  3. Weather Station with Scene Activator!!!
51 Posts 3 Posters 35.5k Views 3 Watching
  • korttomaK korttoma
    You are stil not giving HTtemp any value!
    C
    C
    cleight
    wrote on last edited by cleight
    #41
    @korttoma Can you elaborate on HTTemp not getting any value? I am not following what HTTemp should be either changed to or how to give it value.
    Here is a snippet of the debug window:
    Indoor Temp:20F
    Hot Tub:0Fsend: 11-11-0-0 s=255,c=3,t=1,pt=0,l=0,st=ok:
    read: 0-0-11 s=255,c=3,t=1,pt=0,l=10:1423665003
    Time value received:
    1423665003
    • korttomaK
      korttomaK
      korttoma
      Try replacing the last section with this:
      local HTTemp = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 105)
      luup.sleep(750)
      • Tomas
      C 1 Reply Last reply
        luup.sleep(750)
        C
        C
        cleight
        I tried this luup code and get the same results, at this point I have to believe it is an issue in my sketch as I have pushed a known working device to 105, VAR_4 and it isn't working either.
        • C cleight
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          wrote on last edited by BulldogLowell
          #44
          @cleight
          check your return with the equivalent http command in this format in your browser:
          http://ip_address:3480/data_request?id=variableget&DeviceNum=98&serviceId=urn:upnp-micasaverde-com:serviceId:TemperatureSensor1&Variable=CurrentTemperature
          just replace ip_address with your vera's IP address...
          look here
            @cleight
            look here
            C
            C
            cleight
            @BulldogLowell Thanks for this information this helped me to get the variables I needed to pull the alarm status, I also fixed the above issue with not being able to pull the Temperature from the device I was trying to. Once I tweak my code and adjust the display the way I like I will post the final sketch and a video.
            One more thing how easy would it be to have semi-static data, like the temp or time in one corner of the screen while it is cycling through all the screens?
            • C cleight
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @cleight
              like this?
              link text
                @cleight
                like this?
                link text
                C
                C
                cleight
                @BulldogLowell yes like that example, I posted on you other thread a week or so ago. I will see if I can put my current sketch and parts of that one together to get it how I want.
                • C cleight
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @cleight
                  I have it all in here, if you are patient enough to get through all this...
                  look at the centerString() function to help you center your weather conditions... you can ignore cleanString() cuz MySensors handles spaces in the strings... my Ethernet version needs to handle spaces differently.
                  look at updateLCD() and its called functions.
                  let me know if you have questions... I'm going to post this project later, though not strictly a MySensors implementation. ;)
                   Vera Auxilliary Controller a.k.a. Arduino/Vera Ethernet Device
                   December, 2014
                   Version .98
                   This sketch features the following:
                   * With the device's own website it allows you to send the device a message along with a visual or sound indicator
                   * Control LCD backlight brightness
                   * Control led (relay)
                   * Control your alarm state or lights or execute scenes...
                   * Control attached Relay
                   * Processes and displays "Vital" data from Vera like the Weather, Alarm State
                   * Reliably runs on an UNO but very expandable if you want to use a Mega instead
                   * Displays Indoor Temp and Humidity using DHT sensor
                   * Displays unread email count
                   INSTRUCTIONS:
                  HARDWARE:
                   * Enter your Vera's IP address where indicated
                   * Attach a 20x4 LCD display using I2C, remove the jumper from the backlight led and connect it to DIMMER_PIN (pwm pin)
                   * Connect DHT11 to Vcc, ground and DHT_SENSOR_PIN
                   * Connect optional Pushbuttons to your ACTION pins
                   * That's IT!!!
                   Software:
                   * Scroll down this sketch and enter your preferences of mac and IP addresses, pinouts, etc.
                   * There are multiple debug serial prints that can be monitored to assure that it is operating properly.  to enable DEBUG printing, uncomment accordingly
                   * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
                   * Add virtual switches to your Vera by following instructions here:http://faq.mios.com/content/2/40/en/how-to-create-virtual-device.html
                   copyright (c) by Jim Brower (BulldogLowell@gmail.com)
                  #include <Wire.h>
                  #include <EEPROM.h>
                  //#include <SD.h>  // you will need a MEGA for this, if you want to really expand the web UI
                  #include <Ethernet.h>
                  #include <EthernetUdp.h>
                  #include <utility/w5100.h>
                  #include <Time.h>
                  #include <Timezone.h>
                  #include "DHT.h"
                  // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<  Setup Area
                  //#define DEBUG_ON   // <<<<<<<< Comment out getNTPtime(); in loop to get this to fit on an UNO for debug, otherwise debug on a MEGA
                  //#define USE_DHCP   // <<<<<<<< Uncomment here for DHCP but uses more than 3kBytes, so warm up your MEGA it is too big for your UNO
                  #define DIMMER_PIN 6                // available PWM capable pin
                  #define DHT_SENSOR_PIN 7            // Thermometer-Hygrometer
                  #define RELAY_PIN 8                 // Relay control output
                  #define DISPLAY_UPDATE_TIME 3000UL  // 3.0 seconds seems OK
                  #define NUMBER_OF_MESSAGE_TYPES 17  // Kinds of transmissions from Vera/Internet
                  #define TONE_PIN 6                  // If you want Audio alerts
