  3. Weather Station with Scene Activator!!!
51 Posts 3 Posters 35.5k Views 3 Watching
  • korttomaK korttoma
    Nice job on the sketch Jim, I especially liked the idea with "#define DEBUG". There were allso some other ideas I will be stealing some day when I find time to update my sketch.
    So I guess you did not use the function by @RexBeckett then? I could not get it to work either. I'll try your suggestion with the delays.
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @korttoma
    Thanks for your help and time, you made it a lot easier! I'm trying to write the code for an audience rather than myself so I'm focused more on what I'm putting into the sketch versus just 'getting it to work.' I'm going to get that led dimming next!
    I messed around with the function but lost patience with it,,. I'll get my lua book out and tackle that one rainy day. Meanwhile, I have been using these delays without any issues (no Vera re-starts) and can probably work on shortening the delay times now that I have my Ethernet gateway working so well!!!
    best network performance ever for me since I started with MySensors :)
    I keep looking at your scene controller (and the one Henrik did) and I guess I just have to pick one to make!!
    • korttomaK
      korttomaK
      korttoma
      It was all my pleasure Jim, it is nice to have someone to exchange ideas with. I take it you mean the dimming of the backlight right? Let me know if you need some details.
      I have also put together a Ethernet GW some time ago but newer got around to take it in to use. And then there was all this about the SPI issue so I guess I need to take it on again at some point. A bit unclear if it will work with the Ethernet board I have anyway.
      • Tomas
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @korttoma
        yeah, I meant dimming the LED backlight, a nice touch to your project.
        your ethernet board uses the same Wiznet chipset, so you may want to try what was posted on the other thread. I got frustrated with my Serial gateway losing its communication with Vera.
        • C
          C
          cleight
          Hello, I am building this same thing and have used the sketch and luup code above thanks to @BulldogLowell & @korttoma!
          I am having issues though pulling a variable to send to the lcd screen via luup. I put this device under the Light Variable 4 code is at the bottom of the Lua below. This device is another mysensor that is visible in Vera so I am not sure what is wrong, any help someone could provide would be great.
          Luup code:
          local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 7)
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_1", value=temp}, 103)
          luup.sleep(750)
          local humid = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel", 10)
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_2", value=humid}, 103)
          luup.sleep(750)
          local low = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 61)
              luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_3", value=low}, 103)
           luup.sleep(750)
          local high = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 62)
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_4", value=high}, 103)
          luup.sleep(750)
          local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Condition", 6)
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_5", value=conditions}, 103)
          luup.sleep(750)
          local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Forecast.1.Condition", 59)
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_2", value=conditions}, 103)
           luup.sleep(750)
            local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
           luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 103)
            luup.sleep(750)
          Sketch: weather_station.ino
          • BulldogLowellB
            BulldogLowellB
            BulldogLowell
            luup.sleep(750)
            it looks like you are making a call for the variable "conditions" and passing "HTTemp" in the two last commands. here:
            local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98) -- you get "conditions"
            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 103) -- you set "HTTemp"
            luup.sleep(750)
            that could be it...
            C 1 Reply Last reply
              luup.sleep(750)
              luup.sleep(750)
              that could be it...
              C
              C
              cleight
              @BulldogLowell I was under the impression that the value could be named what ever you want, is that not the case? changing the value to temp should fix the issue you think?
              • C cleight
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                #38
                now I am confused.
                You are (it seems to me) retreiving a value from device 98, no?
                You are then writing that to device 103, at VAR_4... yes?
                please clarify for me.
                (reference the snippet of code in my last post)
                  now I am confused.
                  C
                  C
                  cleight
                  @BulldogLowell Thanks for pointing that out, I actually need to write VAR4 to device 105. I have made the necessary changes but still isn't working.
                   local temp = luup.variable_get("urn:upnp-   org:serviceId:TemperatureSensor1","CurrentTemperature", 7)
                  luup.sleep(750)
                   luup.sleep(750)
                   local low = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 8)
                   luup.sleep(750)
                   local high = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 9)
                   luup.sleep(750)
                   luup.sleep(750)
                   local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Forecast.1.Condition", 6)
                   luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_2", value=conditions}, 105)
                    luup.sleep(750)
                    local temp = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
                    luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 105)
                    luup.sleep(750)
                  • korttomaK
                    korttomaK
                    korttoma
                    You are stil not giving HTtemp any value!
                    • Tomas
                      C
                      C
                      cleight
                      wrote on last edited by cleight
                      #41
                      @korttoma Can you elaborate on HTTemp not getting any value? I am not following what HTTemp should be either changed to or how to give it value.
                      Here is a snippet of the debug window:
                      Indoor Temp:20F
                      Hot Tub:0Fsend: 11-11-0-0 s=255,c=3,t=1,pt=0,l=0,st=ok:
                      read: 0-0-11 s=255,c=3,t=1,pt=0,l=10:1423665003
                      Time value received:
                      1423665003
                      • korttomaK
                        korttomaK
                        korttoma
                        Try replacing the last section with this:
                        local HTTemp = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
                        luup.sleep(750)
                        • Tomas
                          luup.sleep(750)
                          C
                          C
                          cleight
                          I tried this luup code and get the same results, at this point I have to believe it is an issue in my sketch as I have pushed a known working device to 105, VAR_4 and it isn't working either.
                          • C cleight
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            #44
                            @cleight
                            check your return with the equivalent http command in this format in your browser:
                            http://ip_address:3480/data_request?id=variableget&DeviceNum=98&serviceId=urn:upnp-micasaverde-com:serviceId:TemperatureSensor1&Variable=CurrentTemperature
                            just replace ip_address with your vera's IP address...
                            look here
                              @cleight
                              look here
                              C
                              C
                              cleight
                              @BulldogLowell Thanks for this information this helped me to get the variables I needed to pull the alarm status, I also fixed the above issue with not being able to pull the Temperature from the device I was trying to. Once I tweak my code and adjust the display the way I like I will post the final sketch and a video.
                              One more thing how easy would it be to have semi-static data, like the temp or time in one corner of the screen while it is cycling through all the screens?
                              • C cleight
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @cleight
                                like this?
                                link text
                                  @cleight
                                  like this?
