  3. Best options for a low current display for a battery operated node?
24 Posts 5 Posters 8.8k Views 6 Watching
  • NeverDieN NeverDie
    This one claims to be 80ua: https://www.buydisplay.com/default/2-2-inch-122x32-lcd-display-module-graphic-sed1520
    Nca78N
    Nca78N
    @neverdie said in Best options for a low current display for a battery operated node?:
    Interesting, there are a bunch of sellers when searching for the SED1520 controller. I guess it's a SED1520 clone and not the original, which seems like a very old model if I judge by the retro style of the datasheet :)
    https://www.lcd-module.de/eng/pdf/zubehoer/s_1520.pdf
    The only problem is it's a parallel interface, so it will need a lot of free pins.
      Thanks to a computer magazine, which wrote about https://github.com/joeycastillo/The-Open-Book I was made aware of a source for e-ink / e-paper displays:
      https://zh-tw.buyepaper.com/c/e-ink-display-0371
      Pricing looks ok and that have many different sizes
      • Nca78N Nca78
        So finally I made a new board with my spare PCF85176, still with a 5V uno and it's much better. This is the measurement for the full board: driver, LCD and MCP1703 that generates the 3V VLCD.
        I2C lines of the driver are 5V tolerant so I rewired my board to power the driver through the MCP1703. But it seems it's leaching power from the (still at 5V) I2C lines as measurement falls to 1uA :)
        Anyway the contrast is very good as you can see on the picture, and I'm also happy with the design of my "sensor test board", not perfect but flexible enough to test different combinations of voltage sources.
        matheus galvaoM
        matheus galvaoM
        matheus galvao
        @Nca78 I trying to use the GYTN-2490 display the same I intend to use with the PCF855 controller, how did you manage to show the values in the photo? which MCU do you use? I use PIC18f
        https://ibb.co/album/QX1sSS
        Nca78N 1 Reply Last reply
        • matheus galvaoM matheus galvao
          Nca78N
          Nca78N
          @matheus-galvao said in Best options for a low current display for a battery operated node?:
          GYTN-2490
          Hello, I didn't do much for this one, I just used an existing PCF8576 arduino library. Are you using this exact same LCD driver, or another one ? They are not very difficult to make libraries for, I made a library for PCA9553 (much lower power) and it was easy, the annoying part is sometimes to convert the digits to "raw" data sent to the LCD driver when LCD driver designers and lcd manufacturer didn't have the same idea for segment mapping :)
