  3. NodeManager
  4. SetsleepSeconds is not a member of class NodeManager
3 Posts 2 Posters 2.1k Views 2 Watching
  • U
    U
    usernobody
    wrote on last edited by usernobody
    since a few days I try out the new nodemanager version 1.7.
    so far everything works which I need very well, but when I try to set SetsleepSeconds I get the above error when compiling.
    i am using arduino ide 1.8.5 with current mysensors library and arduino mega 2560 r3 board
    the error occurs even with almost unchanged example sketch
     * MySensors node configuration
    // General settings
    #define SKETCH_NAME "NodeManager"
    #define SKETCH_VERSION "1.0"
    //#define MY_NODE_ID 99
    // NRF24 radio settings
    //#define MY_RF24_ENABLE_ENCRYPTION
    //#define MY_RF24_CHANNEL 125
    //#define MY_RF24_PA_LEVEL RF24_PA_HIGH
    //#define MY_DEBUG_VERBOSE_RF24
    //#define MY_RF24_DATARATE RF24_250KBPS
    // RFM69 radio settings
    //#define MY_RFM69_FREQUENCY RFM69_433MHZ
    //#define MY_IS_RFM69HW
    //#define MY_RFM69_NEW_DRIVER
    //#define MY_RFM69_ENABLE_ENCRYPTION
    //#define MY_RFM69_NETWORKID 100
    //#define MY_DEBUG_VERBOSE_RFM69
    //#define MY_RF69_IRQ_PIN D1
    //#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
    //#define MY_RF69_SPI_CS D2
    //#define MY_RFM69_ATC_MODE_DISABLED
    // RFM95 radio settings
    //#define MY_RADIO_RFM95
    //#define MY_RFM95_FREQUENCY (RFM95_868MHZ)
    //#define MY_DEBUG_VERBOSE_RFM95
    //#define MY_RFM95_MAX_POWER_LEVEL_DBM (20)
    //#define MY_RFM95_IRQ_PIN D1
    //#define MY_RFM95_IRQ_NUM MY_RFM95_IRQ_PIN
    //#define MY_RFM95_CS_PIN D8
    // RS485 serial transport settings
    //#define MY_RS485
    //#define MY_RS485_BAUD_RATE 9600
    //#define MY_RS485_DE_PIN 2
    //#define MY_RS485_MAX_MESSAGE_LENGTH 40
    //#define MY_RS485_HWSERIAL Serial1
    // Message signing settings
    //#define MY_SIGNING_SOFT
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
    //#define MY_SIGNING_REQUEST_SIGNATURES
    //#define MY_SIGNING_ATSHA204
    //#define MY_SIGNING_ATSHA204_PIN 4
    // OTA Firmware update settings
    //#define MY_OTA_FIRMWARE_FEATURE
    //#define OTA_WAIT_PERIOD 300
    //#define FIRMWARE_MAX_REQUESTS 2
    //#define MY_OTA_RETRY 2
    // Advanced settings
    #define MY_BAUD_RATE 9600
    //#define MY_SMART_SLEEP_WAIT_DURATION_MS 500
    //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE
    //#define MY_SIGNAL_REPORT_ENABLED
    // Optimizations when running on 2032 Coin Cell. Also set node.setSleepBetweenSend(500) and run the board at 1Mhz
    //#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
    //#define MY_TRANSPORT_WAIT_READY_MS  5000
    //#define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 2000
    //#define MY_PARENT_NODE_ID 0
    //#define MY_PARENT_NODE_IS_STATIC
     * MySensors gateway configuration
    // Common gateway settings
    //#define MY_REPEATER_FEATURE
    // Serial gateway settings
    #define MY_GATEWAY_SERIAL
    // Ethernet gateway settings
    //#define MY_GATEWAY_W5100
    // ESP8266 gateway settings
    //#define MY_GATEWAY_ESP8266
    //#define MY_ESP8266_SSID ""
    //#define MY_ESP8266_PASSWORD ""
    // Gateway networking settings
    //#define MY_PORT 5003
    //#define MY_GATEWAY_MAX_CLIENTS 2
    //#define MY_USE_UDP
    // Gateway MQTT settings
    //#define MY_GATEWAY_MQTT_CLIENT