                                  link text
                                  C
                                  C
                                  cleight
                                  @BulldogLowell yes like that example, I posted on you other thread a week or so ago. I will see if I can put my current sketch and parts of that one together to get it how I want.
                                  • C cleight
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @cleight
                                    I have it all in here, if you are patient enough to get through all this...
                                    look at the centerString() function to help you center your weather conditions... you can ignore cleanString() cuz MySensors handles spaces in the strings... my Ethernet version needs to handle spaces differently.
                                    look at updateLCD() and its called functions.
                                    let me know if you have questions... I'm going to post this project later, though not strictly a MySensors implementation. ;)
                                     Vera Auxilliary Controller a.k.a. Arduino/Vera Ethernet Device
                                     December, 2014
                                     Version .98
                                     * With the device's own website it allows you to send the device a message along with a visual or sound indicator
                                     * Control LCD backlight brightness
                                     * Control led (relay)
                                     * Control your alarm state or lights or execute scenes...
                                     * Control attached Relay
                                     * Processes and displays "Vital" data from Vera like the Weather, Alarm State
                                     * Reliably runs on an UNO but very expandable if you want to use a Mega instead
                                     * Displays Indoor Temp and Humidity using DHT sensor
                                     * Displays unread email count
                                     INSTRUCTIONS:
                                    HARDWARE:
                                     * Enter your Vera's IP address where indicated
                                     * Attach a 20x4 LCD display using I2C, remove the jumper from the backlight led and connect it to DIMMER_PIN (pwm pin)
                                     * Connect DHT11 to Vcc, ground and DHT_SENSOR_PIN
                                     * Connect optional Pushbuttons to your ACTION pins
                                     * That's IT!!!
                                     Software:
                                     * Scroll down this sketch and enter your preferences of mac and IP addresses, pinouts, etc.
                                     * There are multiple debug serial prints that can be monitored to assure that it is operating properly.  to enable DEBUG printing, uncomment accordingly
                                     * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
                                     * Add virtual switches to your Vera by following instructions here:http://faq.mios.com/content/2/40/en/how-to-create-virtual-device.html
                                     copyright (c) by Jim Brower (BulldogLowell@gmail.com)
                                    #include <EEPROM.h>
                                    //#include <SD.h>  // you will need a MEGA for this, if you want to really expand the web UI
                                    #include <Ethernet.h>
                                    #include <EthernetUdp.h>
                                    #include <utility/w5100.h>
                                    #include <Time.h>
                                    #include <Timezone.h>
                                    #include "DHT.h"
                                    // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<  Setup Area
                                    //#define DEBUG_ON   // <<<<<<<< Comment out getNTPtime(); in loop to get this to fit on an UNO for debug, otherwise debug on a MEGA
                                    //#define USE_DHCP   // <<<<<<<< Uncomment here for DHCP but uses more than 3kBytes, so warm up your MEGA it is too big for your UNO
                                    #define DIMMER_PIN 6                // available PWM capable pin
                                    #define DHT_SENSOR_PIN 7            // Thermometer-Hygrometer
                                    #define RELAY_PIN 8                 // Relay control output
                                    #define DISPLAY_UPDATE_TIME 3000UL  // 3.0 seconds seems OK
                                    #define NUMBER_OF_MESSAGE_TYPES 17  // Kinds of transmissions from Vera/Internet
                                    #define TONE_PIN 6                  // If you want Audio alerts
                                    #define NUMBER_OF_ACTION_BUTTONS 5  // your device can control scenes, devices, etc Vera-side
                                    #ifdef  DEBUG_ON
                                    typedef enum{
                                      LCD_WIND, LCD_TIME, LCD_ALARM_STATUS, LCD_GARAGE, LCD_GUEST_GARAGE, LCD_IP_ADDRESS, LCD_TEMPERATURE, LCD_AC_SETPOINT, LCD_OUTSIDE_TEMP, LCD_WEATHER, LCD_FORECAST, LCD_MESSAGE, LCD_HI_LOW, LCD_EMAIL}
                                    lcdState;
                                    lcdState state = LCD_TIME;  // display start on Time
                                    //File webFile;
                                    char *messagePtr;
                                    const char *messageType[NUMBER_OF_MESSAGE_TYPES] = {
                                      "?ledStatus=", "?alarmState=", "?garageState=", "?guestGarageState=", "?weatherCondition=", "?outsideTemp=", "?outsideHumid=", "?airconSetpoint=", "?weatherForecast=", "?messageData=", "?todayHigh=", "?todayLow=", "?windSpeed=", "?windDirection=", "?relayState=", "?brightLevel=", "?emailCount="};
                                    boolean messageFlag = false;
                                    unsigned long timerStart;
                                    unsigned long timerDuration;
                                    int signal = 0;
                                    boolean lightOn;
                                    boolean relayState;
                                    boolean garageOpen = false;
                                    boolean guestGarageOpen = false;
                                    char customMessage [30];
                                    char weatherCondition[30] = {
                                      "  Not Yet Reported"};
                                    char weatherForecast[30] = {
                                    int outdoorTemp = -99;
                                    int outdoorHumid = -99;
                                    int todayHigh = -99;
                                    int todayLow = -99;
                                    int airconSetpoint = 78;
                                    int alarmArmed = -1;
                                    int windSpeed = 99;
                                    char windDirection[6] = {
                                      "ZZZ"};
                                    char myCharBuffer[30];
                                    byte brightLevel = 0;
                                    byte oldBrightLevel;
                                    int emailCount = -1;
                                    byte buttonPin[NUMBER_OF_ACTION_BUTTONS] = {
                                      4, 5, A0, A1, A2};
                                    byte lastButtonState[4];
                                    DHT dht;
                                    LiquidCrystal_I2C lcd(0x27, 20,4);
                                    uint8_t clock[8] = {
                                      0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // I'm-fetching-time indicator for LCD display
                                    EthernetUDP Udp;
                                    EthernetServer server(80);
                                    uint8_t mac[] = {
                                      0xDE, 0xDE, 0xDE, 0xDE, 0xDE, 0xDE }; //<<<<<<<<<<<<<<< Select your arduino's mac address
                                    IPAddress ip(192,168,1,50); // <<<<<<<<<<<<<<<<<<<<<<<<<< Select your arduino's IP address if not using DHCP
                                    unsigned int localPort = 8888;
                                    IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
                                    const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
                                    byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
                                    byte socketStat[MAX_SOCK_NUM];
                                    char myString[100];
                                    byte locator = 0;
                                    EthernetClient client;
                                    byte veraServer[] = {
                                      192,168,1,59 }; //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Vera's IP Address
                                    const char *dayOfWeek[] = {
                                      "       Sunday","       Monday", "      Tuesday", "     Wednesday", "      Thursday", "       Friday", "      Saturday"};
                                    const char *monthString[] = {
                                      "NULL", "January", "February", "March", "April", "May", "June", "July", "August","September", "October", "November", "December"};
