  3. DHT11 sensor
DHT11 sensor
2 Posts 2 Posters 997 Views 2 Watching
  • A
    A
    akya
    Can anyone know about where i can find the " minimum sampling time" of DHT11 temperature and humidity sensor?
    chisightC 1 Reply Last reply
    • A akya
      chisightC
      chisightC
      chisight
      @akya the number of times you can read a DHT11 in a given time period isn't limited. You can read as fast as you want. The limit widely mentioned (at various rates of around once every 2 seconds) has to do with the heating effect of turning on current to the temperature sensitive resistor to take a reading. Someone tested and noticed that reading at high speed caused a slightly elevated temperature reading.
      You can test for yourself and see at what read rate you notice an increase, or just limit to once every 2 seconds or less.
      See me on IRC at ircs://freenode:6697/##nodered and ircs://freenode:6697/#mysensors
