  3. [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem)
21 Posts 5 Posters 5.7k Views 4 Watching
  • R
    R
    rafael156
    @tekka Do you have an idea what´s wrong with the code? yesterday i have changed "sleep(UPDATE_INTERVAL);" to "wait(UPDATE_INTERVAL); " but bothing changed. Fota update or software reboot doesnt work.
    Are the fuses and the bootloader options (txt) correct?
    tekkaT 1 Reply Last reply
      don't you need to reboot to trigger the update?
      • R
        R
        rafael156
        wrote on last edited by rafael156
        Yeah, right! That's the problem! But when I click on "reboot" on myscontroller, the node does not react to any command, i.e. reboot etc.
        is there a function that takes the command from myscontroller and executes it or do I have to implement it myself in the sketch?
        SoloamS gohanG 2 Replies Last reply
        • R rafael156
          SoloamS
          SoloamS
          Soloam
          @rafael156 I had a similar problem, my node would stop responding when I tried to reboot it. The problem was in the fuse settings, have you checked if they are all set? What version are you using? (16,8 or 1)
          • R rafael156
            @rafael156 have you tried with smartsleep instead of sleep? Of course the node would respond only when it wakes up.
            • R
              R
              rafael156
              @Soloam i have checked fuse settings several times . i use the 8 mhz version. boards.txt see above .
              at burn process, arduino ide (1.6.13) gave me a warning about the fuses
              which fuses do you have?
              @gohan no, i didnt. but i have tried wait(), with no success. i will try smartsleep() today!
              • R rafael156
                tekkaT
                tekkaT
                tekka
                @rafael156 Hmm, I don't think this is related to the fuse settings. Try again changing sleep() to wait() and upload the full logs from MYSController and the node (with MY_DEBUG enabled)
                • R
                  R
                  rafael156
                  ok, Thanks at all!
                  You helped me find the mistake!
                  it was actually because the node could not receive commands because there was a "sleep()" hidden somewhere in each sketch. after I searched all sketches thoroughly and replaced them with "wait()", everything runs without problems:
                   * Version 1.0: Henrik EKblad
                   * sensor using a DHT11/DHT-22.
                  // Enable debug prints
                  //#define MY_RS485
                  #define DHT_DATA_PIN 3
                  #define SENSOR_TEMP_OFFSET 0
                  static const uint64_t UPDATE_INTERVAL = 60000;
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  float lastTemp;
                  float lastHum;
                  uint8_t nNoUpdatesTemp;
                  uint8_t nNoUpdatesHum;
                  bool metric = true;
                  DHT dht;
                    sendSketchInfo("TemperatureAndHumidity", "1.1");
                    present(CHILD_ID_HUM, S_HUM);
                    wait(dht.getMinimumSamplingPeriod());
                    dht.readSensor(true);
                    if (isnan(temperature)) {
                      lastTemp = temperature;
                      if (!metric) {
                      // Reset no updates counter
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      Serial.print("T: ");
                      nNoUpdatesTemp++;
                    if (isnan(humidity)) {
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      Serial.print("H: ");
                      Serial.println(humidity);
                      nNoUpdatesHum++;
                    //sleep(UPDATE_INTERVAL);
                  void receive(){
                  However, I would suggest that the functions "wait()" and "smartsleep()" be mentioned in relation to the MySBootloader in a separate point under "https://www.mysensors.org/about/fota". Maybe under a chapter:
                  1. Enabling FOTA in your sketch
                    1.1 DualOptiboot only
                    --> text as before
                    1.2 MySBootloader
                    --> ... use smartsleep() and wait() instead of sleep()...
                  Summary:
                  • fuse settings 8MHz external crystal:
                  MYSBL.menu.frequency.MYSBL8=ATmega328 8Mhz ext MYSBootloader_1.3.0-rc.1
                  MYSBL.menu.frequency.MYSBL8.build.f_cpu=8000000L
                  MYSBL.menu.frequency.MYSBL8.upload.speed=57600
                  MYSBL.menu.frequency.MYSBL8.bootloader.low_fuses=0xFF
                  MYSBL.menu.frequency.MYSBL8.bootloader.high_fuses=0xD2
                  MYSBL.menu.frequency.MYSBL8.bootloader.extended_fuses=0x06
                  MYSBL.menu.frequency.MYSBL8.bootloader.unlock_bits=0x3F
                  MYSBL.menu.frequency.MYSBL8.bootloader.lock_bits=0x0F
                  MYSBL.menu.frequency.MYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
                  • if sensebender gateway is connected via usb, only one instance may access the gateway at a time, therefore "OpenHab" must be terminated first
                  • do not use "sleep()" in the sketches. only "smartsleep()" or "wait()".
                    use the current dev-branch from "https://github.com/mysensors/MySensorsBootloaderRF24
                  gohanG badmannenB 2 Replies Last reply
                  • R rafael156
                    ok, Thanks at all!
                    //#define MY_RS485
                    float lastTemp;
                    float lastHum;
                    bool metric = true;
                    DHT dht;
                        if (!metric) {
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesTemp++;
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesHum++;
                    void receive(){
                      --> text as before
                      1.2 MySBootloader
                    Summary:
                    @rafael156 said in [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem):
                    I'd use smartsleep in this case as wait will keep the MCU active and drain battery. Wait is better used in place of "delay"
                    • R rafael156
                      ok, Thanks at all!
                      //#define MY_RS485
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                      DHT dht;
                          if (!metric) {
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesTemp++;
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesHum++;
                      void receive(){
                        --> text as before
                        1.2 MySBootloader
                      Summary:
                      badmannenB
                      badmannenB
                      badmannen
                      @rafael156 oh crap ... I put in that lowFuse as FF .. ( I read you had it for 8 MHz INTERNAL .. but nooo you wrote external ... ooops ... is there any way to force write it back without connecting an 8 MHz oscillator to the chip .. I only got 16 MHz oscillators .. or am I screwed for that chip until I go and get one?
                      rPi 3 - UNO R3 - Mini - Nano - custom