                                    TimeChangeRule usEDT = {
                                      "EDT", Second, Sun, Mar, 2, -240};  //Eastern Daylight Time = UTC - 4 hours
                                    TimeChangeRule usEST = {
                                      "EST", First, Sun, Nov, 2, -300};   //Eastern Standard Time = UTC - 5 hours
                                    Timezone usET(usEDT, usEST);
                                    TimeChangeRule *tcr;
                                      SERIAL_START(9600);
                                      lightOn = EEPROM.read(0);
                                      pinMode(RELAY_PIN, OUTPUT);
                                      pinMode(DIMMER_PIN, OUTPUT);
                                      digitalWrite(RELAY_PIN, relayState? HIGH : LOW);
                                      for (byte i = 0; i < 4; i++)
                                        pinMode(buttonPin[i], INPUT_PULLUP);
                                      dht.setup(DHT_SENSOR_PIN);
                                    #ifdef USE_DHCP
                                      DEBUG_PRINTLN(F("configuring e-net"));
                                      if (Ethernet.begin(mac) == 0) // start Ethernet and UDP
                                        DEBUG_PRINTLN(F("Fail Ethernet DHCP"));
                                        while(true){
                                      Ethernet.begin(mac, ip);
                                      server.begin();
                                      Udp.begin(localPort);
                                      lcd.init();
                                      lcd.clear();
                                      lightOn? lcd.backlight() : lcd.noBacklight();
                                      lcd.createChar(0, clock);
                                      analogWrite(DIMMER_PIN,255);
                                      startupSyncVera();
                                      updateLCD();
                                      getNTPtime();
                                      webControl();
                                      messageTimer();
                                      for (byte i = 0; i < NUMBER_OF_ACTION_BUTTONS; i++)
                                        byte buttonState = digitalRead(buttonPin[i]);
                                        if (buttonState == LOW && lastButtonState[i] == HIGH)
                                          buttonPress(i);
                                        lastButtonState[i] = buttonState;
                                    void updateLCD()
                                      static unsigned long lastDisplayChangeTime;
                                      if (millis() - lastDisplayChangeTime >= DISPLAY_UPDATE_TIME)
                                        switch (state)
                                        case LCD_TIME:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          DEBUG_PRINT(F("Time: "));
                                          DEBUG_PRINT(hourFormat12());
                                          DEBUG_PRINT(F(":"));
                                          DEBUG_PRINT(minute());
                                          DEBUG_PRINTLN(isAM() ? "a" : "p");
                                          DEBUG_PRINTLN(dayOfWeek[weekday() - 1]);
                                          lcd.print(dayOfWeek[weekday() - 1]);
                                          displayStatus();
                                          if (emailCount != -1)
                                            state = LCD_EMAIL;
                                            state = LCD_ALARM_STATUS;
                                        case LCD_EMAIL:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("    Email Count"));
                                          DEBUG_PRINT(F("emails: "));
                                          lcd.setCursor(0,2);
                                          lcd.print(F("         "));
                                          lcd.print(emailCount);
                                          DEBUG_PRINTLN(emailCount);
                                          displayStatus();
                                        case LCD_ALARM_STATUS:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("    Alarm Status"));
                                          DEBUG_PRINT(F("Alm: "));
                                          lcd.setCursor(0,2);
                                          if (alarmArmed == 0)
                                            lcd.print(F("     Not  Armed"));
                                          else if (alarmArmed == 1)
                                            lcd.print(F("        Armed"));
                                            lcd.print(F("  Not Yet Reported"));
                                          DEBUG_PRINTLN(alarmArmed ? F("Yes") : F("NO"));
                                          displayStatus();
                                          state = LCD_GARAGE;
                                        case LCD_GARAGE:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("    Main  Garage"));
                                          DEBUG_PRINT(F("Garage: "));
                                          lcd.setCursor(0,2);
                                          if (garageOpen == 0)
                                            lcd.print(F("       Closed"));
                                          else if (garageOpen == 1)
                                            lcd.print(F("        Open"));
                                          DEBUG_PRINTLN(garageOpen ? F("OPEN") : F("CLOSE"));
                                          displayStatus();
                                          state = LCD_GUEST_GARAGE;
                                        case LCD_GUEST_GARAGE:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("    Guest Garage"));
                                          DEBUG_PRINT(F("Guest: "));
                                          lcd.setCursor(0,2);
                                          if (guestGarageOpen == 0)
                                          else if (guestGarageOpen == 1)
                                          DEBUG_PRINTLN(guestGarageOpen ? F("OPEN") : F("CLOSE"));
                                          displayStatus();
                                          state = LCD_TEMPERATURE;
                                        case LCD_TEMPERATURE:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F(" Temperture: "));
                                          DEBUG_PRINT(F("Inside Temp:"));
                                          lcd.print(dht.toFahrenheit(dht.getTemperature()), 0);
                                          lcd.print(char(223));
                                          lcd.print(F("F"));
                                          lcd.setCursor(0,2);
                                          lcd.print(F("   Humidity: "));
                                          lcd.print(dht.getHumidity(), 0);
                                          DEBUG_PRINT(F("Humidity:"));
                                          DEBUG_PRINTLN(dht.getHumidity());
                                          lcd.print(F("%"));
                                          displayStatus();
                                          state = LCD_AC_SETPOINT;
                                        case LCD_AC_SETPOINT:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("    A/C Setpoint"));
                                          lcd.setCursor(0,2);
                                          lcd.print(F("        "));
                                          lcd.print(airconSetpoint);
                                          lcd.print(F("F"));
                                          DEBUG_PRINT(F("A/C setpoint:"));
                                          DEBUG_PRINTLN(airconSetpoint);
                                          displayStatus();
                                          state = LCD_OUTSIDE_TEMP;
                                        case LCD_OUTSIDE_TEMP:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F(" Outdoor Temp:"));
                                          DEBUG_PRINT(F("Ext. Temp:"));
                                          lcd.print(outdoorTemp);
                                          lcd.print(F("F"));
                                          DEBUG_PRINTLN(outdoorTemp);
                                          lcd.setCursor(0,2);
                                          lcd.print(F("     Humidity:"));
                                          lcd.print (outdoorHumid);
                                          lcd.print(F("%"));
                                          DEBUG_PRINTLN(outdoorHumid);
                                          displayStatus();
                                          state = LCD_WEATHER;
                                        case LCD_WEATHER:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("  Today's  Weather"));
                                          DEBUG_PRINT(F("Weather: "));
                                          lcd.setCursor(0,2);
                                          lcd.print(weatherCondition);
                                          DEBUG_PRINTLN(weatherCondition);
                                          displayStatus();
                                          state = LCD_HI_LOW;
                                        case LCD_HI_LOW:
                                          fastClearLCD();
                                          DEBUG_PRINTLN(F("Weather Hi/Lows"));
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("Today's High: "));
                                          lcd.print(todayHigh);
