  3. SmartSleep wake up message always get NACK
18 Posts 6 Posters 4.7k Views 5 Watching
  • H
    H
    Henrik Nielsen
    Hi
    I'm struggling a bit with the smartSleep functionality in MySensors.
    I know it should be straight forward, since it appears that the usage of sleep and smartSleep methods are basically the same from a developers perspective, but for some reason, the "wake up" message the node sends when the smart sleep is over, never gets sent. I almost never see messages that I manually send with sensor data etc. getting NACK'ed, and this happens on every single wake.
    Below is a tiny PoC test I have made. I kept it as simple as possible so I could hopefully get something working, and build on to that. But this simple example also fails :(
    #define MY_RF24_CHANNEL 0x44
    #define MY_RF24_BASE_RADIO_ID 0x00, 0xf6, 0x4d,0x89, 0xc0
    void presentation() {
      sendSketchInfo("SmartSleepTest", "1.0");
      present(1, S_INFO, "Info");
      smartSleep(1000);
    When running, the output looks like this:
    6 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    36 TSM:INIT:TSP OK
    38 TSF:SID:OK,ID=204
    40 TSM:FPAR
    77 TSF:MSG:SEND,204-204-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    446 TSF:MSG:READ,202-202-204,s=255,c=3,t=8,pt=1,l=1,sg=0:2
    452 TSF:MSG:FPAR OK,ID=202,D=3
    573 TSF:MSG:READ,201-201-204,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    579 TSF:MSG:FPAR OK,ID=201,D=2
    2084 TSM:FPAR:OK
    2084 TSM:ID
    2086 TSM:ID:OK
    2088 TSM:UPL
    2095 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2140 TSF:MSG:READ,0-201-204,s=255,c=3,t=25,pt=1,l=1,sg=0:2
    2148 TSF:MSG:PONG RECV,HP=2
    2150 TSM:UPL:OK
    2152 TSM:READY:ID=204,PAR=201,DIS=2
    2160 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2191 TSF:MSG:READ,0-201-204,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2201 TSF:MSG:SEND,204-204-201-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    2211 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:201
    2355 TSF:MSG:READ,0-201-204,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2363 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:SmartSleepTest
    2410 !TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
    2420 TSF:MSG:SEND,204-204-201-0,s=1,c=0,t=36,pt=0,l=4,sg=0,ft=1,st=OK:Info
    2428 MCO:REG:REQ
    2441 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2506 TSF:MSG:READ,0-201-204,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2512 MCO:PIM:NODE REG=1
    2514 MCO:BGN:INIT OK,TSP=1
    2519 MCO:SLP:MS=1000,SMS=1,I1=255,M1=255,I2=255,M2=255
    2529 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    3037 TSF:TDI:TSL
    3039 MCO:SLP:WUP=-1
    3041 TSF:TRI:TSB
    5457 !TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:1000
    5466 MCO:SLP:MS=1000,SMS=1,I1=255,M1=255,I2=255,M2=255
    5476 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:500
    5984 TSF:TDI:TSL
    5986 MCO:SLP:WUP=-1
    5988 TSF:TRI:TSB
    8404 !TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:1000
    8413 MCO:SLP:MS=1000,SMS=1,I1=255,M1=255,I2=255,M2=255
    8423 TSF:MSG:SEND,204-204-201-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:500
    8931 TSF:TDI:TSL
    8933 MCO:SLP:WUP=-1
    The PRE-SLEEP message at 2529 gets sent correct, but the POST-SLEEP message gets NACK'ed at 5457.
    I have tried the following, without any luck:
    1. Longer and shorter smart sleep durations, with the same result.
    2. Attempts has been made both with a Raspberry Pi gateway and an ESP8266 gateway, but I doubt the gateway type matter, since it looks like something locally on the node.
    3. Two types of hardware for the node, both a home-designed mini-pcb which run great for other nodes (without smart sleep), and the Easy/Newbie PCB from openhardware.io.
    4. Looking for examples that use smartSleep, but the ones I found only use sleep.
    ANY help or push in the right direction will be greatly appreciated. :)
    /Henrik
    YveauxY berkseoB 2 Replies Last reply
    • H Henrik Nielsen
      Hi
        smartSleep(1000);
      26 TSM:INIT
      28 TSF:WUR:MS=0
      36 TSM:INIT:TSP OK
      40 TSM:FPAR
      2084 TSM:FPAR:OK
      2084 TSM:ID
      2086 TSM:ID:OK
      2088 TSM:UPL
      2150 TSM:UPL:OK
      2428 MCO:REG:REQ
      3037 TSF:TDI:TSL
      3039 MCO:SLP:WUP=-1
      3041 TSF:TRI:TSB
      5984 TSF:TDI:TSL
      5986 MCO:SLP:WUP=-1
      5988 TSF:TRI:TSB
      8931 TSF:TDI:TSL
      8933 MCO:SLP:WUP=-1
      /Henrik
      YveauxY
      YveauxY
      @henrik-nielsen do you know if the message is received by the gateway? This is possible although the node reports nack.
