  3. ESP8266 WiFi gateway and signing
6 Posts 2 Posters 1.7k Views 3 Watching
  • B
    B
    bilbolodz
    Is signing for ESP8266 gateway supported? I know that hardware signing is NOT supported but how about software? If so should be personalization in usual way (using sketch from examples) like "arduino nano" nodes?
    AnticimexA 1 Reply Last reply
    • B bilbolodz
      AnticimexA
      AnticimexA
      Anticimex
      @bilbolodz soft signing should work, yes.
      • B
        B
        bilbolodz
        So I should first "personalise" ESP8266 device with "standard personalising sketch" and than upload my GW code with #define MY_SIGNING_SOFT. Right?
        • B bilbolodz
          AnticimexA
          AnticimexA
          Anticimex
          @bilbolodz The procedure is no different compared to other nodes. Unless you use the "simple" security flags, in which case no personalization is needed.
          • B
            B
            bilbolodz
            OK I will try it today. Yesterday I've done such procedure (without success) but now I've realised that I've used OLD (2.1) personalisation script (saved on disk) but loaded GW code compiled with 2.2 library. Probably that's an issue.
            • B bilbolodz
              AnticimexA
              AnticimexA
              Anticimex
              @bilbolodz Yes, then you lack the checksum and you should get a init-error from the security backend.