                                          lcd.print(F("F"));
                                          lcd.setCursor(0,2);
                                          lcd.print(F("         Low: "));
                                          lcd.print (todayLow);
                                          lcd.print(F("F"));
                                          displayStatus();
                                          if (windSpeed > 2)
                                            state = LCD_WIND;
                                            state = LCD_FORECAST;
                                            DEBUG_PRINTLN(F("wind too light to report..."));
                                        case LCD_WIND:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("   Winds  Gusting"));
                                          DEBUG_PRINT(F("Winds: "));
                                          DEBUG_PRINTLN(windSpeed);
                                          lcd.print(F(" "));
                                          lcd.setCursor(1,2);
                                          if (windSpeed < 10) lcd.print(F(" "));
                                          lcd.print(windSpeed);
                                          lcd.print(F("mph from the "));
                                          lcd.print(windDirection);
                                          displayStatus();
                                        case LCD_FORECAST:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("      Tomorrow"));
                                          DEBUG_PRINT(F("Forecast: "));
                                          lcd.setCursor(0,2);
                                          lcd.print(weatherForecast);
                                          DEBUG_PRINTLN(weatherForecast);
                                          displayStatus();
                                          if (messageFlag)
                                            state = LCD_MESSAGE;
                                            state = LCD_IP_ADDRESS;
                                        case LCD_MESSAGE:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          if (signal == 2 && brightLevel > 0)
                                            for (int i = 0; i < 20; i++)
                                              digitalWrite(DIMMER_PIN, HIGH);
                                              delay(50);
                                              digitalWrite(DIMMER_PIN,LOW);
                                              delay(50);
                                            analogWrite(DIMMER_PIN,brightLevel);
                                          else if (signal == 1 && lightOn == 1)
                                            beepTone();
                                          if (signal != 0)
                                            lastDisplayChangeTime - millis();  // give the message back the time lost in the flash/blinking
                                          lcd.setCursor(0,1);
                                          lcd.print(F("  *** Message ***"));
                                          DEBUG_PRINT(F("Message: "));
                                          lcd.setCursor(0,2);
                                          lcd.print(customMessage);
                                          DEBUG_PRINTLN(customMessage);
                                          displayStatus();
                                        case LCD_IP_ADDRESS:
                                          fastClearLCD();
                                          lcd.setCursor(0,0);
                                          timeDate();
                                          lcd.setCursor(0,1);
                                          lcd.print(F("     IP Address"));
                                          DEBUG_PRINT(F("IP Address: "));
                                          lcd.setCursor(0,2);
                                          lcd.print("    ");
                                          for (byte thisByte = 0; thisByte < 4; thisByte++) // print the value of each byte of the IP address:
                                            lcd.print(Ethernet.localIP()[thisByte], DEC);
                                            if (thisByte < 3) lcd.print(".");
                                    #ifdef DEBUG_ON
                                            Serial.print(Ethernet.localIP()[thisByte], DEC);
                                            if (thisByte < 3) DEBUG_PRINT(".");
                                            else DEBUG_PRINTLN(F(" "));
                                          lcd.print(F(" "));
                                          displayStatus();
                                          state = LCD_TIME;
                                        lastDisplayChangeTime = millis();
                                        DEBUG_PRINT(F("free ram:"));
                                        DEBUG_PRINTLN(freeRam());
                                    void sendNTPpacket(IPAddress& address) // Send an NTP request to the time server at the given address
                                      memset(packetBuffer, 0, NTP_PACKET_SIZE);
                                      packetBuffer[0]  = 0b11100011;   // LI, Version, Mode
                                      packetBuffer[1]  = 0;            // Stratum, or type of clock
                                      packetBuffer[2]  = 6;            // Polling Interval
                                      packetBuffer[3]  = 0xEC;         // Peer Clock Precision
                                      packetBuffer[12] = 49;
                                      packetBuffer[13] = 0x4E;
                                      packetBuffer[14] = 49;
                                      packetBuffer[15] = 52;
                                      Udp.beginPacket(address, 123);  //NTP requests are to port 123
                                      Udp.write(packetBuffer,NTP_PACKET_SIZE);
                                      Udp.endPacket();
                                    void receiveTime(unsigned long newTime)
                                      DEBUG_PRINT(F("Time value received: "));
                                      int lastSecond = second();
                                      int lastMinute = minute();
                                      int lastHour = hour();
                                      setTime(newTime);
                                      if ((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour))
                                        DEBUG_PRINT(hourFormat12() < 10? F(" 0") : F(" "));
                                        DEBUG_PRINT(minute() < 10? F(":0") : F(":"));
                                        DEBUG_PRINTLN(isAM()? F("am") : F("pm"));
                                        DEBUG_PRINT(month());
                                        DEBUG_PRINT(F("/"));
                                        DEBUG_PRINT(day());
                                        DEBUG_PRINTLN(year());
                                        //DEBUG_PRINTLN(dayOfWeek[weekday() - 1()]);
                                      lcd.setCursor(19,0);
                                      lcd.print(F(" "));
                                    void getNTPtime()
                                      const unsigned long interval = 60000UL;
                                      if ((millis() - lastUpdateTime >= interval))
                                        lcd.write(0);
                                        sendNTPpacket(timeServer); // send an NTP packet to a time server
                                        delay(1000);
                                        if (Udp.parsePacket())
                                          Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
                                          unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
                                          unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
                                          unsigned long secsSince1900 = highWord << 16 | lowWord;
                                          DEBUG_PRINT(F("Seconds since Jan 1 1900 = "));
                                          DEBUG_PRINTLN(secsSince1900);
                                          DEBUG_PRINT(F("Unix time = "));
                                          time_t utcEpoch = secsSince1900 - 2208988800UL;  //seventyYears = 2208988800UL
                                          DEBUG_PRINTLN(utcEpoch);
                                          receiveTime(usET.toLocal(utcEpoch, &tcr) + 2);   //about 2 seconds to call for time
                                          lastUpdateTime += interval;
                                    void webControl()
                                      EthernetClient client = server.available();
                                      if (client)
                                        while (client.connected())
                                          if (client.available())
                                            char c = client.read();
                                            if (locator < 100)
                                              myString[locator] = c;
                                              locator++;
                                              myString[locator] = '\0';
                                            if (c == '\n') //if HTTP request has ended
                                              DEBUG_PRINTLN(F("MyString ="));
                                              DEBUG_PRINTLN(myString);
                                              // Send a full website with controls functions and handles message input...
