  3. Soft WDT reset on ESP8266 RFM69 gateway after find parent
21 Posts 3 Posters 3.6k Views 3 Watching
    Alright. I'll add a ceramic capacitor.
    For compleeness, here is my complete sketch for the node:
    // Enable debug prints
    #define MY_NODE_ID 1
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_FREQUENCY RFM69_433MHZ // RFM69_433MHZ for development branch, RF69_433MHZ for master
    #define MY_RF69_IRQ_PIN 2
    #define MY_RF69_SPI_CS 10
    #include <MySensors.h> // From Library Manager
    #include <BME280I2C.h> // From Library Manager
    BME280I2C bme;
    static const uint64_t UPDATE_INTERVAL = 300000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_VCC_BEFORE 2
    #define CHILD_ID_VCC_AFTER 3
    MyMessage msgVccBefore(CHILD_ID_VCC_BEFORE, V_VOLTAGE);
    MyMessage msgVccAfter(CHILD_ID_VCC_AFTER, V_VOLTAGE);
    //TODO: Add pressure from BME280?
    //TODO: Add light detection (irq-based, LDR)
    //TODO: Add flooding detection
      sendSketchInfo("StorageRoom", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      wait(100);
      wait(100);
      present(CHILD_ID_VCC_BEFORE, S_CUSTOM);
      wait(100);
      present(CHILD_ID_VCC_AFTER, S_CUSTOM);
      if (! bme.begin()) {
        Serial.println("Could not find a valid BME280 sensor, check wiring! Continuing without sensor...");
      static float lastTemp;
      static float lastHum;
      send(msgVccBefore.set(readVcc() / 1000.0, 3));
      float temperature = bme.temp();
      if (isnan(temperature)) {
        Serial.println("Failed reading temperature");
        // Only send temperature if it changed since the last measurement
        lastTemp = temperature;
    #ifdef MY_DEBUG
      Serial.print("T: ");
      Serial.println(temperature);
      float humidity = bme.hum();
      if (isnan(humidity)) {
        Serial.println("Failed reading humidity");
        // Only send humidity if it changed since the last measurement
        lastHum = humidity;
    #ifdef MY_DEBUG
      Serial.print("H: ");
      Serial.println(humidity);
      send(msgVccAfter.set(readVcc() / 1000.0, 3));
      sleep(UPDATE_INTERVAL);
    long readVcc() {
      // From http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
      ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
    #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
      ADMUX = _BV(MUX5) | _BV(MUX0);
    #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
      ADMUX = _BV(MUX3) | _BV(MUX2);
    #else
      while (bit_is_set(ADCSRA, ADSC)); // measuring
      long result = (high << 8) | low;
    and for the gateway:
    // Based on https://github.com/mysensors/MySensors/tree/master/examples/GatewayESP8266OTA
    #include <ArduinoOTA.h>
    #define MY_BAUD_RATE 74880 // To be able to see reset messages
    #define WIFI_REPORT_INTERVAL 300000
    #define MY_RF69_IRQ_PIN D2
    #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
    #define MY_RF69_SPI_CS D8
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "Mr-IoT.com"
    #include "settings.h"
    #define MY_HOSTNAME "RFM69-Gateway"
    #define MY_PORT 5003
    #if defined(MY_USE_UDP)
    #include <WiFiUDP.h>
    #else
    #include <ESP8266WiFi.h>
    #define CHILD_ID_WIFI_RSSI 0
    MyMessage msgWifiRssi(CHILD_ID_WIFI_RSSI, V_LEVEL);
    #define CHILD_ID_RSSI1 1
    MyMessage msgRssi1(CHILD_ID_RSSI1, V_LEVEL);
    bool sendRssi = false;
    int16_t rssi;
      ArduinoOTA.onStart([]() {
        DEBUG_OUTPUT("ArduinoOTA start\n");
      ArduinoOTA.onEnd([]() {
        DEBUG_OUTPUT("\nArduinoOTA end\n");
      ArduinoOTA.setPassword((const char *)OTA_PASSWORD);
      ArduinoOTA.setHostname(MY_HOSTNAME);
      ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
        DEBUG_OUTPUT("OTA Progress: %u%%\r", (progress / (total / 100)));
      ArduinoOTA.onError([](ota_error_t error) {
        DEBUG_OUTPUT("Error[%u]: ", error);
        if (error == OTA_AUTH_ERROR) {
          DEBUG_OUTPUT("Auth Failed\n");
        } else if (error == OTA_BEGIN_ERROR) {
          DEBUG_OUTPUT("Begin Failed\n");
        } else if (error == OTA_CONNECT_ERROR) {
          DEBUG_OUTPUT("Connect Failed\n");
        } else if (error == OTA_RECEIVE_ERROR) {
          DEBUG_OUTPUT("Receive Failed\n");
        } else if (error == OTA_END_ERROR) {
          DEBUG_OUTPUT("End Failed\n");
      ArduinoOTA.begin();
      present(CHILD_ID_WIFI_RSSI, S_SOUND);
      wait(100);
      present(CHILD_ID_RSSI1, S_SOUND);
    long lastSend = 0;
      // Send locally attech sensors data here
      ArduinoOTA.handle();
      if (millis() - lastSend > WIFI_REPORT_INTERVAL) {
        send(msgWifiRssi.set(WiFi.RSSI(), 1));
        lastSend = millis();
      if (sendRssi) {
        sendRssi = false;
        send(msgRssi1.set(rssi, 0));
      rssi = _radio.RSSI;
      if (message.sender == 1) {
        sendRssi = true;
    #21
    About 35 minutes after I reset the node, it started reporting again (without any other changes). I have no idea what caused it to start working.
