  3. Adding Door sensor to Multisensor not working...
8 Posts 4 Posters 2.8k Views 4 Watching
  • S
    ShadeX12
    Greetings All,
    I previously had a working sketch for a multi-sensor. I have since tried to add a door switch to the sketch but i can't get it working at all. All the other sensors seem to be working. Any advice you can provide would be greatly appreciated.
    // Enable debug prints
    #define MY_NODE_ID 233
    #define MY_PARENT_NODE_ID 0
    #include <DHT.h>
    #include <Bounce2.h>
    #define CHILD_ID_MOTION 1   // Id of the sensor child
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    #define CHILD_ID_DOOR 4
    #define DHT_DATA_PIN 5
    #define SENSOR_TEMP_OFFSET 0
    #define BUTTON_PIN  7  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    MyMessage msgHum(CHILD_ID_HUM, V_HUM), msgDoor(CHILD_ID_DOOR, V_TRIPPED), msgTemp(CHILD_ID_TEMP, V_TEMP), msg(CHILD_ID_MOTION, V_TRIPPED);
    DHT dht;
      sendSketchInfo("TemperatureHumidityMotionAndDoor", "1.2");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_MOTION, S_MOTION);
      present(CHILD_ID_DOOR, S_DOOR);
      if (1200000 <= dht.getMinimumSamplingPeriod()) {
          // Setup the button
        pinMode(BUTTON_PIN,INPUT_PULLUP);
         // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msgDoor.set(value==HIGH ? 1 : 0));
         oldValue = value;
        #ifdef MY_DEBUG
        Serial.print("D: ");
        Serial.println(value);
      // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
        send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
       sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    Thanks!
    alexsh1A 1 Reply Last reply
    • S ShadeX12
      Greetings All,
      #include <DHT.h>
      int oldValue=-1;
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
            // Setup the button
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
        debouncer.update();
           oldValue = value;
          #ifdef MY_DEBUG
      Thanks!
      alexsh1A
      alexsh1A
      alexsh1
      @shadex12 said in Adding Door sensor to Multisensor not working...:
      BUTTON_PIN
      Are you trying to add a motion sensor or a reed switch? What is BUTTON_PIN?
      What is the log saying?
      Try to substitute the following
      with
      sleep(DIGITAL_INPUT_SENSOR-2, CHANGE, 0);
      S 1 Reply Last reply
      • alexsh1A alexsh1
        BUTTON_PIN
        with
        ShadeX12
        @alexsh1
        Thanks for the response. I should have been more clear. I currently have motion, temperature and humidity. I am trying to add a reed switch to use as a door sensor.
        With the code a I posted above motion temp and humidity all work fine but I cannot get any output from the reed switch. I have tested the switch itself and it is fine, so I know it is my code. I am not much of a coder so I mostly sticking stuff together from the examples and trying to learn and improve but I really don't know what I am doing.
        BUTTON_PIN I believe is where i define which pin on the Arduino to connect the reed switch to.
        The serial output shows that the reed switch registers with the gateway and I can see it in Home Assisstant, but it never updates or outputs anything in the logs again after this line:
        189 TSF:MSG:SEND,233-233-0-0,s=4,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
        I made the change to the code as you suggested but it didn't seem to any effect, positive or negative.
        • bgunnarbB
          bgunnarbB
          bgunnarb
          Hi!
          This is how I see it:
          You sleep most of the time so both the motion sensor and the door sensor will have to generate an interrupt in order for the sensor to transmit.
          The Arduino only has two interrupts, 0 and 1. Pin 2 generates interrupt 0 and pin 3 generates interrupt 1.
          The motion sensor is attached to pin 3 which generates interrupt 1 (3-2 = 1) but only pins 3 and 2 are able to generate interrupts. You have attached your door sensor to BUTTON_PIN = pin 7 but pin 7 cannot generate an interrupt. This is why you never see this triggered.
          Try attaching the door sensor to pin 2 and re-use the code for the motion sensor, transmitting the message msgDoor.
          You will have to change the sleep message also to handle two interrupts. This is the constructor for the sleep message, taken from the 2.x API-definition:
          int8_t sleep(uint8_t interrupt1, uint8_t mode1, uint8_t interrupt2, uint8_t mode2, unsigned long ms=0);
          I have never been so busy since I retired!
          • bgunnarbB bgunnarb
            Hi!
            alexsh1A
            alexsh1A
            alexsh1
            @bgunnarb Spot on!
            @ShadeX12 You have to re-wire your Reed sensor to pins 2 or 3
            • S
              ShadeX12
              Thanks a lot everyone for the responses. I have got a little further. I am now able to get readings from the door sensor...sort of.
              Everything works fine with the sensor if the door switch is close. As soon as the switch is open, it flips to open the close over and over again a spams the gateway with the messages.
              Here's what I've got for code. I suspect maybe something is wrong with the loop.
               * Version 1.0 - Henrik Ekblad
               * Motion Sensor example using HC-SR501
               * http://www.mysensors.org/build/motion
              #include <DHT.h>
              #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              #define DIGITAL_INPUT_SENSOR2 3 // The input for door sensor
              #define DHT_DATA_PIN 4
              float lastTemp;
              float lastHum;
              bool metric = true;
              // Initialize motion message
              MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
              MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
              DHT dht;
                sendSketchInfo("TemperatureAndHumidity", "1.1");
                  pinMode(DIGITAL_INPUT_SENSOR2, INPUT);      // sets the door sensor digital pin as input
                  digitalWrite(DIGITAL_INPUT_SENSOR2,HIGH);   // Activate internal pull-up
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                } else {
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                } else {
                  nNoUpdatesHum++;
                // Read digital door value
                  bool tripped2 = digitalRead(DIGITAL_INPUT_SENSOR2) == HIGH;
                  Serial.println(tripped2);
                  send(msgDoor.set(tripped2?"1":"0"));  // Send tripped value to gw
                sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, digitalPinToInterrupt(DIGITAL_INPUT_SENSOR2), CHANGE, SLEEP_TIME);
              • S ShadeX12
                #include <DHT.h>
                float lastTemp;
                float lastHum;
                bool metric = true;
                DHT dht;
                    if (!metric) {
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                  } else {
                    nNoUpdatesTemp++;
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                  } else {
                    nNoUpdatesHum++;
                @shadex12 see if setting the door sensors to INPUT_PULLUP instead of INPUT helps.
                My guess is that the pin is floating.
                Edit: sorry, I see now that the pin is set to high which does the same thing as setting pullup. Ignore my advice :)
                • S
                  ShadeX12
                  Okay I figured this out!
                  The problem was actually with where I was defining the pins. They where withing the if statement for the DHT warning. I have moved them outside that statement and it seems to be working fine.
                  #include <DHT.h>
                  float lastTemp;
                  float lastHum;
                  bool metric = true;
                  DHT dht;
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                    } else {
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                    } else {
                      nNoUpdatesHum++;
                  Thanks again for all your help everyone!