                                              client.println(F(
                                                "<html>"
                                                "<head>"
                                                "<title>Vera Helper</title>"
                                                "</head>"
                                                "<body>"
                                                "<div align=\"center\">"
                                                "<H2>Arduino Auxilliary Controller</H2>"
                                                "<H3>for Vera</H3>"
                                                "<hr>"
                                                "<H2><font color=\"green\">Comfort Settings</H2>"
                                                "<H4><font color=\"blue\">Temperature</font>"
                                                "<font color=\"red\">"));
                                              client.println(dht.toFahrenheit(dht.getTemperature()), 1);
                                              client.println(F("</font>"
                                                "<font color=\"blue\">F</font>"
                                                "<br />"
                                                "<H4><font color=\"blue\">Humidity</font>"
                                              client.println(dht.getHumidity(), 1);
                                                "<font color=\"blue\">%</font>"
                                                "<H4><font color=\"midnightBlue\">AirConditioning Setpoint</font>"
                                              client.println(airconSetpoint);
                                                "<br />"
                                                "<hr>"
                                                "<h2>"
                                                "Send Message<br>"
                                                "<form>"
                                                "<input type=\"text\" size=\"20\" name= \"messageData\" value=\"Enter message here\">"
                                                "<select name=\"time\">"
                                                "<option value=\"5\">5min</option>"
                                                "<option value=\"15\">15min</option>"
                                                "<option selected value=\"30\">30min</option>"
                                                "<option value=\"60\">60min</option>"
                                                "<option value=\"720\">12hrs</option>"
                                                "<option value=\"1440\">24hrs</option>"
                                                "</select>"
                                                "<h4>"
                                                "<input type=\"radio\" name=\"signal\" value=\"2\"> Flash<br>"
                                                "<input type=\"radio\" name=\"signal\" value=\"1\"> Tone <br>"
                                                "<input type=\"radio\" name=\"signal\" value=\"0\" checked> None</h4>"
                                                "<input type=\"submit\" onclick=\"alert('Message Sent!')\" value=\"Send\"> <input type=\"reset\" value=\"Reset\"></h2>"
                                                "</form>"
                                                "<hr>"
                                                "<a href=\"/?ledStatus=1?\"\">Turn On LED Backlight</a>    "
                                                "<a href=\"/?ledStatus=0?\"\">Turn Off LED Backlight</a>"
                                                "<br />"
                                                "<a href=\"/?relayState=1?\"\">Turn On Outlet</a>    "
                                                "<a href=\"/?relayState=0?\"\">Turn Off Outlet</a><br /> "
                                                "<br />"
                                                "<a href=\"/?airconSetpoint="));
                                              if (airconSetpoint > 70) client.println(airconSetpoint - 1);
                                              else client.println(airconSetpoint);
                                              client.println(F("?\"\">Lower Air Conditioning Setpoint</a><br /> "
                                                "<br />"
                                                "<div style=\"background-color:LightSlateGray; color:black; margin:20px; padding:20px;\">"
                                                "<h3>Jim Brower</h3>"
                                                "<h5>&copy; copyright 2014</h5>"
                                                "<h5><a href=\"mailto:bulldoglowell@gmail.com?subject=Arduino/Vera Home Controller\">"
                                                "Send Email</a><h5>"
                                                "</div>"
                                                "</body>"
                                                "</html>"));
                                              delay(1);
                                              client.stop();
                                              // let's sort out that HTTP request...