                  #define NUMBER_OF_ACTION_BUTTONS 5  // your device can control scenes, devices, etc Vera-side
                  #ifdef  DEBUG_ON
                  #define DEBUG_PRINT(x)   Serial.print(x)
                  #define SERIAL_START(x)  Serial.begin(x)
                  #else
                  typedef enum{
                    LCD_WIND, LCD_TIME, LCD_ALARM_STATUS, LCD_GARAGE, LCD_GUEST_GARAGE, LCD_IP_ADDRESS, LCD_TEMPERATURE, LCD_AC_SETPOINT, LCD_OUTSIDE_TEMP, LCD_WEATHER, LCD_FORECAST, LCD_MESSAGE, LCD_HI_LOW, LCD_EMAIL}
                  lcdState;
                  lcdState state = LCD_TIME;  // display start on Time
                  //File webFile;
                  char *messagePtr;
                  const char *messageType[NUMBER_OF_MESSAGE_TYPES] = {
                    "?ledStatus=", "?alarmState=", "?garageState=", "?guestGarageState=", "?weatherCondition=", "?outsideTemp=", "?outsideHumid=", "?airconSetpoint=", "?weatherForecast=", "?messageData=", "?todayHigh=", "?todayLow=", "?windSpeed=", "?windDirection=", "?relayState=", "?brightLevel=", "?emailCount="};
                  boolean messageFlag = false;
                  unsigned long timerStart;
                  unsigned long timerDuration;
                  int signal = 0;
                  boolean lightOn;
                  boolean relayState;
                  boolean garageOpen = false;
                  boolean guestGarageOpen = false;
                  char customMessage [30];
                  char weatherCondition[30] = {
                    "  Not Yet Reported"};
                  char weatherForecast[30] = {
                  int outdoorTemp = -99;
                  int outdoorHumid = -99;
                  int todayHigh = -99;
                  int todayLow = -99;
                  int airconSetpoint = 78;
                  int alarmArmed = -1;
                  int windSpeed = 99;
                  char windDirection[6] = {
                    "ZZZ"};
                  char myCharBuffer[30];
                  byte brightLevel = 0;
                  byte oldBrightLevel;
                  int emailCount = -1;
                  byte buttonPin[NUMBER_OF_ACTION_BUTTONS] = {
                    4, 5, A0, A1, A2};
                  byte lastButtonState[4];
                  DHT dht;
                  LiquidCrystal_I2C lcd(0x27, 20,4);
                  uint8_t clock[8] = {
                    0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // I'm-fetching-time indicator for LCD display
                  EthernetUDP Udp;
                  EthernetServer server(80);
                  uint8_t mac[] = {
                    0xDE, 0xDE, 0xDE, 0xDE, 0xDE, 0xDE }; //<<<<<<<<<<<<<<< Select your arduino's mac address
                  IPAddress ip(192,168,1,50); // <<<<<<<<<<<<<<<<<<<<<<<<<< Select your arduino's IP address if not using DHCP
                  unsigned int localPort = 8888;
                  IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
                  const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
                  byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
                  byte socketStat[MAX_SOCK_NUM];
                  char myString[100];
                  byte locator = 0;
                  EthernetClient client;
                  byte veraServer[] = {
                    192,168,1,59 }; //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Vera's IP Address
                  const char *dayOfWeek[] = {
                    "       Sunday","       Monday", "      Tuesday", "     Wednesday", "      Thursday", "       Friday", "      Saturday"};
                  const char *monthString[] = {
                    "NULL", "January", "February", "March", "April", "May", "June", "July", "August","September", "October", "November", "December"};
                  TimeChangeRule usEDT = {
                    "EDT", Second, Sun, Mar, 2, -240};  //Eastern Daylight Time = UTC - 4 hours
                  TimeChangeRule usEST = {
                    "EST", First, Sun, Nov, 2, -300};   //Eastern Standard Time = UTC - 5 hours
                  Timezone usET(usEDT, usEST);
                  TimeChangeRule *tcr;
                    SERIAL_START(9600);
                    lightOn = EEPROM.read(0);
                    pinMode(RELAY_PIN, OUTPUT);
                    pinMode(DIMMER_PIN, OUTPUT);
                    digitalWrite(RELAY_PIN, relayState? HIGH : LOW);
                    for (byte i = 0; i < 4; i++)
                      pinMode(buttonPin[i], INPUT_PULLUP);
                    dht.setup(DHT_SENSOR_PIN);
                  #ifdef USE_DHCP
                    DEBUG_PRINTLN(F("configuring e-net"));
                    if (Ethernet.begin(mac) == 0) // start Ethernet and UDP
                      DEBUG_PRINTLN(F("Fail Ethernet DHCP"));
                      while(true){
                  #else
                    Ethernet.begin(mac, ip);
                    server.begin();
                    Udp.begin(localPort);
                    lcd.init();
                    lcd.clear();
                    lightOn? lcd.backlight() : lcd.noBacklight();
                    lcd.createChar(0, clock);
                    analogWrite(DIMMER_PIN,255);
                    startupSyncVera();
                    updateLCD();
                    getNTPtime();
                    webControl();
                    messageTimer();
                    for (byte i = 0; i < NUMBER_OF_ACTION_BUTTONS; i++)
                      byte buttonState = digitalRead(buttonPin[i]);
                      if (buttonState == LOW && lastButtonState[i] == HIGH)
                        buttonPress(i);
                      lastButtonState[i] = buttonState;
                  void updateLCD()
                    static unsigned long lastDisplayChangeTime;
                    if (millis() - lastDisplayChangeTime >= DISPLAY_UPDATE_TIME)
                      switch (state)
                      case LCD_TIME:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        DEBUG_PRINT(F("Time: "));
                        DEBUG_PRINT(hourFormat12());
                        DEBUG_PRINT(F(":"));
                        DEBUG_PRINT(minute());
                        DEBUG_PRINTLN(isAM() ? "a" : "p");
                        DEBUG_PRINTLN(dayOfWeek[weekday() - 1]);
                        lcd.print(dayOfWeek[weekday() - 1]);
                        displayStatus();
                        if (emailCount != -1)
