  3. Node to Node communication without gatway
3 Posts 2 Posters 1.1k Views 2 Watching
  • B
    B
    btmerz
    I have two sensor nodes and I want to send data from one node to the other.
    But I want to use them in an environment where is no gateway available.
    I got the communication to work with the gateway.
    So I can send data from the first node to the second (which is configured as a repeater).
    But if I disconnect the gatway nothing works.
    How do I have to configure the two nodes so that they can talk directly with each other without a gateway?
    node one (sender):
    #define MY_NODE_ID 150
    #define CHILD_ID 0 // Id of the sensor child
    MyMessage msg(CHILD_ID, V_TEXT);
    sendSketchInfo("Liedanzeige_Sender", "1.0");
    present(CHILD_ID, S_INFO,"Lied",true);
    send Data with : "send(msg.setSensor(CHILD_ID).setDestination(151).set("Test"),true);"
    node two (receiver):
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 151
    sendSketchInfo("Liedanzeige_Empfang", "1.0");
    present(CHILD_ID, S_INFO, "Empfänger", true);
    rejoe2R 1 Reply Last reply
    • B btmerz
      node one (sender):
      rejoe2R
      rejoe2R
      rejoe2
      @btmerz If the controller is not present, the nodes won't enter loop(). To avoid this, use (3000 may be changed)
      #define MY_TRANSPORT_WAIT_READY_MS 3000
      • B
        B
        btmerz
        Hi, meanwhile I was able to solve the problem.
        #define MY_PASSIVE_NODE did the trick.