                                              for (byte i = 0; i < NUMBER_OF_MESSAGE_TYPES; i++)
                                                messagePtr = strstr(myString, messageType[i]); // we need a global variable here
                                                if (messagePtr)
                                                  DEBUG_PRINT(F("network msg..."));
                                                  DEBUG_PRINTLN(messageType[i]);
                                                  processMessage(i);
                                              myString[0] = '\0'; //clearing string for next read
                                              locator = 0;
                                    #ifdef DEBUG_ON
                                    int freeRam ()
                                      extern int __heap_start, *__brkval;
                                      int v;
                                      return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
                                    void ShowSockStatus()
                                      for (int i = 0; i < MAX_SOCK_NUM; i++)
                                        DEBUG_PRINT(F("Socket#"));
                                        DEBUG_PRINT(i);
                                        uint8_t s = W5100.readSnSR(i);
                                        socketStat[i] = s;
                                        DEBUG_PRINT(F(":0x"));
                                    #ifdef DEBUG_ON
                                        Serial.print(s,16);
                                        DEBUG_PRINT(F(" "));
                                        DEBUG_PRINT(W5100.readSnPORT(i));
                                        DEBUG_PRINT(F(" D:"));
                                        uint8_t dip[4];
                                        W5100.readSnDIPR(i, dip);
                                    #ifdef DEBUG_ON
                                        for (int j=0; j<4; j++)
                                          Serial.print(dip[j],10);
                                          if (j<3) Serial.print(".");
                                        DEBUG_PRINT(F("("));
                                        DEBUG_PRINT(W5100.readSnDPORT(i));
                                        DEBUG_PRINT(F(")"));
                                    void processMessage(byte httpMessage)
                                      switch (httpMessage)
                                      case 0: // "?ledStatus="
                                        lightOn = parseNumber(httpMessage) ? 1 : 0;
                                        //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? lightOn = 0 : lightOn = 1;
                                        EEPROM.write(0, lightOn? 0xFF : 0x00);
                                        if (lightOn) lcd.backlight();
                                        else lcd.noBacklight();
                                        DEBUG_PRINT(F("LCD Backlight: "));
                                        DEBUG_PRINTLN(lightOn ? F("ON") : F("OFF"));
                                      case 1: // "?alarmState="
                                        alarmArmed = parseNumber(httpMessage) ? 1 : 0;
                                        DEBUG_PRINTLN(alarmArmed ? F("Alarm is ON") : F("Alarm is OFF"));
                                      case 2: // "?garageState="
                                        garageOpen = parseNumber(httpMessage) ? 1 : 0;
                                        DEBUG_PRINTLN(garageOpen ? F("Garage is Open") : F("garage is Closed"));
                                      case 3: // "?guestGarageState="
                                        guestGarageOpen = parseNumber(httpMessage) ? 1 : 0;
                                        DEBUG_PRINTLN(guestGarageOpen ? F("Guest garage is Open") : F("Guest garage is Closed"));
                                      case 4: // "?weatherCondition="  // Parse Weather
                                          strncpy(weatherCondition, parseString(httpMessage), sizeof weatherCondition);
                                          if (strstr(weatherCondition, "%20"))
                                            strncpy(weatherCondition, cleanString(weatherCondition, "%20"), sizeof weatherCondition);
                                          if (strlen(weatherCondition) < 19)
                                            strncpy(weatherCondition, centerString(weatherCondition), sizeof weatherCondition);
                                      case 5: // "?outsideTemp="  // Parse Outside Temperature
                                        outdoorTemp = parseNumber(httpMessage);
                                      case 6: // "?outsideHumid=" // Parse Outside Humidity
                                        outdoorHumid = parseNumber(httpMessage);
                                      case 7: // "?airconSetpoint="  // Parse A/C Setpoint
                                        airconSetpoint = parseNumber(httpMessage);
                                      case 8: // "?weatherForecast="  // Parse the weather forecast
                                          strncpy(weatherForecast, parseString(httpMessage), sizeof weatherForecast);
                                          if (strstr(weatherForecast, "+"))
                                            strncpy(weatherForecast, cleanString(weatherForecast, "+"), sizeof weatherForecast);
                                          if (strlen(weatherForecast) < 19)
                                            strncpy(weatherForecast, centerString(weatherForecast), sizeof weatherForecast);
                                      case 9: //"?messageData="  // Parse display message
                                          strncpy(customMessage, parseString(httpMessage), sizeof customMessage);
                                          if (strstr(customMessage, "+"))
                                            strncpy(customMessage, cleanString(customMessage, "+"), sizeof customMessage);
                                          if (strlen(customMessage) < 19)
                                            strncpy(customMessage, centerString(customMessage), sizeof customMessage);
                                          Serial.println(myString);
                                          if (strstr(myString, "&time="))
                                            DEBUG_PRINTLN(F("Got length marker..."));
                                            char *timePointer = (strstr(myString, "&time="));
                                            timerDuration = atoi(timePointer + 6);
                                            timerStart = millis();
                                            DEBUG_PRINT(F("message length:"));
                                            DEBUG_PRINTLN(timerDuration);
                                            DEBUG_PRINTLN(F("No length marker..."));
                                            timerDuration = 5;
                                          if (strstr(myString, "&signal="))
                                            DEBUG_PRINTLN(F("Got signal..."));
                                            char *signalPointer = (strstr(myString, "&signal="));
                                            signal = atoi(signalPointer + 8);
                                            DEBUG_PRINT(F("Signal ="));
                                            DEBUG_PRINTLN(signal);
                                            DEBUG_PRINTLN(F("No signal..."));
                                            timerDuration = 5;
                                          messageFlag = true;
                                      case 10: // "?todayHigh="  // Parse Outside High Temperature
                                        todayHigh = parseNumber(httpMessage);
                                      case 11: // "?todayLow="  // Parse Outside Low Temperature
                                        todayLow = parseNumber(httpMessage);
                                      case 12: // "?windSpeed="  // Parse Outside Low Temperature
                                        windSpeed = parseNumber(httpMessage);
                                      case 13: // "?windDirection"  // Parse Outside Low Temperature
                                        strncpy(windDirection, parseString(httpMessage), sizeof windDirection);
                                      case 14:  //  "?relayState=" // Get the state of the relay
                                        relayState = parseNumber(httpMessage) ? 1 : 0;
                                        //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? relayState = 0 : relayState = 1;
                                        //EEPROM.write(1, relayState ? 0xFF : 0x00);
                                        digitalWrite(RELAY_PIN, relayState ? HIGH : LOW);
                                        DEBUG_PRINT(F("Relay Status: "));
                                        DEBUG_PRINTLN(relayState ? F("ON") : F("OFF"));
                                      case 15:  //  "?brightLevel=" // Get the brightness of the LED
                                        brightLevel = parseNumber(httpMessage);
                                        brightLevel = map(brightLevel, 0, 100, 0, 255);
                                        DEBUG_PRINT(F("Brite:"));
                                        DEBUG_PRINTLN(brightLevel);
                                        if (brightLevel != oldBrightLevel)
                                          analogWrite(DIMMER_PIN, brightLevel);
                                        oldBrightLevel = brightLevel;
                                      case 16: // "?emailCount"  // Parse email count
                                        emailCount = parseNumber(httpMessage);
                                      default:
                                          //Nothing to do here...