                          state = LCD_EMAIL;
                        else
                          state = LCD_ALARM_STATUS;
                        break;
                      case LCD_EMAIL:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("    Email Count"));
                        DEBUG_PRINT(F("emails: "));
                        lcd.setCursor(0,2);
                        lcd.print(F("         "));
                        lcd.print(emailCount);
                        DEBUG_PRINTLN(emailCount);
                        displayStatus();
                        break;
                      case LCD_ALARM_STATUS:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("    Alarm Status"));
                        DEBUG_PRINT(F("Alm: "));
                        lcd.setCursor(0,2);
                        if (alarmArmed == 0)
                          lcd.print(F("     Not  Armed"));
                        else if (alarmArmed == 1)
                          lcd.print(F("        Armed"));
                        else
                          lcd.print(F("  Not Yet Reported"));
                        DEBUG_PRINTLN(alarmArmed ? F("Yes") : F("NO"));
                        displayStatus();
                        state = LCD_GARAGE;
                        break;
                      case LCD_GARAGE:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("    Main  Garage"));
                        DEBUG_PRINT(F("Garage: "));
                        lcd.setCursor(0,2);
                        if (garageOpen == 0)
                          lcd.print(F("       Closed"));
                        else if (garageOpen == 1)
                          lcd.print(F("        Open"));
                        else
                        DEBUG_PRINTLN(garageOpen ? F("OPEN") : F("CLOSE"));
                        displayStatus();
                        state = LCD_GUEST_GARAGE;
                        break;
                      case LCD_GUEST_GARAGE:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("    Guest Garage"));
                        DEBUG_PRINT(F("Guest: "));
                        lcd.setCursor(0,2);
                        if (guestGarageOpen == 0)
                        else if (guestGarageOpen == 1)
                        else
                        DEBUG_PRINTLN(guestGarageOpen ? F("OPEN") : F("CLOSE"));
                        displayStatus();
                        state = LCD_TEMPERATURE;
                        break;
                      case LCD_TEMPERATURE:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F(" Temperture: "));
                        DEBUG_PRINT(F("Inside Temp:"));
                        lcd.print(dht.toFahrenheit(dht.getTemperature()), 0);
                        lcd.print(char(223));
                        lcd.print(F("F"));
                        lcd.setCursor(0,2);
                        lcd.print(F("   Humidity: "));
                        lcd.print(dht.getHumidity(), 0);
                        DEBUG_PRINT(F("Humidity:"));
                        DEBUG_PRINTLN(dht.getHumidity());
                        lcd.print(F("%"));
                        displayStatus();
                        state = LCD_AC_SETPOINT;
                        break;
                      case LCD_AC_SETPOINT:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("    A/C Setpoint"));
                        lcd.setCursor(0,2);
                        lcd.print(F("        "));
                        lcd.print(airconSetpoint);
                        lcd.print(F("F"));
                        DEBUG_PRINT(F("A/C setpoint:"));
                        DEBUG_PRINTLN(airconSetpoint);
                        displayStatus();
                        state = LCD_OUTSIDE_TEMP;
                        break;
                      case LCD_OUTSIDE_TEMP:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F(" Outdoor Temp:"));
                        DEBUG_PRINT(F("Ext. Temp:"));
                        lcd.print(outdoorTemp);
                        lcd.print(F("F"));
                        DEBUG_PRINTLN(outdoorTemp);
                        lcd.setCursor(0,2);
                        lcd.print(F("     Humidity:"));
                        lcd.print (outdoorHumid);
                        lcd.print(F("%"));
                        DEBUG_PRINTLN(outdoorHumid);
                        displayStatus();
                        state = LCD_WEATHER;
                        break;
                      case LCD_WEATHER:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("  Today's  Weather"));
                        DEBUG_PRINT(F("Weather: "));
                        lcd.setCursor(0,2);
                        lcd.print(weatherCondition);
                        DEBUG_PRINTLN(weatherCondition);
                        displayStatus();
                        state = LCD_HI_LOW;
                        break;
                      case LCD_HI_LOW:
                        fastClearLCD();
                        DEBUG_PRINTLN(F("Weather Hi/Lows"));
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("Today's High: "));
                        lcd.print(todayHigh);
                        lcd.print(F("F"));
                        lcd.setCursor(0,2);
                        lcd.print(F("         Low: "));
                        lcd.print (todayLow);
                        lcd.print(F("F"));
                        displayStatus();
                        if (windSpeed > 2)
                          state = LCD_WIND;
                        else
                          state = LCD_FORECAST;
                          DEBUG_PRINTLN(F("wind too light to report..."));
                        break;
                      case LCD_WIND:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("   Winds  Gusting"));
                        DEBUG_PRINT(F("Winds: "));
                        DEBUG_PRINTLN(windSpeed);
                        lcd.print(F(" "));
                        lcd.setCursor(1,2);
                        if (windSpeed < 10) lcd.print(F(" "));
                        lcd.print(windSpeed);
                        lcd.print(F("mph from the "));
                        lcd.print(windDirection);
                        displayStatus();
                        break;
                      case LCD_FORECAST:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("      Tomorrow"));
                        DEBUG_PRINT(F("Forecast: "));
                        lcd.setCursor(0,2);
