  3. relay statue doesn't change
22 Posts 3 Posters 4.3k Views 3 Watching
  • L
    L
    ludoarchi
    hi everyone
    i make a relay sensor this weekend but it doesn t work. The statue never change.
    This the log if someone can help me
    thinks
    send: 136-136-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 136-136-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 136-136-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-136 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    repeater started, id=136, parent=0, distance=1
    send: 136-136-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
    send: 136-136-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 136-136-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    read: 0-0-136 s=1,c=1,t=2,pt=0,l=1,sg=0:0
    send: 136-136-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
    Incoming change for sensor:1, New status: 0
      Did you use the standard code from the example?
      L 1 Reply Last reply
        L
        L
        ludoarchi
        @gohan yes standard code
        • L ludoarchi
          L
          L
          ludoarchi
          @ludoarchi 1.5.4 version
          gohanG 1 Reply Last reply
          • L
            L
            ludoarchi
            nobody have idea ?
            • Boots33B
              Boots33B
              Boots33
              wrote on last edited by Boots33
              Your only getting 0 sent for the relay so it certainly won't be changing status. Perhaps post the code you are using .
              • L ludoarchi
                @ludoarchi said in relay statue doesn't change:
                what version?
                • L
                  L
                  ludoarchi
                  arduini 1.6.5 + Mysensors libraries 1.5.4
                  and relay actuator code come from mysensors 1.5.4 exemple
                  • Boots33B Boots33
                    L
                    L
                    ludoarchi
                    @boots33 i only used code from mysensors exemple. I tried exemples V1 and V2 and i always have only 0 sent. I don't understand.
                    • Boots33B
                      Boots33B
                      Boots33
                      1.5.4 is a few versions back now so it will help if you post the code you are using, even if it is the standard version. That will give us a starting point to work from.
                      Also what controller are you using.
                      L 3 Replies Last reply
                      • L ludoarchi
                        @ludoarchi Is there a reason why you don't update arduino to 1.8.5 and mysensors to 2.2?
                          L
                          L
                          ludoarchi
                          @gohan because i remenber that it used to work in that old version. But i have test yesterday with mysensors 2.2.0 et code V2 and it s ths same problem ... an idea ?
                          • Boots33B Boots33
                            L
                            L
                            ludoarchi
                            wrote on last edited by gohan
                            @boots33 that s the code V1
                            // Example sketch showing how to control physical relays.
                            // This example will remember relay state even after power failure.
                              gw.sendSketchInfo("Relay", "1.0");
                              // Fetch relay status
                                gw.present(sensor, S_LIGHT);
                                pinMode(pin, OUTPUT);
                                digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                              gw.process();
                              if (message.type==V_LIGHT) {
                                 // Change relay state
                                 // Store state in eeprom
                                 // Write some debug info
                                 Serial.print(message.sensor);
                            • Boots33B Boots33
                              L
                              L
                              ludoarchi
                              @boots33 that s the code V2
                               * Version 1.0 - Henrik Ekblad
                              #define MY_REPEATER_FEATURE
                              void before()
                              		present(sensor, S_BINARY);
                              	if (message.type==V_STATUS) {
                              • Boots33B Boots33
                                L
                                L
                                ludoarchi
                                @boots33 i m using mysensor 2.2 with jeedom last version on rpi3 (serial gateway and node with 4.7uf condo).
                                i also used my old rpi2 with Mysensors 1.5.4 for test
                                  are you checking the right relay pin? Pls post a v2 node log
                                    L
                                    L
                                    ludoarchi
                                    @gohan 16 MCO:BGN:INIT REPEATER,CP=RNNRA---,VER=2.2.0
                                    26 MCO:BGN:BFR
                                    27 TSM:INIT
                                    28 TSF:WUR:MS=0
                                    35 TSM:INIT:TSP OK
                                    37 TSF:SID:OK,ID=136
                                    39 TSM:FPAR
                                    75 TSF:MSG:SEND,136-136-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    2083 !TSM:FPAR:NO REPLY
                                    2085 TSM:FPAR
                                    2121 TSF:MSG:SEND,136-136-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    2568 TSF:MSG:READ,0-0-136,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    2573 TSF:MSG:FPAR OK,ID=0,D=1
                                    2842 TSF:MSG:READ,5-5-136,s=255,c=3,t=8,pt=1,l=1,sg=0:2
                                    2851 TSF:MSG:READ,45-45-136,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                    4129 TSM:FPAR:OK
                                    4130 TSM:ID
                                    4131 TSM:ID:OK
                                    4133 TSM:UPL
                                    4136 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                    4148 TSF:MSG:READ,0-0-136,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    4153 TSF:MSG:PONG RECV,HP=1
                                    4156 TSM:UPL:OK
                                    4157 TSM:READY:ID=136,PAR=0,DIS=1
                                    4162 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    4169 TSF:MSG:READ,0-0-136,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    4179 TSF:MSG:SEND,136-136-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                                    4195 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    4220 TSF:MSG:READ,0-0-136,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    4228 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
                                    4236 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                    4244 TSF:MSG:SEND,136-136-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                    4251 MCO:REG:REQ
                                    4254 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                    4261 TSF:MSG:READ,0-0-136,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                    4267 MCO:PIM:NODE REG=1
                                    4269 MCO:BGN:STP
                                    4271 MCO:BGN:INIT OK,TSP=1
                                    22720 TSF:MSG:READ,0-0-136,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                    22724 TSF:MSG:ACK REQ
                                    22737 TSF:MSG:SEND,136-136-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                                    31295 TSF:MSG:READ,0-0-136,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                    31299 TSF:MSG:ACK REQ
                                    31337 !TSF:MSG:SEND,136-136-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
                                      The last you got was a NACK btw. Have you tried a different controller like domoticz or MyController? Also remember to check your logs on https://www.mysensors.org/build/parser if you meed help decoding it
                                        L
                                        L
                                        ludoarchi
                                        @gohan i think the nack came when i unplleged the node but i will try again.
                                        there is no nack in the V1log
                                        i would like to try myscontroler but i m not able to start with it ... i ve configured the COM but nothing happened ... i don't find How To for it 😕
                                        i also try Double State Relay code V2 and it s the same think ... no statue change
                                          I am talking about MyController, not MySController