                                    void buttonPress(int buttonID)
                                      DEBUG_PRINTLN(F("buttonPress"));
                                      ShowSockStatus();
                                      if (client.connect(veraServer, 3480)) //starts client connection, checks for connection
                                        DEBUG_PRINTLN(F("connected"));
                                        switch (buttonID)
                                        case 0:  // adjust backlight brightness down
                                          int brite = brightLevel;
                                          brite -= 25;
                                          if (brite < 0) brite = 0;
                                          client.print(F("GET /data_request?"
                                            "id=action&output_format=xml"
                                            "&DeviceNum=111"
                                            "&serviceId=urn:upnp-org:"
                                            "serviceId:Dimmer1"
                                            "&action=SetTarget"
                                            "&newTargetValue="));
                                          client.println(brite);
                                          client.println(F(" HTTP/1.1"
                                            "Connection: close"));  //close 1.1 persistent connection
                                          client.println(); //end of get request
                                          delay(1);
                                          client.stop();
                                        case 1:  // adjust backlight brightness up
                                          brite += 25;
                                          if (brite > 255) brite = 255;
                                            "&DeviceNum=111"
                                            "serviceId:Dimmer1"
                                            "&action=SetTarget"
                                          delay(1);
                                          client.stop();
                                        case 2:  // Toggle Alarm
                                            "&DeviceNum=112" /* <<<<< Set Vera Device Number for Alarm */
                                            "serviceId:SwitchPower1"
                                            "&action=SetTarget"
                                          client.print(relayState ? F("0") : F("1"));
                                          delay(1);
                                          client.stop();
                                        case 3:  // run lights out scene  //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                                            "&action=SetTarget"
                                          delay(1);
                                          client.stop();
                                        case 4:  // Lower Air Conditioning //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                                            "&DeviceNum=112" /* <<<<< Set Vera Device Number for A/C Control */
                                            "&action=SetTarget"
                                          if (airconSetpoint > 72) client.print(airconSetpoint - 1);
                                          else client.print(airconSetpoint - 1);
                                          delay(1);
                                          client.stop();
                                        default:
                                            //nothing to do here...
                                    char *parseString(byte messageNumber)
                                      int textLocation = (messagePtr - myString + strlen(messageType[messageNumber]));
                                      myCharBuffer[0] = '\0';
                                      for (byte i = 0; i < 30; i++) // we have room to display only 20 chars, but lets parse 30.
                                        if (myString[textLocation + i] != '&')
                                          myCharBuffer[i] = myString[textLocation + i];
                                          DEBUG_PRINTLN(myCharBuffer[i]);
                                          DEBUG_PRINTLN(F("got & marker"));
                                          myCharBuffer[i] = '\0';
                                      DEBUG_PRINTLN(myCharBuffer);
                                      return myCharBuffer;
                                    char *cleanString(char *targetString, char *searchString)
                                      while(strstr(targetString, searchString))
                                        char* stringChunk;
                                        stringChunk = strstr(targetString, searchString);
                                        targetString[stringChunk - targetString] = '\0';
                                        strncpy(myCharBuffer, targetString, sizeof myCharBuffer);
                                        strncat(myCharBuffer, " ", sizeof myCharBuffer);
                                        strncat(myCharBuffer, stringChunk + strlen(searchString), sizeof myCharBuffer);
                                        strncpy(targetString, myCharBuffer, sizeof myCharBuffer);
                                    int parseNumber(byte msgNum)
                                      if (strstr(myString, messageType[msgNum]))
                                        char *messagePointer;
                                        messagePointer = strtok(myString, "=");
                                        messagePointer = strtok(NULL, "?");
                                        int extractedNumber = atoi(messagePointer);
                                        return extractedNumber;
                                        DEBUG_PRINTLN(F("Fail parseNumber..."));
                                        return -99;
                                    char *centerString(char *stringToCenter)
                                      char centerSpacing[30];
                                      for (byte i = 0; i < ((20 - strlen(myCharBuffer)) / 2); i++)
                                        centerSpacing[i] = ' ';
                                        centerSpacing[i+1] = '\0';
                                      strncat(centerSpacing, myCharBuffer, sizeof centerSpacing);
                                      strncpy(myCharBuffer, centerSpacing, sizeof myCharBuffer);
                                    void messageTimer()
                                      if (millis() - timerStart >= timerDuration * 60000UL)
                                        signal = 0;
                                    void fastClearLCD()
                                      for (int i = 1; i < 3; i++)
                                        lcd.setCursor(0,i);
                                        for (int j = 0; j < 20; j++)
                                          lcd.print(F(" "));
                                    void timeDate()
                                      if (hourFormat12() < 10) lcd.print(F(" "));
                                      lcd.print(hourFormat12());
                                      lcd.print(minute());
                                      lcd.print(isAM() ? "am" : "pm");
                                      lcd.setCursor(9,0);
                                      if (month() < 10) lcd.print(F(" "));
                                      lcd.print(month());
                                      lcd.print(day());
                                      lcd.print(F("/"));
                                      lcd.print(year());
                                    void displayStatus()
                                      lcd.setCursor(0,3);
                                      lcd.print(emailCount < 0? 0 : emailCount);
                                      if (emailCount == 1)
                                        lcd.print(F(" eMail   "));
                                        lcd.print(F(" eMails   "));
                                      lcd.setCursor(11,3);
                                      if (alarmArmed != 1)
                                        lcd.print(F("Not Armed"));
                                    void beepTone()
                                      tone(TONE_PIN, 440, 200);
                                       noTone(TONE_PIN);
                                    void startupSyncVera() // RUNS A VERA SCENE ON STARTUP... Push the dimmer value from this scene
                                        DEBUG_PRINTLN(F("asking for dimmer level"));
                                        client.println(F("GET /data_request?id=action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=40"
                                        " HTTP/1.1"));
                                        client.println(F("Connection: close"));  //close 1.1 persistent connection
                                        delay(1);
                                        client.stop();
                                      @cleight
                                       December, 2014
                                       Version .98
                                       INSTRUCTIONS:
                                      HARDWARE:
                                       * That's IT!!!
