  3. Watermeter pulsesensor
7 Posts 2 Posters 3.3k Views 1 Watching
  • E Offline
    E Offline
    egbertje
    wrote on last edited by egbertje
    I have build an sensor with the watermeterpulsesensor sketch with an arduino nano and the TCRT5000 module sensor.
    It works but everytime the value rises with 2 for one rotation of my watermeter. Default /1000 ( 1liter per rotation)
    So again when i get with a mirror and make the sensor go high (green led goes on) the value rises with 1 but when i remove the reflector (green led goes off) also the value rises wth one again.
    So it looks like the code triggers to the up and down going flank together of one pulse.
    Do i have to change something in the code?
    B 1 Reply Last reply
    • E egbertje
      B Offline
      B Offline
      BulldogLowell
      @egbertje
      maybe you re getting some bounce which creates two interrupts...
      you could play around with that here:
      void onPulse()
        if (!SLEEP_MODE) {
          unsigned long interval = newBlink-lastBlink;
      	lastPulse = millis();
          if (interval<500000L) {
            // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)<<<<<< HERE
            return;
          flow = (60000000.0 /interval) / ppl;
          lastBlink = newBlink;
        pulseCount++;
      • E Offline
        E Offline
        egbertje
        Hi Bulldog,
        I allready played with that value and increased it to 2 or 3 seconds but that does not change my problem.
        I think the problem is that this code sees a pulse and when the pulse is going from zero to high it is 1 count but also when this pulse is going again to zero the count is 2.
        • E egbertje
          Hi Bulldog,
          B Offline
          B Offline
          BulldogLowell
          @egbertje
          try the other edge yet?
          pinMode(2, INPUT_PULLUP); // keep pin from floating
          attachInterrupt(INTERRUPT, onPulse, FALLING);
          • E Offline
            E Offline
            egbertje
            Also this does not work (pinmode3)
            • E Offline
              E Offline
              egbertje
              This post is deleted!
              • E Offline
                E Offline
                egbertje
                After testing some more i get better result with this setting:
                attachInterrupt(INTERRUPT, onPulse, LOW);
