  3. Home Assistant
  4. New version MySensors 2.3.0 with RFM69HW - Problem
5 Posts 3 Posters 2.5k Views 3 Watching
  • pepsonP
    pepsonP
    pepson
    Hi
    Today i update from 2.2.0 version to 2.3.0 on my Home Assistant 0.71.0
    After update to 2.3.0 i have a problem with communication on radio RFM69HW. Sometime lost communication and no reaction. When come back to 2.2.0 all is ok. Please help me....
    • pepsonP
      pepsonP
      pepson
      This is my code
      #define MY_RADIO_RFM69
      #define MY_IS_RFM69HW
      #define RFM69_868MH
      #define MY_RFM69_NEW_DRIVER
      #define MY_REPEATER_FEATURE
      //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
      // uncomment if we want to manually assign an ID
      #define MY_NODE_ID 1
      #include <Bounce2.h>
      #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
      #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
      //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
      //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
      //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
      #define RELAY_UP_PIN 5
      #define RELAY_DOWN_PIN 6
      #define RELAY_ON 0
      #define RELAY_OFF 1
      //#define RELAY_DOWN 1
      //#define RELAY_UP 0
      #define DIRECTION_DOWN 0
      #define DIRECTION_UP 1
      #define SKETCH_NAME "Roleta w sypialni"
      #define SKETCH_VER "2.3"
      #define CHILD_ID_COVER 0   // sensor Id of the sensor child
      #define STATE_UP 100 // 100 is open - up
      #define STATE_DOWN 0 // 0 is closed - down
      //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
      #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
      #define PRESENT_MESSAGE "Rolety dla Home Assistant"
      const int LEVELS = 100; //the number of levels
      float rollTime = 20.0; //the overall rolling time of the shutter
      const bool IS_ACK = false; //is to acknowlage
      static bool initial_state_sent = false;//for hass we need at list one state send at begining
      // debouncing parameters
      int value = 0;
      int oldValueUp = 0;
      int oldValueDown = 0;
      int oldValueStop = 0;
      //static unsigned long last_interrupt_time_up = 0;
      //static unsigned long last_interrupt_time_down = 0;
      //static unsigned long debounce_time = 200;
      Bounce debouncerUp = Bounce();
      Bounce debouncerDown = Bounce();
      Bounce debouncerStop = Bounce();
      // shutter position parameters
      float timeOneLevel = rollTime / LEVELS;
      int requestedShutterLevel = 0;
      int currentShutterLevel = 0;
      unsigned long lastLevelTime = 0;
      bool isMoving = false;
      int directionUpDown;
      bool calibrateDown;
      bool calibrateUp;
      unsigned long calibrationStartTime;
      float calibrationTime = 5.0;
      bool calibratedDown;
      bool calibratedUp;
      enum CoverState {
        STOP,
        UP, // Window covering. Up.
        DOWN, // Window covering. Down.
      static int coverState = STOP;
      MyMessage msgUp(CHILD_ID_COVER, V_UP);
      MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
      MyMessage msgStop(CHILD_ID_COVER, V_STOP);
      MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
      //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
      void sendState() {
        // Send current state and status to gateway.
      //  send(msgUp.set(coverState == UP));
      //  send(msgDown.set(coverState == DOWN));
      //  send(msgStop.set(coverState == STOP));
        send(msgPercentage.set(currentShutterLevel));
      void shuttersUp(void) {
        #ifdef MY_DEBUG
        Serial.println("Shutters going up");
        if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
          digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
          wait(50);
        digitalWrite(RELAY_UP_PIN, RELAY_ON);
        directionUpDown = DIRECTION_UP;
        isMoving = true;
        coverState = UP;
        sendState();
      void shuttersDown(void) {
        #ifdef MY_DEBUG
        Serial.println("Shutters going down");
        if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
          digitalWrite(RELAY_UP_PIN, RELAY_OFF);
          wait(50);
        digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
        directionUpDown = DIRECTION_DOWN;
        isMoving = true;
        coverState = DOWN;
        sendState();
      void shuttersHalt(void) {
      #ifdef MY_DEBUG
        Serial.println("Shutters halted");
        isMoving = false;
        requestedShutterLevel = currentShutterLevel;
      #ifdef MY_DEBUG
        Serial.println("saving state to: ");
        Serial.println(String(currentShutterLevel));
        saveState(CHILD_ID_COVER, currentShutterLevel);
        coverState = STOP;
        sendState();
      void changeShuttersLevel(int level) {
        int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
        if (isMoving && dir != directionUpDown) {
          shuttersHalt();
        requestedShutterLevel = level;
      void initShutters() {
      #ifdef MY_DEBUG
        Serial.println("Init Cover");
        shuttersUp();
        wait((rollTime + timeOneLevel * LEVELS) * 1000);
        currentShutterLevel = STATE_UP;
      #ifdef MY_DEBUG
        Serial.println("recieved incomming message");
        Serial.println("Recieved message for sensor: ");
        Serial.println(String(message.sensor));
        Serial.println("Recieved message with type: ");
        Serial.println(String(message.type));
        if (message.sensor == CHILD_ID_COVER) {
          switch (message.type) {
            case V_UP:
              //Serial.println(", New status: V_UP");
              changeShuttersLevel(STATE_UP);
              //state = UP;
              //sendState();
              break;
            case V_DOWN:
              //Serial.println(", New status: V_DOWN");
              changeShuttersLevel(STATE_DOWN);
              //state = DOWN;
              //sendState();
              break;
            case V_STOP:
              //Serial.println(", New status: V_STOP");
              shuttersHalt();