      • H
        H
        Henrik Nielsen
        @Yveaux I checked, and no, the gateway does not receive the wake up message with payload 1000. It does receive the pre-sleep message with 500 ms, so I'm pretty sure I'm looking the right place :)
        berkseoB 1 Reply Last reply
        • H Henrik Nielsen
          Hi
            smartSleep(1000);
          26 TSM:INIT
          28 TSF:WUR:MS=0
          36 TSM:INIT:TSP OK
          40 TSM:FPAR
          2084 TSM:FPAR:OK
          2084 TSM:ID
          2086 TSM:ID:OK
          2088 TSM:UPL
          2150 TSM:UPL:OK
          2428 MCO:REG:REQ
          3037 TSF:TDI:TSL
          3039 MCO:SLP:WUP=-1
          3041 TSF:TRI:TSB
          5984 TSF:TDI:TSL
          5986 MCO:SLP:WUP=-1
          5988 TSF:TRI:TSB
          8931 TSF:TDI:TSL
          8933 MCO:SLP:WUP=-1
          /Henrik
          berkseoB
          berkseoB
          berkseo
          @henrik-nielsen
          Hello, there may be a problem with the repeater. ACK and NOACK are confirmation of sending to the first node in the chain(that is, in your case to the repeater). Try turning off this repeater so that the sender receives a new route. I also recommend using the sleep function with the attribute of smart sleep mode activation -- sleep(1000, true);
          • H Henrik Nielsen
            berkseoB
            berkseoB
            berkseo
            wrote on last edited by berkseo
            @henrik-nielsen
            Try adding a little wait after the line with sleep, it will slow down the sketch but the framework will continue to work wait(200); ...not sure.
            • H
              H
              Henrik Nielsen
              @berkseo Thank you for your suggestions, I have tried both.
              • I moved the node up right next to the gateway, so there are no repeaters in between. I still get NACK on the wake up message. And I can see in the gateway log that the wake up message are not received by the gateway. The other message still shows up just fine. In the output below you can see it sends directly to node 0
              • I also added a wait(200) after the sleep, still get the same error, but I guess it is because the wake up message are sent before the sleep method returns?
              • Using sleep(1000, true) instead of smartSleep, same result, but I'll start using sleep(nnn, true) instead anyway :)
              New code:
              #define MY_RF24_BASE_RADIO_ID 0x00,0xf6,0x4d,0x89,0xc0
                sleep(1000, true);
                wait(200);
              Output:
              16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
              26 TSM:INIT
              28 TSF:WUR:MS=0
              34 TSM:INIT:TSP OK
              36 TSF:SID:OK,ID=204
              38 TSM:FPAR
              75 TSF:MSG:SEND,204-204-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              686 TSF:MSG:READ,0-0-204,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              692 TSF:MSG:FPAR OK,ID=0,D=1
              708 TSF:MSG:READ,0-201-204,s=255,c=3,t=25,pt=1,l=1,sg=0:2
              714 !TSF:MSG:PONG RECV,INACTIVE
              854 TSF:MSG:READ,202-202-204,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              880 TSF:MSG:READ,203-203-204,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              2084 TSM:FPAR:OK
              2084 TSM:ID
              2086 TSM:ID:OK
              2088 TSM:UPL
              2093 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2101 TSF:MSG:READ,0-0-204,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2107 TSF:MSG:PONG RECV,HP=1
              2109 TSM:UPL:OK
              2111 TSM:READY:ID=204,PAR=0,DIS=1
              2117 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2127 TSF:MSG:READ,0-0-204,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2136 TSF:MSG:SEND,204-204-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
              2146 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2242 TSF:MSG:READ,0-0-204,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              2254 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:SmartSleepTest
              2265 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              2275 TSF:MSG:SEND,204-204-0-0,s=1,c=0,t=36,pt=0,l=4,sg=0,ft=0,st=OK:Info
              2283 MCO:REG:REQ
              2289 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              2297 TSF:MSG:READ,0-0-204,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2304 MCO:PIM:NODE REG=1
              2308 MCO:BGN:INIT OK,TSP=1
              2310 MCO:SLP:MS=1000,SMS=1,I1=255,M1=255,I2=255,M2=255
              2318 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
              2826 TSF:TDI:TSL
              2828 MCO:SLP:WUP=-1
              2830 TSF:TRI:TSB
              4513 !TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:1000
              4722 MCO:SLP:MS=1000,SMS=1,I1=255,M1=255,I2=255,M2=255
              4728 TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:500
              5238 TSF:TDI:TSL
              5240 MCO:SLP:WUP=-1