                        lcd.print(weatherForecast);
                        DEBUG_PRINTLN(weatherForecast);
                        displayStatus();
                        if (messageFlag)
                          state = LCD_MESSAGE;
                        else
                          state = LCD_IP_ADDRESS;
                        break;
                      case LCD_MESSAGE:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        if (signal == 2 && brightLevel > 0)
                          for (int i = 0; i < 20; i++)
                            digitalWrite(DIMMER_PIN, HIGH);
                            delay(50);
                            digitalWrite(DIMMER_PIN,LOW);
                            delay(50);
                          analogWrite(DIMMER_PIN,brightLevel);
                        else if (signal == 1 && lightOn == 1)
                          beepTone();
                        if (signal != 0)
                          lastDisplayChangeTime - millis();  // give the message back the time lost in the flash/blinking
                        lcd.setCursor(0,1);
                        lcd.print(F("  *** Message ***"));
                        DEBUG_PRINT(F("Message: "));
                        lcd.setCursor(0,2);
                        lcd.print(customMessage);
                        DEBUG_PRINTLN(customMessage);
                        displayStatus();
                        break;
                      case LCD_IP_ADDRESS:
                        fastClearLCD();
                        lcd.setCursor(0,0);
                        timeDate();
                        lcd.setCursor(0,1);
                        lcd.print(F("     IP Address"));
                        DEBUG_PRINT(F("IP Address: "));
                        lcd.setCursor(0,2);
                        lcd.print("    ");
                        for (byte thisByte = 0; thisByte < 4; thisByte++) // print the value of each byte of the IP address:
                          lcd.print(Ethernet.localIP()[thisByte], DEC);
                          if (thisByte < 3) lcd.print(".");
                  #ifdef DEBUG_ON
                          Serial.print(Ethernet.localIP()[thisByte], DEC);
                          if (thisByte < 3) DEBUG_PRINT(".");
                          else DEBUG_PRINTLN(F(" "));
                        lcd.print(F(" "));
                        displayStatus();
                        state = LCD_TIME;
                        break;
                      lastDisplayChangeTime = millis();
                      DEBUG_PRINT(F("free ram:"));
                      DEBUG_PRINTLN(freeRam());
                  void sendNTPpacket(IPAddress& address) // Send an NTP request to the time server at the given address
                    memset(packetBuffer, 0, NTP_PACKET_SIZE);
                    packetBuffer[0]  = 0b11100011;   // LI, Version, Mode
                    packetBuffer[1]  = 0;            // Stratum, or type of clock
                    packetBuffer[2]  = 6;            // Polling Interval
                    packetBuffer[3]  = 0xEC;         // Peer Clock Precision
                    packetBuffer[12] = 49;
                    packetBuffer[13] = 0x4E;
                    packetBuffer[14] = 49;
                    packetBuffer[15] = 52;
                    Udp.beginPacket(address, 123);  //NTP requests are to port 123
                    Udp.write(packetBuffer,NTP_PACKET_SIZE);
                    Udp.endPacket();
                  void receiveTime(unsigned long newTime)
                    DEBUG_PRINT(F("Time value received: "));
                    int lastSecond = second();
                    int lastMinute = minute();
                    int lastHour = hour();
                    setTime(newTime);
                    if ((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour))
                      DEBUG_PRINTLN(F("Clock updated...."));
                      DEBUG_PRINT(F("Sensor's time currently set to:"));
                      DEBUG_PRINT(hourFormat12() < 10? F(" 0") : F(" "));
                      DEBUG_PRINT(minute() < 10? F(":0") : F(":"));
                      DEBUG_PRINTLN(isAM()? F("am") : F("pm"));
                      DEBUG_PRINT(month());
                      DEBUG_PRINT(F("/"));
                      DEBUG_PRINT(day());
                      DEBUG_PRINTLN(year());
                      //DEBUG_PRINTLN(dayOfWeek[weekday() - 1()]);
                    lcd.setCursor(19,0);
                    lcd.print(F(" "));
                  void getNTPtime()
                    static unsigned long lastUpdateTime;
                    const unsigned long interval = 60000UL;
                    if ((millis() - lastUpdateTime >= interval))
                      lcd.write(0);
                      sendNTPpacket(timeServer); // send an NTP packet to a time server
                      delay(1000);
                      if (Udp.parsePacket())
                        Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
                        unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
                        unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
                        unsigned long secsSince1900 = highWord << 16 | lowWord;
                        DEBUG_PRINT(F("Seconds since Jan 1 1900 = "));
                        DEBUG_PRINTLN(secsSince1900);
                        DEBUG_PRINT(F("Unix time = "));
                        time_t utcEpoch = secsSince1900 - 2208988800UL;  //seventyYears = 2208988800UL
                        DEBUG_PRINTLN(utcEpoch);
                        receiveTime(usET.toLocal(utcEpoch, &tcr) + 2);   //about 2 seconds to call for time
                        lastUpdateTime += interval;
                  void webControl()
                    EthernetClient client = server.available();
                    if (client)
                      while (client.connected())
                        if (client.available())
                          char c = client.read();
                          if (locator < 100)
                            myString[locator] = c;
                            locator++;
                            myString[locator] = '\0';
                          if (c == '\n') //if HTTP request has ended
                            DEBUG_PRINTLN(F("MyString ="));
                            DEBUG_PRINTLN(myString);
                            // Send a full website with controls functions and handles message input...
