  3. [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem)
21 Posts 5 Posters 5.5k Views 4 Watching
  • R rafael156
    ok, Thanks at all!
    You helped me find the mistake!
    it was actually because the node could not receive commands because there was a "sleep()" hidden somewhere in each sketch. after I searched all sketches thoroughly and replaced them with "wait()", everything runs without problems:
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      wait(dht.getMinimumSamplingPeriod());
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      //sleep(UPDATE_INTERVAL);
      wait(UPDATE_INTERVAL);
    void receive(){
    However, I would suggest that the functions "wait()" and "smartsleep()" be mentioned in relation to the MySBootloader in a separate point under "https://www.mysensors.org/about/fota". Maybe under a chapter:
    1. Enabling FOTA in your sketch
      1.1 DualOptiboot only
      --> text as before
      1.2 MySBootloader
      --> ... use smartsleep() and wait() instead of sleep()...
    Summary:
    • fuse settings 8MHz external crystal:
    MYSBL.menu.frequency.MYSBL8=ATmega328 8Mhz ext MYSBootloader_1.3.0-rc.1
    MYSBL.menu.frequency.MYSBL8.build.f_cpu=8000000L
    MYSBL.menu.frequency.MYSBL8.upload.speed=57600
    MYSBL.menu.frequency.MYSBL8.bootloader.low_fuses=0xFF
    MYSBL.menu.frequency.MYSBL8.bootloader.high_fuses=0xD2
    MYSBL.menu.frequency.MYSBL8.bootloader.extended_fuses=0x06
    MYSBL.menu.frequency.MYSBL8.bootloader.unlock_bits=0x3F
    MYSBL.menu.frequency.MYSBL8.bootloader.lock_bits=0x0F
    MYSBL.menu.frequency.MYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
    • if sensebender gateway is connected via usb, only one instance may access the gateway at a time, therefore "OpenHab" must be terminated first
    • do not use "sleep()" in the sketches. only "smartsleep()" or "wait()".
      use the current dev-branch from "https://github.com/mysensors/MySensorsBootloaderRF24
    B Offline
    B Offline
    badmannen
    @rafael156 oh crap ... I put in that lowFuse as FF .. ( I read you had it for 8 MHz INTERNAL .. but nooo you wrote external ... ooops ... is there any way to force write it back without connecting an 8 MHz oscillator to the chip .. I only got 16 MHz oscillators .. or am I screwed for that chip until I go and get one?
    rPi 3 - UNO R3 - Mini - Nano - custom