              5242 TSF:TRI:TSB
              6926 !TSF:MSG:SEND,204-204-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:1000
              • H Henrik Nielsen
                New code:
                  sleep(1000, true);
                  wait(200);
                Output:
                26 TSM:INIT
                28 TSF:WUR:MS=0
                34 TSM:INIT:TSP OK
                38 TSM:FPAR
                2084 TSM:FPAR:OK
                2084 TSM:ID
                2086 TSM:ID:OK
                2088 TSM:UPL
                2109 TSM:UPL:OK
                2283 MCO:REG:REQ
                2826 TSF:TDI:TSL
                2828 MCO:SLP:WUP=-1
                2830 TSF:TRI:TSB
                5238 TSF:TDI:TSL
                5240 MCO:SLP:WUP=-1
                5242 TSF:TRI:TSB
                berkseoB
                berkseoB
                berkseo
                @henrik-nielsen
                The problem is deeper, you came across an interesting point, I did not notice it before... left to dig the problem
                • H
                  H
                  Henrik Nielsen
                  I guess if I could just turn off the wake up / post-sleep message, everything would still kinda work. MyController will react to the pre-sleep message and send any pending messages, so the problem is just the 2 seconds of wasted battery everytime it try to send the wake up messages.
                  There might of course be other implications that I am not aware of :)
                  • H Henrik Nielsen
                    berkseoB
                    berkseoB
                    berkseo
                    @henrik-nielsen
                    I banished your sketch. Faced the same problem, have not seen before. As it turned out, this is a problem of quality of radio modules and radio driver settings. The solution is described below.
                    Was before:
                     __  __       ____
                            |___/                      2.3.1-alpha
                    18 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-alpha
                    28 TSM:INIT
                    28 TSF:WUR:MS=0
                    36 TSM:INIT:TSP OK
                    38 TSF:SID:OK,ID=100
                    40 TSM:FPAR
                    77 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    600 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    606 TSF:MSG:FPAR OK,ID=0,D=1
                    2088 TSM:FPAR:OK
                    2088 TSM:ID
                    2091 TSM:ID:OK
                    2093 TSM:UPL
                    2099 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2205 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2211 TSF:MSG:PONG RECV,HP=1
                    2215 TSM:UPL:OK
                    2217 TSM:READY:ID=100,PAR=0,DIS=1
                    2222 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2357 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2365 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.3.1-alpha
                    2375 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2838 TSF:MSG:READ,0-0-100,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    2846 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:SmartSleepTest
                    2856 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                    2867 TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=36,pt=0,l=4,sg=0,ft=0,st=OK:Info
                    2875 MCO:REG:REQ
                    2912 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                    4923 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                    4995 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    5001 MCO:PIM:NODE REG=1
                    5003 MCO:BGN:STP
                    5005 MCO:BGN:INIT OK,TSP=1
                    6008 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
                    6017 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
                    6625 TSF:TDI:TSL
                    6627 MCO:SLP:WUP=-1
                    6629 TSF:TRI:TSB
                    8312 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:3000
                    10524 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
                    10532 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:600
                    11141 TSF:TDI:TSL
                    11143 MCO:SLP:WUP=-1
                    11145 TSF:TRI:TSB
                    12828 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:3000
                    15036 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
                    15044 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:600
                    15652 TSF:TDI:TSL
                    1.Go to the folder - C:\Users\Andrey\Documents\Arduino\libraries\MySensors-development
                    2.Next, go to the folder - \drivers\RF24
                    3.Open the file - RF24registers.h
                    4.Change the parameters to these:
                    ...lines 42-47.