                            client.println(F(
                              "<html>"
                              "<head>"
                              "<title>Vera Helper</title>"
                              "</head>"
                              "<body>"
                              "<div align=\"center\">"
                              "<H2>Arduino Auxilliary Controller</H2>"
                              "<H3>for Vera</H3>"
                              "<hr>"
                              "<H2><font color=\"green\">Comfort Settings</H2>"
                              "<H4><font color=\"blue\">Temperature</font>"
                              "<font color=\"red\">"));
                            client.println(dht.toFahrenheit(dht.getTemperature()), 1);
                            client.println(F("</font>"
                              "<font color=\"blue\">F</font>"
                              "<br />"
                              "<H4><font color=\"blue\">Humidity</font>"
                            client.println(dht.getHumidity(), 1);
                              "<font color=\"blue\">%</font>"
                              "<H4><font color=\"midnightBlue\">AirConditioning Setpoint</font>"
                            client.println(airconSetpoint);
                              "<br />"
                              "<hr>"
                              "<h2>"
                              "Send Message<br>"
                              "<form>"
                              "<input type=\"text\" size=\"20\" name= \"messageData\" value=\"Enter message here\">"
                              "<select name=\"time\">"
                              "<option value=\"5\">5min</option>"
                              "<option value=\"15\">15min</option>"
                              "<option selected value=\"30\">30min</option>"
                              "<option value=\"60\">60min</option>"
                              "<option value=\"720\">12hrs</option>"
                              "<option value=\"1440\">24hrs</option>"
                              "</select>"
                              "<h4>"
                              "<input type=\"radio\" name=\"signal\" value=\"2\"> Flash<br>"
                              "<input type=\"radio\" name=\"signal\" value=\"1\"> Tone <br>"
                              "<input type=\"radio\" name=\"signal\" value=\"0\" checked> None</h4>"
                              "<input type=\"submit\" onclick=\"alert('Message Sent!')\" value=\"Send\"> <input type=\"reset\" value=\"Reset\"></h2>"
                              "</form>"
                              "<hr>"
                              "<a href=\"/?ledStatus=1?\"\">Turn On LED Backlight</a>    "
                              "<a href=\"/?ledStatus=0?\"\">Turn Off LED Backlight</a>"
                              "<br />"
                              "<a href=\"/?relayState=1?\"\">Turn On Outlet</a>    "
                              "<a href=\"/?relayState=0?\"\">Turn Off Outlet</a><br /> "
                              "<br />"
                              "<a href=\"/?airconSetpoint="));
                            if (airconSetpoint > 70) client.println(airconSetpoint - 1);
                            else client.println(airconSetpoint);
                            client.println(F("?\"\">Lower Air Conditioning Setpoint</a><br /> "
                              "<br />"
                              "<div style=\"background-color:LightSlateGray; color:black; margin:20px; padding:20px;\">"
                              "<h3>Jim Brower</h3>"
                              "<h5>&copy; copyright 2014</h5>"
                              "<h5><a href=\"mailto:bulldoglowell@gmail.com?subject=Arduino/Vera Home Controller\">"
                              "Send Email</a><h5>"
                              "</div>"
                              "</body>"
                              "</html>"));
                            delay(1);
                            client.stop();
                            // let's sort out that HTTP request...
                            for (byte i = 0; i < NUMBER_OF_MESSAGE_TYPES; i++)
                              messagePtr = strstr(myString, messageType[i]); // we need a global variable here
                              if (messagePtr)
                                DEBUG_PRINT(F("network msg..."));
                                DEBUG_PRINTLN(messageType[i]);
                                processMessage(i);
                                break;
                            myString[0] = '\0'; //clearing string for next read
                            locator = 0;
                  #ifdef DEBUG_ON
                  int freeRam ()
                    extern int __heap_start, *__brkval;
                    int v;
                    return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
                  void ShowSockStatus()
                    for (int i = 0; i < MAX_SOCK_NUM; i++)
                      DEBUG_PRINT(F("Socket#"));
                      DEBUG_PRINT(i);
                      uint8_t s = W5100.readSnSR(i);
                      socketStat[i] = s;
                      DEBUG_PRINT(F(":0x"));
                  #ifdef DEBUG_ON
                      Serial.print(s,16);
                      DEBUG_PRINT(F(" "));
                      DEBUG_PRINT(W5100.readSnPORT(i));
                      DEBUG_PRINT(F(" D:"));
                      uint8_t dip[4];
                      W5100.readSnDIPR(i, dip);
                  #ifdef DEBUG_ON
                      for (int j=0; j<4; j++)
                        Serial.print(dip[j],10);
                        if (j<3) Serial.print(".");
                      DEBUG_PRINT(F("("));
                      DEBUG_PRINT(W5100.readSnDPORT(i));
                      DEBUG_PRINT(F(")"));
                  void processMessage(byte httpMessage)
                    switch (httpMessage)
                    case 0: // "?ledStatus="
                      lightOn = parseNumber(httpMessage) ? 1 : 0;
                      //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? lightOn = 0 : lightOn = 1;
                      EEPROM.write(0, lightOn? 0xFF : 0x00);
                      if (lightOn) lcd.backlight();
                      else lcd.noBacklight();
                      DEBUG_PRINT(F("LCD Backlight: "));
                      DEBUG_PRINTLN(lightOn ? F("ON") : F("OFF"));
                      break;
                    case 1: // "?alarmState="
