  2. Bug Reports
  3. Strange value being sent from controller using mixed temp/relay node
multiple sensormqtterror
42 Posts 6 Posters 22.2k Views 3 Watching
  • T tjay4x4
    I try this code on pro mini with Vera3 but then I implementing it I have a DOOR Switch instead of Ds18b20. So is it possile to show temperature on vera and what's wrong?
    repeater started, id 1
    send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=25,st=ok:Liquid warm floore relay
    send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 1-1-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=2,c=0,t=0,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=4,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=5,c=0,t=3,pt=0,l=5,st=ok:1.4.1
    send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.6
    send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:28.2
    send: 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,st=ok:28.5
    hekH Offline
    hekH Offline
    @tjay4x4
    We can't help you much without any code.
    • G Gambituk
      and here is the modified relay/temp sketch
      // Running DS temperature sensor(s) and relay(s) on one mysensor arduino node
          // Combines Onewire and Relay code
          // 2014-10-14 Pego: Tested and Running on Uno/Clone and MQTT gateway
          // Example sketch showing how to send in OneWire temperature readings
          // Example sketch showing how to control physical relays.
          // This example will remember relay state even after power failure.
          #include <OneWire.h>presen
          #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
          unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
          OneWire oneWire(ONE_WIRE_BUS);
          int numSensors=0;
          boolean metric = true;
          MyMessage msg(0,V_TEMP);
            // Startup OneWire
            sensors.begin();
            //gw.begin();
            gw.sendSketchInfo("Temp and Relays", "1.0");
               gw.present(i, V_TEMP);
            // Fetch relay status
              gw.present(sensor, S_LIGHT);
              pinMode(pin, OUTPUT);
              digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
            gw.process();
              // Only send data if temperature has changed more then 1 degC and no error
              if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
            //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
            if (message.type==V_LIGHT) {
               // Change relay state
               // Store state in eeprom
               // Write some debug info
               Serial.print(message.sensor);
      T Offline
      T Offline
      tjay4x4
      Sorry. :) Hek, I using this code. Vera3 find relay and it works, but also appears 3 door sensors instead of 3 temp sensors.
      I try to use the my arduino board only with sd18b20 sketch and it work's and show temperature. Is it sketch suitale for vera?
          int numSensors=0;
            // Startup OneWire
            sensors.begin();
            //gw.begin();
            gw.process();