    //#define MY_PORT 1883
    //#define MY_MQTT_CLIENT_ID "mysensors-1"
    //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
    //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
    // Gateway inclusion mode
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Gateway Leds settings
    //#define MY_DEFAULT_ERR_LED_PIN 4
    //#define MY_DEFAULT_RX_LED_PIN  5
    //#define MY_DEFAULT_TX_LED_PIN  6
     * NodeManager modules for supported sensors
    //#define USE_BATTERY
    //#define USE_SIGNAL
    //#define USE_CONFIGURATION
    //#define USE_ANALOG_INPUT
    //#define USE_THERMISTOR
    //#define USE_ML8511
    //#define USE_ACS712
    //#define USE_DIGITAL_INPUT
    //#define USE_DIGITAL_OUTPUT
    //#define USE_DHT
    //#define USE_SHT21
    //#define USE_INTERRUPT
    //#define USE_DS18B20
    //#define USE_BH1750
    //#define USE_MLX90614
    //#define USE_BME280
    //#define USE_BMP085_180
    //#define USE_BMP280
    //#define USE_SONOFF
    //#define USE_HCSR04
    //#define USE_MCP9808
    //#define USE_MQ
    //#define USE_MHZ19
    //#define USE_AM2320
    //#define USE_TSL2561
    //#define USE_PT100
    //#define USE_DIMMER
    //#define USE_PULSE_METER
    //#define USE_PMS
    //#define USE_VL53L0X
    //#define USE_SSD1306
    //#define USE_SHT31
    //#define USE_SI7021
    //#define USE_CHIRP
    //#define USE_HD44780
    //#define USE_TTP
    //#define USE_SERVO
    //#define USE_APDS9960
    //#define USE_NEOPIXEL
     * NodeManager built-in features
    // Enable/disable NodeManager's features
    #define FEATURE_DEBUG ON
    #define FEATURE_POWER_MANAGER OFF
    #define FEATURE_INTERRUPTS ON
    #define FEATURE_CONDITIONAL_REPORT OFF
    #define FEATURE_EEPROM OFF
    #define FEATURE_SLEEP ON
    #define FEATURE_RECEIVE ON
    #define FEATURE_TIME OFF
    #define FEATURE_RTC OFF
    #define FEATURE_SD OFF
    #define FEATURE_HOOKING OFF
     * Load NodeManager Library
    #include "NodeManagerLibrary.h"
    NodeManager node;
     * Add your sensors below
    // built-in sensors
    //SensorBattery battery(node);
    //SensorConfiguration configuration(node);
    //SensorSignal signal(node);
    //PowerManager power(5,6);
    // Attached sensors
    //SensorAnalogInput analog(node,A0);
    //SensorLDR ldr(node,A0);
    //SensorRain rain(node,A0);
    //SensorSoilMoisture soil(node,A0);
    //SensorThermistor thermistor(node,A0);
    //SensorML8511 ml8511(node,A0);
    //SensorACS712 acs712(node,A0);
    //SensorDigitalInput digitalIn(node,6);
    //SensorDigitalOutput digitalOut(node,6);
    //SensorRelay relay(node,6);
    //SensorLatchingRelay1Pin latching1pin(node,6);
    //SensorLatchingRelay2Pins latching2pins(node,6,7);
    //SensorDHT11 dht11(node,6);
    //SensorDHT22 dht22(node,6);
    //SensorSHT21 sht21(node);
    //SensorHTU21D htu21(node);
    //SensorInterrupt interrupt(node,3);
    //SensorDoor door(node,3);
    //SensorMotion motion(node,3);
    //SensorDs18b20 ds18b20(node,6);
    //SensorBH1750 bh1750(node);
    //SensorMLX90614 mlx90614(node);
    //SensorBME280 bme280(node);
    //SensorBMP085 bmp085(node);
    //SensorBMP180 bmp180(node);
    //SensorBMP280 bmp280(node);
    //SensorSonoff sonoff(node);
    //SensorHCSR04 hcsr04(node,6);
    //SensorMCP9808 mcp9808(node);
    //SensorMQ mq(node,A0);
    //SensorMHZ19 mhz19(node,6,7);
    //SensorAM2320 am2320(node);
