  3. RFM69 Project
RFM69 Project
2 Posts 2 Posters 991 Views 1 Watching
  • Z
    Z
    zok
    Hi all,
    I have an application that requires 2 RFM69 sensor modules to monitor the open/closed position of 2 drawers in a cabinet (through reed switches). I am using the following for this: https://www.tindie.com/products/easySensors/arduino-ide-compatible-wireless-switch/
    The receiver should wirelessly monitor the data sent from these nodes and turn on an LED for each output (when a draw is open). I am using the following for this:
    https://www.tindie.com/products/easySensors/button-sized-rfm-69-wireless-node/
    I have managed to get the sensor node working with the example code provided by the developer, but I am stuck with the receiver code.
    Would it be possible to have 2 switch sensor nodes send their switch status data to one receiver node?
    Can someone please help with an example of how to do this?
    Thanks in advance.
    Zok
    • scalzS
      scalzS
      Hi!
      the receiver could be the gateway, or search for node to node communication in the forum if this is what you need.
      And if you need hw infos related to your boards, I think the designer is Koresh, in MySensors Openhardware section
      https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node
