  3. Many compilation errors with mySensor 2.2
5 Posts 2 Posters 2.7k Views 2 Watching
  • djdehaanD
    djdehaanD
    djdehaan
    wrote on last edited by djdehaan
    Hi all,
    I must be crazy, but I have a strange but big problem with version 2.2 of mySensor. I use it on esp8266 (Wemos), and with a previous version my program compiled without a problem. I upgraded to mySensor 2.2 and 2 problem arised. First my compilation first resulted in:
    In file included from D:\users\DirkJan\Arduino\libraries\MySensors/MySensors.h:405:0,
                     from D:\users\DirkJan\Arduino\Projecten\Project_WCsniffer\IoT21_WCsniffer010\IoT21_WCsniffer010.ino:31:
    D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:57:53: error: declaration of C function 'void ets_update_cpu_frequency(int)' conflicts with
     extern "C" void ets_update_cpu_frequency(int freqmhz);
    In file included from D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/pgmspace.h:10:0,
                     from D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/Arduino.h:255,
                     from sketch\IoT21_WCsniffer010.ino.cpp:1:
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266/tools/sdk/include/ets_sys.h:218:6: error: previous declaration 'void ets_update_cpu_frequency(uint32_t)' here
     void ets_update_cpu_frequency(uint32_t ticks_per_us);
    exit status 1
    Fout bij het compileren voor board WeMos D1 R2 & mini
    So I changed file MyMainESP8266.cpp and replace int for uint32_t. When I then compile the Sketch, it comes with the following load of errors:
    Archiving built core (caching) in: C:\Users\DirkJan\AppData\Local\Temp\arduino_cache_514641\core\core_espressif_esp8266_d1_mini_CpuFrequency_160,VTable_flash,FlashSize_4M1M,LwIPVariant_v2mss536,Debug_Disabled,DebugLevel_None____,FlashErase_none,UploadSpeed_256000_8c8da037c528d73cc750ee74e4676a97.a
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o): In function `esp_yield':
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/core_esp8266_main.cpp:87: multiple definition of `esp_yield'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:81: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o): In function `esp_schedule':
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/core_esp8266_main.cpp:94: multiple definition of `esp_schedule'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:89: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o): In function `init_done()':
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/core_esp8266_main.cpp:144: multiple definition of `init_done()'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:151: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o): In function `__yield':
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/core_esp8266_main.cpp:98: multiple definition of `__yield'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:94: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o): In function `optimistic_yield':
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/core_esp8266_main.cpp:109: multiple definition of `optimistic_yield'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:105: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o):(.bss.resetInfo+0x0): multiple definition of `resetInfo'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\Projecten\Project_WCsniffer\IoT21_WCsniffer010/DJ_Tools.ino:63: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o): In function `user_init':
    D:\users\DirkJan\Arduino\hardware\espressif\esp8266\cores\esp8266/core_esp8266_main.cpp:168: multiple definition of `user_init'
    sketch\IoT21_WCsniffer010.ino.cpp.o:D:\users\DirkJan\Arduino\libraries\MySensors/hal/architecture/ESP8266/MyMainESP8266.cpp:160: first defined here
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o):(.bss.core_release+0x0): multiple definition of `core_release'
    C:\Users\DirkJan\AppData\Local\Temp\arduino_build_931425/arduino.ar(core_esp8266_main.cpp.o):(.ver_number+0x0): multiple definition of `core_version'
    sketch\IoT21_WCsniffer010.ino.cpp.o:(.ver_number+0x0): first defined here
    What do i do wrong???
    Thanks for any help,
    Dirk Jan
    • electrikE
      electrikE
      electrik
      did you select the right board to compile for?
      • djdehaanD
        djdehaanD
        djdehaan
        I certainly did.
        When i compile the following Sketch, I do get the first compile error mentioned above:
        #define ESP8266
        #define MY_BAUD_RATE 9600
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "xxx"
        #define MY_ESP8266_PASSWORD "xxx"
        #define MY_PORT 5003
        #include <ESP8266WiFi.h>
        #include <ESP8266mDNS.h>
          // put your setup code here, to run once:
          // put your main code here, to run repeatedly:
        What is wrong with this sketch (besides that it does nothing)?
        • djdehaanD
          djdehaanD
          djdehaan
          I found out that the same errors occur if i load mySensor library 2.1 or 2.0. It is not related to 2.2 version of mySensor.
          So what goes wrong? For this matter, I downloaded the ESP8266 hardware library again, and ran
          python get.py
          So the ESP8266 harware lib is the newest. And then still it generates all those error, again and again.
          • djdehaanD
            djdehaanD
            djdehaan
            Well, problem solved. I removed the ESP8266 harware libs and reinstalled them now using the Boards Manager. Then it works fine. But a manual download of the ESP8266 hardware lib causes all these comilation errors.
            Thanks.