                    // ARD, auto retry delay
                    #define RF24_SET_ARD (10)
                    // ARD, auto retry count
                    #define RF24_SET_ARC (15)
                    5.Next, open the file-RF24.ccp
                    ...line 67
                    ...line 114
                    delayMicroseconds(100);
                    The problem in radio driver, in his settings, apparently all wrote according to the Datasheet, but in life a bit otherwise)))
                    Has now become:
                     __  __       ____
                            |___/                      2.3.1-alpha
                    28 TSM:INIT
                    28 TSF:WUR:MS=0
                    38 TSM:INIT:TSP OK
                    43 TSF:SID:OK,ID=100
                    45 TSM:FPAR
                    102 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2111 !TSM:FPAR:NO REPLY
                    2113 TSM:FPAR
                    2170 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2736 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    2742 TSF:MSG:FPAR OK,ID=0,D=1
                    4182 TSM:FPAR:OK
                    4182 TSM:ID
                    4184 TSM:ID:OK
                    4186 TSM:UPL
                    4194 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    4300 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    4306 TSF:MSG:PONG RECV,HP=1
                    4311 TSM:UPL:OK
                    4311 TSM:READY:ID=100,PAR=0,DIS=1
                    4319 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    4450 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    4462 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.3.1-alpha
                    4474 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    4939 TSF:MSG:READ,0-0-100,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    4950 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:SmartSleepTest
                    4966 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                    4976 TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=36,pt=0,l=4,sg=0,ft=0,st=OK:Info
                    4984 MCO:REG:REQ
                    5021 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    5308 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    5314 MCO:PIM:NODE REG=1
                    5316 MCO:BGN:STP
                    5318 MCO:BGN:INIT OK,TSP=1
                    6322 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
                    6334 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
                    6942 TSF:TDI:TSL
                    6944 MCO:SLP:WUP=-1
                    6946 TSF:TRI:TSB
                    6952 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:3000
                    9164 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
                    9177 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
                    9785 TSF:TDI:TSL
                    9787 MCO:SLP:WUP=-1
                    9789 TSF:TRI:TSB
                    9797 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:3000
                    12005 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
                    12017 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
                    12625 TSF:TDI:TSL
                    use.. ;)
                    • H
                      H
                      Henrik Nielsen
                      It works :D You're a wizard @berkseo :)
                      I do infact use the cheap radio modules from china, so I think you're right about the possible lacking of quality in the hardware :/
                      I guess there is not a way I can change these settings somewhere local to my sketch, so they do not get overwritten the next time I update the MySensors lib?
                      Anyway, it's great that it works now, and I will just bookmark this topic for future reference.
                      Thank again for your assistance :)
                      • H Henrik Nielsen
                        berkseoB
                        berkseoB
                        berkseo
                        @henrik-nielsen
                        Everyone uses cheap radio modules, it's a reality. One thing is technical specifications, the other is real network on real equipment. Although I think if you take a very original radios, it will be the same in 99%)). ....Glad to help, it's called a community.
                        H 1 Reply Last reply
                        • berkseoB berkseo
                          @henrik-nielsen
                          H
                          H
                          Henrik Nielsen
                          @berkseo I just started wondering if "everyone" uses cheap chinese radios, should this fix be part of the official code base?
                          Maybe just as something that could be enabled if needed.
                          scalzS 1 Reply Last reply
                          • H Henrik Nielsen
                            scalzS
                            scalzS
                            wrote on last edited by scalz
                            @henrik-nielsen said in SmartSleep wake up message always get NACK:
                            simple! add issue or pull request to mysensors github. that's the easiest way when there's issue to fix ;)
                            because the team can't follow all forum topics and make todolist, in this way this is not handy.
                            • scalzS scalz
                              berkseoB
                              berkseoB
                              berkseo
                              @scalz said in SmartSleep wake up message always get NACK:
                              pull request
                              I made a pull request. I think that this will accept. Apparently the next version will already be. ...I'm not sure this is absolutely perfect, a mistake in the first message after sleeping mostly. Perhaps later it is better to modify startListening, although, of course, now it is a good solution, but not ideal.
                              H M 2 Replies Last reply
                              • berkseoB berkseo
                                pull request
                                H
                                H
                                Henrik Nielsen
                                @berkseo Great :) I am currently trying to figure out what my employers policy for open source contributions made in their employees spare time is, so I could make the pull request myself, but you beat me to it :(
                                • berkseoB berkseo
                                  pull request
                                  Memphis007
                                  @berkseo Hi, could you post the link to your pull request ? I don't see any traces of it in MySensors Github repository.
                                  BTW with my setup (genuine/good quality NRF24L01) increase lines 67 & 114 of RF24.ccp to 50 do the trick.
                                  Thanks.
                                  • M Memphis007
                                    Thanks.
                                    @memphis007 berseo's pull requests (link 1, link 2) were closed in favor of this pull request.
                                      Memphis007
                                      @mfalkvidd I have applied Tekka007 pull request successfully, all is working correctly now. Thanks !
