  3. Is a bootloader worth the limitations?
6 Posts 4 Posters 1.7k Views 5 Watching
  • JohnRobJ
    JohnRobJ
    JohnRob
    I'm working on my first to be commissioned node (i.e. not just a test device). I am thinking of using the WDT to reset the system if the processor gets "lost". I am using a Mini Pro board and found the normal WDT reset instructions do not work. My investigation found at least one post that blamed it on the bootloader (not yet verified myself).
    My question is:
    Except for possible OTA reprogramming and maybe a slightly easier programming connection what does a boot loader gain you?
    I realize to perform ISP programming you need a different programmer (I have a AVR MKii clone).
    Am I missing something?
    dbemowskD 1 Reply Last reply
    • JohnRobJ JohnRob
      My question is:
      dbemowskD
      dbemowskD
      @johnrob Another option would be an external hardware based WDT. I have read that they are more reliable than the software based WDTs. I have been working on a board for this, but haven't had the time to do any final testing, but here is a design that I found on the web that uses a 555 timer. I mapped out this schematic in EasyEDA:
      Here is what I came up with for a board using through hole components:
      This board could be made a fraction of the size using SMDs.
      • JohnRobJ
        JohnRobJ
        JohnRob
        @dbemowsk
        Thank for the thought. I am familiar with the 555 (or in this case the 555C) but the WDT should work. BTW if I were to try an external device I would use the TPL5010 as this will be battery powered.
        Back to my point, It would be much easier to just use an ISP than to add an additional circuit. Hence my question, is the boot loaded providing some other function I've not not aware of (mentioned above)?
        • tbowmoT
          tbowmoT
          tbowmo
          If you have an ISP device, then I would say no. The bootloader does not add extra value, and could be left out of the equation.
          JohnRobJ 1 Reply Last reply
          • tbowmoT tbowmo
            JohnRobJ
            JohnRobJ
            JohnRob
            @tbowmo
            Thanks for the response. I'll start to the ISP. All my non Arduino AVR projects were all programmed with ISP. I moved to Arduino specifically for MySensors.
            John
            • bjacobseB
              bjacobseB
              bjacobse
              wrote on last edited by bjacobse
              As I recall the "normal" bootloader have not configured the WDT (I guess it's too difficult for a newbire to understand and handle WDT)
              Optiboot have WDT configured and you can set it
              Remember to call this at for each less than 8sec, else you will get reboot via watchdog
              I recommend not to set the wdt time too short, as you then won't be able to upload a sketch, as the Arduino then will reset during sketch-upload (But this isn't a problem when using ISP)
              wdt_enable(WDTO_8S);
              https://github.com/Optiboot/optiboot/wiki/HowOptibootWorks
