  3. SOLVED : SI7021 T/H Powerdrain NRF52
2 Posts 1 Posters 1.1k Views 1 Watching
  • O
    O
    Omemanti
    wrote on last edited by Omemanti
    Hey,
    I got a question, I've built a PCB with a PIR-motion detector and a SI7021 temp/Hum sensor.
    It all works great except for the power usage when the sensor is asleep.
    Two scenarios happen, that I can't quite explain, but hopefully someone here can.
    1. The power consumption is under the 0.01 when I only use the PIR sensor.
    2. When I include sensor.begin(); the sleeping current jumps to 0.46 mA.
    When I comment the "sensor.begin();" out it returns to 0.01mA.
    schematic etc: https://www.openhardware.io/view/617/NRF52-Wall-Node-3-AAA
    -- Might it be that is has something to do with it using a NRF52?
    #define MY_RADIO_NRF5_ESB
    #define MY_NODE_ID 214
    #define SKETCH_NAME "PIR TESTING"
    #define SKETCH_VERSION "v0.1"
    int PIRLED = 29;
    int ActLED = 6;
    int PIR_pin = 2;
    int a;
    int b;
    #include <Wire.h>
    #include <SI7021.h>
    SI7021 sensor;
      Serial.begin(115200);
      sensor.begin();
      pinMode(PIRLED, OUTPUT);
      pinMode(ActLED, OUTPUT);
      pinMode(PIR_pin, INPUT);
    sleep(5000);
    a = digitalRead(PIR_pin);
    Serial.println(a);
    delay(500);
    • O
      O
      Omemanti
      https://forum.mysensors.org/topic/6961/nrf5-action/1659
      That fixed it.