              //state = IDLE;
              //sendState();
              break;
            case V_PERCENTAGE:
              //Serial.println(", New status: V_PERCENTAGE");
              //          if (!initial_state_sent) {
              //            #ifdef MY_DEBUG
              //            Serial.println("Receiving initial value from controller");
              //            #endif
              //            initial_state_sent = true;
              int per = message.getInt();
              if (per > STATE_UP) {
                per = STATE_UP;
              changeShuttersLevel(per);
              //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
              //sendState();
              break;
      else if (message.sensor ==  CHILD_ID_SET) {
          if (message.type == V_VAR1) {
            #ifdef MY_DEBUG
            Serial.println(", New status: V_VAR1, with payload: ");
            String strRollTime = message.getString();
            rollTime = strRollTime.toFloat();
            #ifdef MY_DEBUG
            Serial.println("rolltime value: ");
            Serial.println(String(rollTime));
            saveState(CHILD_ID_SET, rollTime);
      #ifdef MY_DEBUG
        Serial.println("exiting incoming message");
        return;
      void before() {
        // Setup the button
        pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
        // Activate internal pull-up
      //  digitalWrite(BUTTON_UP_PIN, HIGH);
        //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
        pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
      //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
        //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
      //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
      //  digitalWrite(BUTTON_STOP_PIN, HIGH);
        debouncerUp.attach(BUTTON_UP_PIN);
        debouncerUp.interval(5);
        debouncerDown.attach(BUTTON_DOWN_PIN);
        debouncerDown.interval(5);
      //  debouncerStop.attach(BUTTON_STOP_PIN);
      //  debouncerStop.interval(5);
        pinMode(RELAY_UP_PIN, OUTPUT);
        pinMode(RELAY_DOWN_PIN, OUTPUT);
      void presentation() {
        sendSketchInfo(SKETCH_NAME, SKETCH_VER);
        present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
        // present(CHILD_ID_SET, S_CUSTOM);
      void setup(void) {
        //set up roll time if the saved value is not 255
        #ifdef MY_DEBUG
        Serial.println("getting rolltime from eeprom: ");
        float tmpRollTime = loadState(CHILD_ID_SET);
        if (tmpRollTime != 0xff) {
          rollTime = tmpRollTime;
        #ifdef MY_DEBUG
        int state = loadState(CHILD_ID_COVER);
        #ifdef MY_DEBUG
        Serial.println("getting state from eeprom: ");
        Serial.println(String(state));
      //  if (state == 0xff) {
      //    initShutters();
      //  } else {
          currentShutterLevel = state;
          requestedShutterLevel = state;
      void loop(void) {
      #ifdef MY_DEBUG
          sendState();
         // send(msgCode.set('20.0'));
          //    #ifdef MY_DEBUG
          //    Serial.println("Requesting initial value from controller");
          //    #endif
          //    request(CHILD_ID_COVER, V_PERCENTAGE);
          //    wait(2000, C_SET, V_PERCENTAGE);
        debouncerUp.update();
        value = debouncerUp.read();
        if (value == 0 && value != oldValueUp) {
          if(isMoving){
            shuttersHalt();
          else{
          calibrateUp = false;
          calibratedUp = false;
          //state = UP;
          //sendState();
        oldValueUp = value;
        debouncerDown.update();
        value = debouncerDown.read();
        if (value == 0 && value != oldValueDown) {
          if(isMoving){
            shuttersHalt();
          else{
          calibrateDown = false;
          calibratedDown = false;
          //state = DOWN;
          //sendState();
        oldValueDown = value;
      /*  debouncerStop.update();
        value = debouncerStop.read();
        if (value == 0 && value != oldValueStop) {
          shuttersHalt();
          //state = IDLE;
          //sendState();
        oldValueStop = value;
        if(currentShutterLevel != 100)
        if(currentShutterLevel != 0)
        if (isMoving)
          unsigned long _now = millis();
          if (_now - lastLevelTime >= timeOneLevel * 1000) {
            if (directionUpDown == DIRECTION_UP) {
              currentShutterLevel += 1;
            } else {
              currentShutterLevel -= 1;
            currentShutterLevel = constrain(currentShutterLevel, 0, 100);
            #ifdef MY_DEBUG
            Serial.println(String(requestedShutterLevel));
            lastLevelTime = millis();
          if (currentShutterLevel == requestedShutterLevel)
            if(currentShutterLevel == 0 && !calibratedDown)
              if(calibrateDown == false)
                calibrateDown = true;
                calibrationStartTime = _now;
              else
                if(calibratedDown == false)
                  if (_now - calibrationStartTime >= calibrationTime * 1000)
                   calibratedDown = true;
            else if (currentShutterLevel == 100 && !calibratedUp)
              if(calibrateUp == false)
                calibrateUp = true;
              else
                if(calibratedUp == false)
                   calibratedUp = true;
            else
              shuttersHalt();
        else
          if (requestedShutterLevel != currentShutterLevel)
            if (requestedShutterLevel > currentShutterLevel) {
              shuttersUp();
            else {
              shuttersDown();
      • K
        K
        kimot
        Try with no _NEW_DRIVER.
        Some problems with this was written here
        pepsonP 1 Reply Last reply
        • K kimot
          pepsonP
          pepsonP
          pepson
          @kimot
          Only use this ?
          #define RFM69_868MH
          • Andrew MaynardA
            Andrew MaynardA
            Andrew Maynard
            did you figure this out? i keep getting errors trying to declare mhz