                                       Software:
                                      #include <EEPROM.h>
                                      #include <Time.h>
                                      #include "DHT.h"
                                      #ifdef  DEBUG_ON
                                      typedef enum{
                                      lcdState;
                                      //File webFile;
                                      char *messagePtr;
                                      int signal = 0;
                                      boolean lightOn;
                                      boolean relayState;
                                      int todayLow = -99;
                                      int windSpeed = 99;
                                        "ZZZ"};
                                        4, 5, A0, A1, A2};
                                      DHT dht;
                                      EthernetUDP Udp;
                                      uint8_t mac[] = {
                                      char myString[100];
                                      byte locator = 0;
                                        SERIAL_START(9600);
                                      #ifdef USE_DHCP
                                          while(true){
                                        server.begin();
                                        lcd.init();
                                        lcd.clear();
                                        startupSyncVera();
                                        updateLCD();
                                        getNTPtime();
                                        webControl();
                                        messageTimer();
                                            buttonPress(i);
                                      void updateLCD()
                                          switch (state)
                                          case LCD_TIME:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            displayStatus();
                                              state = LCD_EMAIL;
                                          case LCD_EMAIL:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            lcd.print(F("         "));
                                            displayStatus();
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            displayStatus();
                                            state = LCD_GARAGE;
                                          case LCD_GARAGE:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            displayStatus();
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            displayStatus();
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.print(F("F"));
                                            lcd.setCursor(0,2);
                                            lcd.print(F("%"));
                                            displayStatus();
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            lcd.print(F("        "));
                                            lcd.print(F("F"));
                                            displayStatus();
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.print(F("F"));
                                            lcd.setCursor(0,2);
                                            lcd.print(F("%"));
                                            displayStatus();
                                          case LCD_WEATHER:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            displayStatus();
                                            state = LCD_HI_LOW;
                                          case LCD_HI_LOW:
                                            fastClearLCD();
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.print(F("F"));
                                            lcd.setCursor(0,2);
                                            lcd.print(F("F"));
                                            displayStatus();
                                            if (windSpeed > 2)
                                              state = LCD_WIND;
                                          case LCD_WIND:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.print(F(" "));
                                            lcd.setCursor(1,2);
                                            displayStatus();
                                          case LCD_FORECAST:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            displayStatus();
                                            if (messageFlag)
                                          case LCD_MESSAGE:
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                                delay(50);
                                                delay(50);
                                              beepTone();
                                            if (signal != 0)
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            displayStatus();
                                            fastClearLCD();
                                            lcd.setCursor(0,0);
                                            timeDate();
                                            lcd.setCursor(0,1);
                                            lcd.setCursor(0,2);
                                            lcd.print("    ");
                                      #ifdef DEBUG_ON
                                            lcd.print(F(" "));
                                            displayStatus();
                                            state = LCD_TIME;
                                        Udp.endPacket();
                                        setTime(newTime);
                                          DEBUG_PRINT(day());
                                        lcd.print(F(" "));
                                      void getNTPtime()
                                          lcd.write(0);
                                          delay(1000);
                                      void webControl()
                                        if (client)
                                              if (locator < 100)
                                                locator++;
                                                client.println(F(
                                                  "<html>"
                                                  "<head>"
                                                  "</head>"
                                                  "<body>"
                                                  "<H3>for Vera</H3>"
                                                  "<hr>"
                                                  "<br />"
                                                  "<br />"
                                                  "<hr>"
                                                  "<h2>"
                                                  "Send Message<br>"
                                                  "<form>"
                                                  "</select>"
                                                  "<h4>"
                                                  "</form>"
                                                  "<hr>"
                                                  "<br />"
                                                  "<br />"
                                                  "<br />"
                                                  "</div>"
                                                  "</body>"
                                                  "</html>"));
                                                delay(1);
                                                client.stop();
                                                  if (messagePtr)
                                                    processMessage(i);
                                                locator = 0;
                                      #ifdef DEBUG_ON
                                      int freeRam ()
                                        int v;
                                          DEBUG_PRINT(i);
                                          socketStat[i] = s;
                                      #ifdef DEBUG_ON
                                          Serial.print(s,16);
                                          uint8_t dip[4];
                                      #ifdef DEBUG_ON
                                              timerDuration = 5;
                                              timerDuration = 5;
                                            messageFlag = true;
                                        default:
                                        ShowSockStatus();
                                          switch (buttonID)
                                            brite -= 25;
                                              "&DeviceNum=111"
                                              "serviceId:Dimmer1"
                                              "&action=SetTarget"
                                            delay(1);
                                            client.stop();
                                            brite += 25;
                                              "&DeviceNum=111"
                                              "serviceId:Dimmer1"
                                              "&action=SetTarget"
                                            delay(1);
                                            client.stop();
                                              "&action=SetTarget"
                                            delay(1);
                                            client.stop();
                                              "&action=SetTarget"
                                            delay(1);
                                            client.stop();
                                              "&action=SetTarget"
                                            delay(1);
                                            client.stop();
                                          default:
                                          char* stringChunk;
                                          return -99;
                                      void messageTimer()
                                          signal = 0;
                                      void fastClearLCD()
                                          lcd.setCursor(0,i);
                                            lcd.print(F(" "));
                                      void timeDate()
                                        lcd.setCursor(9,0);
                                        lcd.print(month());
                                        lcd.print(day());
                                        lcd.print(F("/"));
                                        lcd.print(year());
                                        lcd.setCursor(0,3);
                                      void beepTone()
                                         noTone(TONE_PIN);
                                          " HTTP/1.1"));
                                          delay(1);
                                          client.stop();
                                      C
                                      C
                                      cleight
                                      @BulldogLowell I finally am getting somewhere with my project, however after some time working with it I have found that I would rather send data from other Arduino sensors to the LCD project directly rather than send it to Vera and then run a piece of Luup code every 15 minutes to then populate the variables the screen uses. I have looked all over the forums and cannot seem to find the right bit on information on MySensors 1.4 and how to send data from one node to the other, any assistance would be great.
                                      • C cleight
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        @cleight
                                        I've got a vera-centric build, so I haven't messed with this in a while, but there are send( ) and request( ) functions in the API... have you explored that yet?
                                        I would have the remote sensor repeat every so often (e.g. one minute) and add the that node's specifics to the incoming message callback function for the display device.
                                        We should have an example of Node-to-Node communication in the examples...
                                          @cleight
                                          C
                                          C
                                          cleight
                                          @BulldogLowell I agree I think it would benefit the community to have a node to node example on the site.
