  3. SmartSleep wake up message always get NACK
18 Posts 6 Posters 4.7k Views 5 Watching
  • H
    H
    Henrik Nielsen
    I guess if I could just turn off the wake up / post-sleep message, everything would still kinda work. MyController will react to the pre-sleep message and send any pending messages, so the problem is just the 2 seconds of wasted battery everytime it try to send the wake up messages.
    There might of course be other implications that I am not aware of :)
    berkseoB 1 Reply Last reply
    • H Henrik Nielsen
      berkseoB
      berkseoB
      berkseo
      @henrik-nielsen
      I banished your sketch. Faced the same problem, have not seen before. As it turned out, this is a problem of quality of radio modules and radio driver settings. The solution is described below.
      Was before:
       __  __       ____
              |___/                      2.3.1-alpha
      18 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-alpha
      28 TSM:INIT
      28 TSF:WUR:MS=0
      36 TSM:INIT:TSP OK
      38 TSF:SID:OK,ID=100
      40 TSM:FPAR
      77 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      600 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      606 TSF:MSG:FPAR OK,ID=0,D=1
      2088 TSM:FPAR:OK
      2088 TSM:ID
      2091 TSM:ID:OK
      2093 TSM:UPL
      2099 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      2205 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      2211 TSF:MSG:PONG RECV,HP=1
      2215 TSM:UPL:OK
      2217 TSM:READY:ID=100,PAR=0,DIS=1
      2222 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      2357 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      2365 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.3.1-alpha
      2375 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      2838 TSF:MSG:READ,0-0-100,s=255,c=3,t=6,pt=0,l=1,sg=0:M
      2846 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:SmartSleepTest
      2856 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
      2867 TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=36,pt=0,l=4,sg=0,ft=0,st=OK:Info
      2875 MCO:REG:REQ
      2912 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
      4923 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
      4995 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      5001 MCO:PIM:NODE REG=1
      5003 MCO:BGN:STP
      5005 MCO:BGN:INIT OK,TSP=1
      6008 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
      6017 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
      6625 TSF:TDI:TSL
      6627 MCO:SLP:WUP=-1
      6629 TSF:TRI:TSB
      8312 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:3000
      10524 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
      10532 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:600
      11141 TSF:TDI:TSL
      11143 MCO:SLP:WUP=-1
      11145 TSF:TRI:TSB
      12828 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:3000
      15036 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
      15044 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=1,st=OK:600
      15652 TSF:TDI:TSL
      1.Go to the folder - C:\Users\Andrey\Documents\Arduino\libraries\MySensors-development
      2.Next, go to the folder - \drivers\RF24
      3.Open the file - RF24registers.h
      4.Change the parameters to these:
      ...lines 42-47.
      // ARD, auto retry delay
      #define RF24_SET_ARD (10)
      // ARD, auto retry count
      #define RF24_SET_ARC (15)
      5.Next, open the file-RF24.ccp
      ...line 67
      ...line 114
      delayMicroseconds(100);
      The problem in radio driver, in his settings, apparently all wrote according to the Datasheet, but in life a bit otherwise)))
      Has now become:
       __  __       ____
              |___/                      2.3.1-alpha
      28 TSM:INIT
      28 TSF:WUR:MS=0
      38 TSM:INIT:TSP OK
      43 TSF:SID:OK,ID=100
      45 TSM:FPAR
      102 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2111 !TSM:FPAR:NO REPLY
      2113 TSM:FPAR
      2170 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2736 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      2742 TSF:MSG:FPAR OK,ID=0,D=1
      4182 TSM:FPAR:OK
      4182 TSM:ID
      4184 TSM:ID:OK
      4186 TSM:UPL
      4194 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      4300 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      4306 TSF:MSG:PONG RECV,HP=1
      4311 TSM:UPL:OK
      4311 TSM:READY:ID=100,PAR=0,DIS=1
      4319 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      4450 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      4462 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.3.1-alpha
      4474 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      4939 TSF:MSG:READ,0-0-100,s=255,c=3,t=6,pt=0,l=1,sg=0:M
      4950 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=0,st=OK:SmartSleepTest
      4966 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
      4976 TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=36,pt=0,l=4,sg=0,ft=0,st=OK:Info
      4984 MCO:REG:REQ
      5021 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
      5308 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
      5314 MCO:PIM:NODE REG=1
      5316 MCO:BGN:STP
      5318 MCO:BGN:INIT OK,TSP=1
      6322 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
      6334 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
      6942 TSF:TDI:TSL
      6944 MCO:SLP:WUP=-1
      6946 TSF:TRI:TSB
      6952 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:3000
      9164 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
      9177 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
      9785 TSF:TDI:TSL
      9787 MCO:SLP:WUP=-1
      9789 TSF:TRI:TSB
      9797 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:3000
      12005 MCO:SLP:MS=3000,SMS=1,I1=0,M1=3,I2=255,M2=255
      12017 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:600
      12625 TSF:TDI:TSL
      use.. ;)
      • H
        H
        Henrik Nielsen
        It works :D You're a wizard @berkseo :)
        I do infact use the cheap radio modules from china, so I think you're right about the possible lacking of quality in the hardware :/
        I guess there is not a way I can change these settings somewhere local to my sketch, so they do not get overwritten the next time I update the MySensors lib?
        Anyway, it's great that it works now, and I will just bookmark this topic for future reference.
        Thank again for your assistance :)
        • H Henrik Nielsen
          berkseoB
          berkseoB
          berkseo
          @henrik-nielsen
          Everyone uses cheap radio modules, it's a reality. One thing is technical specifications, the other is real network on real equipment. Although I think if you take a very original radios, it will be the same in 99%)). ....Glad to help, it's called a community.
          H 1 Reply Last reply
          • berkseoB berkseo
            @henrik-nielsen
            H
            H
            Henrik Nielsen
            @berkseo I just started wondering if "everyone" uses cheap chinese radios, should this fix be part of the official code base?
            Maybe just as something that could be enabled if needed.
            scalzS 1 Reply Last reply
            • H Henrik Nielsen
              @henrik-nielsen said in SmartSleep wake up message always get NACK:
              simple! add issue or pull request to mysensors github. that's the easiest way when there's issue to fix ;)
              because the team can't follow all forum topics and make todolist, in this way this is not handy.
              • scalzS scalz
                berkseoB
                berkseoB
                berkseo
                @scalz said in SmartSleep wake up message always get NACK:
                pull request
                I made a pull request. I think that this will accept. Apparently the next version will already be. ...I'm not sure this is absolutely perfect, a mistake in the first message after sleeping mostly. Perhaps later it is better to modify startListening, although, of course, now it is a good solution, but not ideal.
                H M 2 Replies Last reply
                • berkseoB berkseo
                  pull request
                  H
                  H
                  Henrik Nielsen
                  @berkseo Great :) I am currently trying to figure out what my employers policy for open source contributions made in their employees spare time is, so I could make the pull request myself, but you beat me to it :(
                  • berkseoB berkseo
                    pull request
                    Memphis007
                    @berkseo Hi, could you post the link to your pull request ? I don't see any traces of it in MySensors Github repository.
                    BTW with my setup (genuine/good quality NRF24L01) increase lines 67 & 114 of RF24.ccp to 50 do the trick.
                    • M Memphis007
                      @memphis007 berseo's pull requests (link 1, link 2) were closed in favor of this pull request.
                        Memphis007
                        @mfalkvidd I have applied Tekka007 pull request successfully, all is working correctly now. Thanks !