                      alarmArmed = parseNumber(httpMessage) ? 1 : 0;
                      DEBUG_PRINTLN(alarmArmed ? F("Alarm is ON") : F("Alarm is OFF"));
                      break;
                    case 2: // "?garageState="
                      garageOpen = parseNumber(httpMessage) ? 1 : 0;
                      DEBUG_PRINTLN(garageOpen ? F("Garage is Open") : F("garage is Closed"));
                      break;
                    case 3: // "?guestGarageState="
                      guestGarageOpen = parseNumber(httpMessage) ? 1 : 0;
                      DEBUG_PRINTLN(guestGarageOpen ? F("Guest garage is Open") : F("Guest garage is Closed"));
                      break;
                    case 4: // "?weatherCondition="  // Parse Weather
                        strncpy(weatherCondition, parseString(httpMessage), sizeof weatherCondition);
                        if (strstr(weatherCondition, "%20"))
                          strncpy(weatherCondition, cleanString(weatherCondition, "%20"), sizeof weatherCondition);
                        if (strlen(weatherCondition) < 19)
                          strncpy(weatherCondition, centerString(weatherCondition), sizeof weatherCondition);
                      break;
                    case 5: // "?outsideTemp="  // Parse Outside Temperature
                      outdoorTemp = parseNumber(httpMessage);
                      break;
                    case 6: // "?outsideHumid=" // Parse Outside Humidity
                      outdoorHumid = parseNumber(httpMessage);
                      break;
                    case 7: // "?airconSetpoint="  // Parse A/C Setpoint
                      airconSetpoint = parseNumber(httpMessage);
                      break;
                    case 8: // "?weatherForecast="  // Parse the weather forecast
                        strncpy(weatherForecast, parseString(httpMessage), sizeof weatherForecast);
                        if (strstr(weatherForecast, "+"))
                          strncpy(weatherForecast, cleanString(weatherForecast, "+"), sizeof weatherForecast);
                        if (strlen(weatherForecast) < 19)
                          strncpy(weatherForecast, centerString(weatherForecast), sizeof weatherForecast);
                      break;
                    case 9: //"?messageData="  // Parse display message
                        strncpy(customMessage, parseString(httpMessage), sizeof customMessage);
                        if (strstr(customMessage, "+"))
                          strncpy(customMessage, cleanString(customMessage, "+"), sizeof customMessage);
                        if (strlen(customMessage) < 19)
                          strncpy(customMessage, centerString(customMessage), sizeof customMessage);
                        Serial.println(myString);
                        if (strstr(myString, "&time="))
                          DEBUG_PRINTLN(F("Got length marker..."));
                          char *timePointer = (strstr(myString, "&time="));
                          timerDuration = atoi(timePointer + 6);
                          timerStart = millis();
                          DEBUG_PRINT(F("message length:"));
                          DEBUG_PRINTLN(timerDuration);
                        else
                          DEBUG_PRINTLN(F("No length marker..."));
                          timerDuration = 5;
                        if (strstr(myString, "&signal="))
                          DEBUG_PRINTLN(F("Got signal..."));
                          char *signalPointer = (strstr(myString, "&signal="));
                          signal = atoi(signalPointer + 8);
                          DEBUG_PRINT(F("Signal ="));
                          DEBUG_PRINTLN(signal);
                        else
                          DEBUG_PRINTLN(F("No signal..."));
                          timerDuration = 5;
                        messageFlag = true;
                      break;
                    case 10: // "?todayHigh="  // Parse Outside High Temperature
                      todayHigh = parseNumber(httpMessage);
                      break;
                    case 11: // "?todayLow="  // Parse Outside Low Temperature
                      todayLow = parseNumber(httpMessage);
                      break;
                    case 12: // "?windSpeed="  // Parse Outside Low Temperature
                      windSpeed = parseNumber(httpMessage);
                      break;
                    case 13: // "?windDirection"  // Parse Outside Low Temperature
                      strncpy(windDirection, parseString(httpMessage), sizeof windDirection);
                      break;
                    case 14:  //  "?relayState=" // Get the state of the relay
                      relayState = parseNumber(httpMessage) ? 1 : 0;
                      //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? relayState = 0 : relayState = 1;
                      //EEPROM.write(1, relayState ? 0xFF : 0x00);
                      digitalWrite(RELAY_PIN, relayState ? HIGH : LOW);
                      DEBUG_PRINT(F("Relay Status: "));
                      DEBUG_PRINTLN(relayState ? F("ON") : F("OFF"));
                      break;
                    case 15:  //  "?brightLevel=" // Get the brightness of the LED
                      brightLevel = parseNumber(httpMessage);
                      brightLevel = map(brightLevel, 0, 100, 0, 255);
                      DEBUG_PRINT(F("Brite:"));
                      DEBUG_PRINTLN(brightLevel);
                      if (brightLevel != oldBrightLevel)
                        analogWrite(DIMMER_PIN, brightLevel);
                      oldBrightLevel = brightLevel;
                      break;
                    case 16: // "?emailCount"  // Parse email count
                      emailCount = parseNumber(httpMessage);
                      break;
                    default:
                        //Nothing to do here...
                  void buttonPress(int buttonID)
                    DEBUG_PRINTLN(F("buttonPress"));
                    ShowSockStatus();
                    if (client.connect(veraServer, 3480)) //starts client connection, checks for connection
                      DEBUG_PRINTLN(F("connected"));
                      switch (buttonID)
                      case 0:  // adjust backlight brightness down
                        int brite = brightLevel;
                        brite -= 25;
                        if (brite < 0) brite = 0;
                        client.print(F("GET /data_request?"
