  3. sleep() in MySensors 2.2.0
5 Posts 3 Posters 1.4k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Hello all,
    I have read about a long discussion about sleep() in MySensors with @AWI and @Yveaux discussing that for PIR sensors sleep must be used with "LOW" interrupt according to atmega328p spec. However, I did try it and it just does not work. If I change
    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    to anything like
    sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), LOW, SLEEP_TIME);
    my PIR stops working.
    I cannot use smartSleep() as I have Domoticz.
    What's the final verdict? How sleep function has to be used please?
    YveauxY 1 Reply Last reply
      If you set it on "high"?
      alexsh1A 1 Reply Last reply
      • alexsh1A alexsh1
        Hello all,
        to anything like
        YveauxY
        YveauxY
        @alexsh1 it is a bug in the atmega datasheet that only certain levels can be used. Change should also work, although it might give two wakes for each trigger.
        Make sure to use mySensors 2.2.x as some issues with waking from sleep by interrupts have been fixed.
          alexsh1A
          alexsh1A
          alexsh1
          @gohan I have not tried it. All I can say is that LOW does not work for PIRs. At least in my setup
          • YveauxY Yveaux
            alexsh1A
            alexsh1A
            alexsh1
            @yveaux thank you!
