  3. TX RX ERR - LED for Sensors
9 Posts 5 Posters 5.9k Views 1 Watching
    Meister_Petz
    is there a simple way to get these LEDs working on Sensors? Like the LEDs on the Serial Gateway but as said... for Sensors.
    Many Thanks
    Petz
    • M Meister_Petz
      Many Thanks
      Petz
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Meister_Petz
      you want to transmit to a node an instruction to turn on/off an LED... or you want to show at the node that it is in TX/RX process?
        Meister_Petz
        @BulldogLowell
        I would like the node to show that it is in TX/RX process.
          wrote on last edited by hek
          There isn't any super-easy way of hooking in this in the sketch. You would have to subclass the MySensors class or add the functionality you want directly.
            Meister_Petz
            wrote on last edited by Meister_Petz
            Nevertheless Thanks!
            That's how I solved it:
            If message sent, blink LED
            If message received, blink LED
            That's my code for 1, 2 or 3 LEDs:
                // YOUR DEFINITIONS
                // Definitions
                // POWER RX TX LED
                // Definitions
                     // choose one Mode
                       // All with one LED => LEDMode = 1
                       // POWER seperate   => LEDMode = 2
                       // only TX and RX   => LEDMode = 3
                       // 3 seperate LEDS  => LEDMode = 4
                       // for a power LED, I would connect a LED between GND and VCC in general.
                     const int LEDMode = 3; // 2 3 4 (0 is off)
                     // Mode 1
                     #define LEDPwrRXTXPin 4
                     // Mode 2
                     #define LEDPwrPin1 3
                     #define LEDRXTXPin 4
                     // Mode 3
                     #define LEDRXPin 3
                     #define LEDTXPin 4
                     // Mode 4
                     #define LEDPwrPin2 19
                     #define LEDRXPin 3
                     #define LEDTXPin 4
                     int blinkRX = 0;
                     int blinkTX = 0;
                // YOUR CODE
                // VOID SETUP
                // POWER RX TX LED
                // VOID SETUP
                     if (LEDMode == 1){
                       pinMode(LEDPwrRXTXPin, OUTPUT);
                     if (LEDMode == 2){
                       pinMode(LEDPwrPin1, OUTPUT);
                       pinMode(LEDRXTXPin, OUTPUT);
                     if (LEDMode == 3){
                       pinMode(LEDRXPin, OUTPUT);
                       pinMode(LEDTXPin, OUTPUT);
                     if (LEDMode == 4){
                       pinMode(LEDPwrPin2, OUTPUT);
                gw.process();
                // POWER RX TX LED
                // VOID LOOP
                if (LEDMode == 1){
                  digitalWrite(LEDPwrRXTXPin,HIGH);
                  if (blinkTX == 1){
                    digitalWrite(LEDPwrRXTXPin, LOW); // invert blink because power is already on
                    delay(40);
                    digitalWrite(LEDPwrRXTXPin, HIGH);
                    blinkTX = 0;
                if (LEDMode == 2){
                  digitalWrite(LEDPwrPin1,HIGH);
                  digitalWrite(LEDRXTXPin,LOW);
                  if (blinkTX == 1){
                    digitalWrite(LEDRXTXPin, HIGH);
                    delay(40);
                    digitalWrite(LEDRXTXPin, LOW);
                    blinkTX = 0;
                if (LEDMode == 3){
                  digitalWrite(LEDRXPin,LOW);
                  digitalWrite(LEDTXPin,LOW);
                  if (blinkTX == 1){
                    digitalWrite(LEDTXPin, HIGH);
                    delay(40);
                    digitalWrite(LEDTXPin, LOW);
                    blinkTX = 0;
                if (LEDMode == 4){
                  digitalWrite(LEDPwrPin2,HIGH);
                  if (blinkTX == 1){
                    delay(40);
                    blinkTX = 0;
                // YOUR CODE
                // VOID LOOP
                // !!! at  gw.send(msg.set...); there also needs to be a - blinkTX = 1; - !!!
                // POWER RX TX LED
                // INCOMING MESSAGE
                if (LEDMode == 1){
                  delay(40);
                if (LEDMode == 2){
                  digitalWrite(LEDRXTXPin,HIGH);
                  delay(40);
                if (LEDMode == 3){
                  digitalWrite(LEDRXPin, HIGH);
                  delay(40);
                  digitalWrite(LEDRXPin, LOW);
                if (LEDMode == 4){
                    delay(40);
                // YOUR CODE
                // INCOMING MESSAGE
            Still missing is the ERROR. Is there a way to ask if there was a "fail" within the message?