    //SensorTSL2561 tsl2561(node);
    //SensorPT100 pt100(node,6);
    //SensorDimmer dimmer(node,3);
    //SensorRainGauge rainGauge(node,3);
    //SensorPowerMeter powerMeter(node,3);
    //SensorWaterMeter waterMeter(node,3);
    //SensorPlantowerPMS pms(node,6,7);
    //SensorVL53L0X vl53l0x(node,3);
    //DisplaySSD1306 ssd1306(node);
    //SensorSHT31 sht31(node);
    //SensorSI7021 si7021(node);
    //SensorChirp chirp(node);
    //DisplayHD44780 hd44780(node);
    //SensorTTP ttp(node);
    //SensorServo servo(node,6);
    //SensorAPDS9960 apds9960(node,3);
    //SensorNeopixel neopixel(node,6);
     * Main Sketch
    // before
    void before() {
      // setup the serial port baud rate
      Serial.begin(MY_BAUD_RATE);
      * Configure your sensors below
      // report measures of every attached sensors every 10 seconds
      //node.setReportIntervalSeconds(10);
      // report measures of every attached sensors every 10 minutes
      //node.setReportIntervalMinutes(10);
      // set the node to sleep in 30 seconds cycles
      node.setSleepSeconds(30);
      // set the node to sleep in 5 minutes cycles
      //node.setSleepMinutes(5);
      // report battery level every 10 minutes
      //battery.setReportIntervalMinutes(10);
      // set an offset to -1 to a thermistor sensor
      //thermistor.setOffset(-1);
      // change the id of a the first child of a sht21 sensor
      //sht21.children.get(1)->setChildId(5);
      // report only when the analog value is above 40%
      //analog.children.get(1)->setMinThreshold(40);
      // power all the nodes through dedicated pins
      //node.setPowerManager(power);
      * Configure your sensors above
      node.before();
    // presentation
    void presentation() {
      // call NodeManager presentation routine
      node.presentation();
    // setup
      // call NodeManager setup routine
      node.setup();
    // loop
      // call NodeManager loop routine
      node.loop();
    #if FEATURE_RECEIVE == ON
    // receive
      // call NodeManager receive routine
      node.receive(message);
    #if FEATURE_TIME == ON
    // receiveTime
    void receiveTime(unsigned long ts) {
      // call NodeManager receiveTime routine
      node.receiveTime(ts);
    did I forget to set a setting or where could the problem lie?
    thank you for your effort?
    best regards
    Stefan
    U 1 Reply Last reply
    • U usernobody
      // General settings
      //#define MY_RS485
      //#define USE_DHT
      //#define USE_SHT21
      //#define USE_MQ
      //#define USE_MHZ19
      //#define USE_PT100
      //#define USE_PMS
      //#define USE_SHT31
      //#define USE_CHIRP
      //#define USE_TTP
      //#define USE_SERVO
      NodeManager node;
      // built-in sensors
      // Attached sensors
       * Main Sketch
      // before
      void before() {
        node.before();
      // presentation
      // setup
        node.setup();
      // loop
        node.loop();
      // receive
      // receiveTime
      best regards
      Stefan
      U
      U
      usernobody
      I kick myself 😑 ...gateway and sleep don't fit very well ...Problem solved!!!
      • U usernobody
        U
        U
        user2684
        @usernobody even if you're right, gateway and sleep do not fit very well, it should compile just fine. Do you have the compilation error to share? Thanks!