                          "id=action&output_format=xml"
                          "&DeviceNum=111"
                          "&serviceId=urn:upnp-org:"
                          "serviceId:Dimmer1"
                          "&action=SetTarget"
                          "&newTargetValue="));
                        client.println(brite);
                        client.println(F(" HTTP/1.1"
                          "Connection: close"));  //close 1.1 persistent connection
                        client.println(); //end of get request
                        delay(1);
                        client.stop();
                        break;
                      case 1:  // adjust backlight brightness up
                        brite += 25;
                        if (brite > 255) brite = 255;
                          "&DeviceNum=111"
                          "serviceId:Dimmer1"
                          "&action=SetTarget"
                        delay(1);
                        client.stop();
                        break;
                      case 2:  // Toggle Alarm
                          "&DeviceNum=112" /* <<<<< Set Vera Device Number for Alarm */
                          "serviceId:SwitchPower1"
                          "&action=SetTarget"
                        client.print(relayState ? F("0") : F("1"));
                        delay(1);
                        client.stop();
                        break;
                      case 3:  // run lights out scene  //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                          "&action=SetTarget"
                        delay(1);
                        client.stop();
                        break;
                      case 4:  // Lower Air Conditioning //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                          "&DeviceNum=112" /* <<<<< Set Vera Device Number for A/C Control */
                          "&action=SetTarget"
                        if (airconSetpoint > 72) client.print(airconSetpoint - 1);
                        else client.print(airconSetpoint - 1);
                        delay(1);
                        client.stop();
                        break;
                      default:
                          //nothing to do here...
                  char *parseString(byte messageNumber)
                    int textLocation = (messagePtr - myString + strlen(messageType[messageNumber]));
                    myCharBuffer[0] = '\0';
                    for (byte i = 0; i < 30; i++) // we have room to display only 20 chars, but lets parse 30.
                      if (myString[textLocation + i] != '&')
                        myCharBuffer[i] = myString[textLocation + i];
                        DEBUG_PRINTLN(myCharBuffer[i]);
                      else
                        DEBUG_PRINTLN(F("got & marker"));
                        myCharBuffer[i] = '\0';
                        break;
                    DEBUG_PRINTLN(myCharBuffer);
                    return myCharBuffer;
                  char *cleanString(char *targetString, char *searchString)
                    while(strstr(targetString, searchString))
                      char* stringChunk;
                      stringChunk = strstr(targetString, searchString);
                      targetString[stringChunk - targetString] = '\0';
                      strncpy(myCharBuffer, targetString, sizeof myCharBuffer);
                      strncat(myCharBuffer, " ", sizeof myCharBuffer);
                      strncat(myCharBuffer, stringChunk + strlen(searchString), sizeof myCharBuffer);
                      strncpy(targetString, myCharBuffer, sizeof myCharBuffer);
                  int parseNumber(byte msgNum)
                    if (strstr(myString, messageType[msgNum]))
                      char *messagePointer;
                      messagePointer = strtok(myString, "=");
                      messagePointer = strtok(NULL, "?");
                      int extractedNumber = atoi(messagePointer);
                      return extractedNumber;
                    else
                      DEBUG_PRINTLN(F("Fail parseNumber..."));
                      return -99;
                  char *centerString(char *stringToCenter)
                    char centerSpacing[30];
                    for (byte i = 0; i < ((20 - strlen(myCharBuffer)) / 2); i++)
                      centerSpacing[i] = ' ';
                      centerSpacing[i+1] = '\0';
                    strncat(centerSpacing, myCharBuffer, sizeof centerSpacing);
                    strncpy(myCharBuffer, centerSpacing, sizeof myCharBuffer);
                  void messageTimer()
                    if (millis() - timerStart >= timerDuration * 60000UL)
                      signal = 0;
                  void fastClearLCD()
                    for (int i = 1; i < 3; i++)
                      lcd.setCursor(0,i);
                      for (int j = 0; j < 20; j++)
                        lcd.print(F(" "));
                  void timeDate()
                    if (hourFormat12() < 10) lcd.print(F(" "));
                    lcd.print(hourFormat12());
                    lcd.print(minute() < 10 ? F(":0") : F(":"));
                    lcd.print(minute());
                    lcd.print(isAM() ? "am" : "pm");
                    lcd.setCursor(9,0);
                    if (month() < 10) lcd.print(F(" "));
                    lcd.print(month());
                    lcd.print(day() < 10 ? F("/0") : F("/"));
                    lcd.print(day());
                    lcd.print(F("/"));
                    lcd.print(year());
                  void displayStatus()
                    lcd.setCursor(0,3);
                    lcd.print(emailCount < 0? 0 : emailCount);
                    if (emailCount == 1)
                      lcd.print(F(" eMail   "));
                    else
                      lcd.print(F(" eMails   "));
                    lcd.setCursor(11,3);
                    if (alarmArmed != 1)
                      lcd.print(F("Not Armed"));
                    else
                  void beepTone()
                    tone(TONE_PIN, 440, 200);
                     noTone(TONE_PIN);
                  void startupSyncVera() // RUNS A VERA SCENE ON STARTUP... Push the dimmer value from this scene
                      DEBUG_PRINTLN(F("asking for dimmer level"));
                      client.println(F("GET /data_request?id=action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=40"
                      " HTTP/1.1"));
                      client.println(F("Connection: close"));  //close 1.1 persistent connection
                      delay(1);
                      client.stop();
                    @cleight
                     December, 2014
                     Version .98
                     INSTRUCTIONS:
                    HARDWARE:
                     * That's IT!!!