            • A
              A
              andriej
              +1 for the RX/TX LED support in code for node! :-)
              • A andriej
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                ++ to include the new RGB implementation along with this mod!
                  Meister_Petz
                  now without delay() but with LEDs are on for a number of loops (millis()) didn't work smoothly)
                      // DEFINITIONS
                        // POWER RX TX LED
                        // Definitions
                             // choose one Mode
                               // RX TX combined, no PWR LED  => LEDMode = 5
                             const int LEDMode = 5; // 2 3 4 5 (0 is off)
                             // does not need to be modified
                             // Mode 1
                             // Mode 2
                             // Mode 3
                             #define LEDRXPin 3
                             #define LEDTXPin 4
                             // Mode 4
                             #define LEDPwrPin2 14
                             #define LEDRXPin2 3
                             #define LEDTXPin2 4
                             // Mode 5
                             #define LEDRXTXPin2 4
                             int blinkRX = 0;
                             int blinkTX = 0;
                             int blinkLoopTX = 0;
                             int blinkOffTX = 500; // number of Loops until blink is off
                             int blinkLoopRX = 0;
                             int blinkOffRX = 500; // number of Loops until blink is off
                      // VOID SETUP - VOID SETUP - VOID SETUP - VOID SETUP - VOID SETUP
                        // POWER RX TX LED
                        // VOID SETUP
                             if (LEDMode == 1){
                             if (LEDMode == 2){
                             if (LEDMode == 3){
                             if (LEDMode == 4){
                             // no POWERLEd only RX TX combined => LEDMode = 5
                             if (LEDMode == 5){
                               pinMode(LEDRXTXPin2, OUTPUT);
                      // VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP
                        gw.process();
                        // POWER RX TX LED
                        // VOID LOOP
                        if (LEDMode == 1){
                          if (blinkTX == 0 && blinkRX == 0){digitalWrite(LEDPwrRXTXPin,HIGH);}
                          if (blinkTX == 1 || blinkRX == 1){
                            if (blinkLoopTX >= blinkOffTX){ blinkTX = 0; blinkRX = 0; blinkLoopTX = 0;}
                            blinkLoopTX++;
                        if (LEDMode == 2){
                          if (blinkTX == 0 && blinkRX == 0){digitalWrite(LEDRXTXPin,LOW);}
                            blinkLoopTX++;
                        if (LEDMode == 3){
                          if (blinkTX == 0){digitalWrite(LEDTXPin,LOW);}
                          if (blinkTX == 1){
                            if (blinkLoopTX >= blinkOffTX){ blinkTX = 0; blinkLoopTX = 0;}
                            blinkLoopTX++;
                          if (blinkRX == 0){digitalWrite(LEDRXPin,LOW);}
                          if (blinkRX == 1){
                            if (blinkLoopRX >= blinkOffRX){ blinkRX = 0; blinkLoopRX = 0;}
                            blinkLoopRX++;
                        if (LEDMode == 4){
                          if (blinkTX == 0){digitalWrite(LEDTXPin2,LOW);}
                          if (blinkTX == 1){
                            digitalWrite(LEDTXPin2, HIGH);
                            blinkLoopTX++;
                          if (blinkRX == 0){digitalWrite(LEDRXPin2,LOW);}
                          if (blinkRX == 1){
                            digitalWrite(LEDRXPin2, HIGH);
                            blinkLoopRX++;
                        if (LEDMode == 5){
                          if (blinkTX == 0 && blinkRX == 0){digitalWrite(LEDRXTXPin2,LOW);}
                            digitalWrite(LEDRXTXPin2, HIGH);
                            blinkLoopTX++;
                        // YOUR CODE
                        // VOID LOOP
                      // VOID INCOMING MESSAGE - VOID INCOMING MESSAGE - VOID INCOMING MESSAGE
                        // POWER RX TX LED
                        // INCOMING MESSAGE
                        blinkRX = 1;
                        // YOUR CODE
                        // INCOMING MESSAGE
                  • AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    I use something similar mainly to show if messages are received. For this purpose I created a small class/ library to blink and time LED's. The class uses a similar syntax as Bounce2 for assigning and handling LED's attached to output pins. LedFlash.
                    A code example:
                    https://codebender.cc/sketch:85200
