2.2.0
                              • ThucarT
                                ThucarT
                                Thucar
                                Now that the GSM Gateway is done, I can start focusing more on the Greenhouse controller. I’m still waiting for the two most important components though - the pH sensor module and the stainless steel EC sensor probe. I’ve stumbled on another very good post on the EC topic which I’ll have to work through: https://thecavepearlproject.org/2017/08/12/measuring-electrical-conductivity-with-an-arduino-part1-overview/
                                MySensors: 2.2.0
                                • ThucarT
                                  ThucarT
                                  Thucar
                                  Got some work done on the hardware side of things. Drainage is done, next up is feed part.
                                  0_1523760989088_P4141136_v1.JPG 0_1523760724731_P4141133_v1.JPG 0_1523760736892_P4141140_v1.JPG 0_1523760744189_P4141141_v1.JPG
                                  MySensors: 2.2.0
                                  • ThucarT
                                    ThucarT
                                    Thucar
                                    A long overdue update.
                                    In the end I basically ended up using a GSM gateway with a LCD and couple sensors (air temperature and air humidity) and two relays. The relays control my Dutch bucket system pump and ventilation fans.
                                    As a separate sensor I'm using a Z-Wave multisensor to keep track of nursery temperatures and lux levels.
                                    The pH meter module did arrive but I do not feel comfortable keeping it submerged in the nutrient solution at all times so I've been just taking a sample of the nutrient solution from the tank after mixing a new batch, and testing it indoors, at the computer.
                                    As for the EC meter, I failed to get any of the "arduino only" examples to produce reliable readings. So I've ordered 5 PCB's for this thing: https://www.sparkyswidgets.com/portfolio-item/miniec-i2c-ec-interface/
                                    Once they arrive, I'll see if I can get more reliable results with a separate module.
                                    So far the whole thing has been running almost perfectly. The only drawback is an occasional reboot of the gateway when switching off the Dutch bucket system pump. I'm using two separate power sources for Arduino and the pump, Added a 1000uF cap to the Arduino power rail and a flyback diode across the pumps power lines. Still getting that reboot about 50% of the time.
                                    Some pics to wrap up my rant.
                                    PS. Yes, that's a webcam in my greenhouse. It's taking hourly snapshots for a timelapse :)
                                    My NFT rails for herbs. A good eye can spot some dill, basil and cilantro plants in there.
                                    That's my "Nursery" - an old fish tank I can cover with a piece of glass when night temps dip below 10C
                                    That's my Fibaro Motion sensor. An easy way to get some essential readings. Like the length of day, hours of sunlight, temperature.
                                    This is my ratsnest. I should have moved the relays to a separate enclosure further away. Right now I think the arc when breaking contact is what's causing an EMP pulse and rebooting my Mega.
                                    Ventilation fans. The temps soared to high 40's and low 50's with door and both ceiling hatches wide open. The fans kick in when air temp reaches 25C
                                    MySensors: 2.2.0
                                      Are you using optocouplers to drive the relays?
                                      • ThucarT
                                        ThucarT
                                        Thucar
                                        Yes, the relay module has optocouplers separating data lines from the relays.
                                        MySensors: 2.2.0
                                          Try disconnecting the load from the relay and see if it still triggers the reboot. If you still have the issue, try disconnect the relays and try again. You need to start narrowing down the possible causes