                     Software:
                    #include <Wire.h>
                    #include <EEPROM.h>
                    #include <Time.h>
                    #include "DHT.h"
                    #ifdef  DEBUG_ON
                    #else
                    typedef enum{
                    lcdState;
                    //File webFile;
                    char *messagePtr;
                    int signal = 0;
                    boolean lightOn;
                    boolean relayState;
                    int todayLow = -99;
                    int windSpeed = 99;
                      "ZZZ"};
                      4, 5, A0, A1, A2};
                    DHT dht;
                    EthernetUDP Udp;
                    uint8_t mac[] = {
                    char myString[100];
                    byte locator = 0;
                      SERIAL_START(9600);
                    #ifdef USE_DHCP
                        while(true){
                    #else
                      server.begin();
                      lcd.init();
                      lcd.clear();
                      startupSyncVera();
                      updateLCD();
                      getNTPtime();
                      webControl();
                      messageTimer();
                          buttonPress(i);
                    void updateLCD()
                        switch (state)
                        case LCD_TIME:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          displayStatus();
                            state = LCD_EMAIL;
                          else
                          break;
                        case LCD_EMAIL:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          lcd.print(F("         "));
                          displayStatus();
                          break;
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          else
                          displayStatus();
                          state = LCD_GARAGE;
                          break;
                        case LCD_GARAGE:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          else
                          displayStatus();
                          break;
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          else
                          displayStatus();
                          break;
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.print(F("F"));
                          lcd.setCursor(0,2);
                          lcd.print(F("%"));
                          displayStatus();
                          break;
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          lcd.print(F("        "));
                          lcd.print(F("F"));
                          displayStatus();
                          break;
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.print(F("F"));
                          lcd.setCursor(0,2);
                          lcd.print(F("%"));
                          displayStatus();
                          break;
                        case LCD_WEATHER:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          displayStatus();
                          state = LCD_HI_LOW;
                          break;
                        case LCD_HI_LOW:
                          fastClearLCD();
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.print(F("F"));
                          lcd.setCursor(0,2);
                          lcd.print(F("F"));
                          displayStatus();
                          if (windSpeed > 2)
                            state = LCD_WIND;
                          else
                          break;
                        case LCD_WIND:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.print(F(" "));
                          lcd.setCursor(1,2);
                          displayStatus();
                          break;
                        case LCD_FORECAST:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          displayStatus();
                          if (messageFlag)
                          else
                          break;
                        case LCD_MESSAGE:
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                              delay(50);
                              delay(50);
                            beepTone();
                          if (signal != 0)
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          displayStatus();
                          break;
                          fastClearLCD();
                          lcd.setCursor(0,0);
                          timeDate();
                          lcd.setCursor(0,1);
                          lcd.setCursor(0,2);
                          lcd.print("    ");
                    #ifdef DEBUG_ON
                          lcd.print(F(" "));
                          displayStatus();
                          state = LCD_TIME;
                          break;
                      Udp.endPacket();
                      setTime(newTime);
                        DEBUG_PRINT(day());
                      lcd.print(F(" "));
                    void getNTPtime()
                        lcd.write(0);
                        delay(1000);
                    void webControl()
                      if (client)
                            if (locator < 100)
                              locator++;
                              client.println(F(
                                "<html>"
                                "<head>"
                                "</head>"
                                "<body>"
                                "<H3>for Vera</H3>"
                                "<hr>"
                                "<br />"
                                "<br />"
                                "<hr>"
                                "<h2>"
                                "Send Message<br>"
                                "<form>"
                                "</select>"
                                "<h4>"
                                "</form>"
                                "<hr>"
                                "<br />"
                                "<br />"
                                "<br />"
                                "</div>"
                                "</body>"
                                "</html>"));
                              delay(1);
                              client.stop();
                                if (messagePtr)
                                  processMessage(i);
                                  break;
                              locator = 0;
                    #ifdef DEBUG_ON
                    int freeRam ()
                      int v;
                        DEBUG_PRINT(i);
                        socketStat[i] = s;
                    #ifdef DEBUG_ON
                        Serial.print(s,16);
                        uint8_t dip[4];
                    #ifdef DEBUG_ON
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                          else
                            timerDuration = 5;
                          else
                            timerDuration = 5;
                          messageFlag = true;
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                        break;
                      default:
                      ShowSockStatus();
                        switch (buttonID)
                          brite -= 25;
                            "&DeviceNum=111"
                            "serviceId:Dimmer1"
                            "&action=SetTarget"
                          delay(1);
                          client.stop();
                          break;
                          brite += 25;
                            "&DeviceNum=111"
                            "serviceId:Dimmer1"
                            "&action=SetTarget"
                          delay(1);
                          client.stop();
                          break;
                            "&action=SetTarget"
                          delay(1);
                          client.stop();
                          break;
                            "&action=SetTarget"
                          delay(1);
                          client.stop();
                          break;
                            "&action=SetTarget"
                          delay(1);
                          client.stop();
                          break;
                        default:
                        else
                          break;
                        char* stringChunk;
                      else
                        return -99;
                    void messageTimer()
                        signal = 0;
                    void fastClearLCD()
                        lcd.setCursor(0,i);
                          lcd.print(F(" "));
                    void timeDate()
                      lcd.setCursor(9,0);
                      lcd.print(month());
                      lcd.print(day());
                      lcd.print(F("/"));
                      lcd.print(year());
                      lcd.setCursor(0,3);
                      else
                      else
                    void beepTone()
                       noTone(TONE_PIN);
                        " HTTP/1.1"));
                        delay(1);
                        client.stop();
                    C
                    C
                    cleight
                    @BulldogLowell I finally am getting somewhere with my project, however after some time working with it I have found that I would rather send data from other Arduino sensors to the LCD project directly rather than send it to Vera and then run a piece of Luup code every 15 minutes to then populate the variables the screen uses. I have looked all over the forums and cannot seem to find the right bit on information on MySensors 1.4 and how to send data from one node to the other, any assistance would be great.
                    • C cleight
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @cleight
                      I've got a vera-centric build, so I haven't messed with this in a while, but there are send( ) and request( ) functions in the API... have you explored that yet?
                      I would have the remote sensor repeat every so often (e.g. one minute) and add the that node's specifics to the incoming message callback function for the display device.
                      We should have an example of Node-to-Node communication in the examples...
                        @cleight
                        C
                        C
                        cleight
                        @BulldogLowell I agree I think it would benefit the community to have a node to node example on the site.
