  2. Bug Reports
  3. [SOLVED] Gateway RS485
22 Posts 4 Posters 6.2k Views 5 Watching
    @philippe-57 do you have any idea how SoftwareSerial could work when there was an error on the PCB?
    P
    P
    Philippe 57
    @mfalkvidd yes I said it works with the test sketch and I do not know why, what I saw on my PCB is that the frame go in one direction and that's why with mysensors the gateway was not answering
    order placed for new PCBs, waiting now
    • P Philippe 57
      Hello everyone
      I found my problem, it comes from my PCB there is an error on the tracks, I ordered again corrected PCB and I come back to you when I could do the tests. it takes at least 15 days / 3 weeks
      thanks again for your help i get back to you as soon as possible
      K
      K
      kimot
      @philippe-57
      And why wait 3 weeks for new PCB?
      Simply cut bad connections on PCB a and make correct connection with wire.
      And four RS485 connectors on gateway?
      RS 485 is bus - from one node to next, all in one line.
      Not star topology.
      If you plan connect four nodes with 20 m of cable to those connectors - you will be in troubles.
      Gateway must be connected like other normal nodes. Only sw is different.
