  3. Arduino Uno with Ethernet Shield W5100 not working
15 Posts 6 Posters 4.6k Views 5 Watching
  • kduinoK
    kduinoK
    kduino
    wrote on last edited by kduino
    I have trouble with my ethernet shield.
    I tried different methods and there where different publications on how to connect, but in the end I was not able to get it running.
    I tried: CE and CS pin on 6 and 5 with and without changing MISO/MOSI/SCK to A0 to A2, but the best result I got was an error free start of the gateway but not receiving any data from nodes so far (connection to ip network seems to be fine, at least the ip is declared via dhcp). The same setting was doing great without ethernet shield. Tried it also on a Mega but without success...
    To sort out the power issue I put an extra 3.3 power regulator together with a big 470 microF capacitor which should do the trick.
    Any ideas? I will post the exact wirings in a few minutes.
    If you have one working in this setting, can you send me the exact sketch together with the wiring information?
    Thank you!
    Here are the details:
    Gateway Debug Print:
    0 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.3.0
    48 TSM:INIT
    49 TSF:WUR:MS=0
    56 TSM:INIT:TSP OK
    58 TSM:INIT:GW MODE
    60 TSM:READY:ID=0,PAR=0,DIS=0
    62 MCO:REG:NOT NEEDED
    8695 GWT:TIN:IP=192.168.178.45
    9698 MCO:BGN:STP
    9700 MCO:BGN:INIT OK,TSP=1
    Gateway code:
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    #define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    //#define MY_IP_ADDRESS 192,168,178,66
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, XYZ
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    // Singing issues:
    #define MY_SIGNING_SOFT
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A5
    Gateway Wiring:
    GatewayArduinoUno - nRF24L01
    A2 - MISO
    A1 - MOSI
    A0 - SCK
    6 - CSN/NSS
    5 - CE
    Node:
    Node Debug Print:
     __  __       ____
            |___/                      2.3.0
    16 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.3.0
    73 TSM:INIT
    74 TSF:WUR:MS=0
    81 TSM:INIT:TSP OK
    83 TSM:INIT:STATID=10
    86 TSF:SID:OK,ID=10
    87 TSM:FPAR
    123 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2131 !TSM:FPAR:NO REPLY
    2134 TSM:FPAR
    2169 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4178 !TSM:FPAR:NO REPLY
    4180 TSM:FPAR
    4216 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6225 !TSM:FPAR:NO REPLY
    6227 TSM:FPAR
    6263 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8271 !TSM:FPAR:FAIL
    8272 TSM:FAIL:CNT=1
    8274 TSM:FAIL:DIS
    8276 TSF:TDI:TSL
    Node Code:
    // Singing issues:
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A2
    //#define MY_SIGNING_REQUEST_SIGNATURES
    #define SKETCH_NAME "Binary Sensor"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
    #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
    #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
    #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
    #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
    #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
    #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
    #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
    MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
    MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
    	// Setup the buttons
    	pinMode(PRIMARY_BUTTON_PIN, INPUT_PULLUP);
    	pinMode(SECONDARY_BUTTON_PIN, INPUT_PULLUP);
    	sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
    	// Register binary input sensor to sensor_node (they will be created as child devices)
    	present(PRIMARY_CHILD_ID, S_DOOR);
    	present(SECONDARY_CHILD_ID, S_DOOR);
    	uint8_t value1, value2;
    	static uint8_t sentValue=2;
    	static uint8_t sentValue2=2;
    	sleep(5);
    	value1 = digitalRead(PRIMARY_BUTTON_PIN);
    	if (value1 != sentValue) {
    		// Value has changed from last transmission, send the updated value
    		send(msg.set(value1==HIGH));
    		sentValue = value1;
        Serial.print("Sensor1: "); Serial.println(value1);
    	value2 = digitalRead(SECONDARY_BUTTON_PIN);
    	if (value2 != sentValue2) {
    		send(msg2.set(value2==HIGH));
    		sentValue2 = value2;
        Serial.print("Sensor2: "); Serial.println(value2);
    	// Sleep until something happens with the sensor
    	sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-3, CHANGE, 0);
    Node Wiring:
    Arduino Nano Breakout Board with Connector (was working fine before).
    • kduinoK kduino
      Thank you!
      48 TSM:INIT
      49 TSF:WUR:MS=0
      56 TSM:INIT:TSP OK
      58 TSM:INIT:GW MODE
      9698 MCO:BGN:STP
      Gateway code:
      #define MY_SOFTSPI
      // Singing issues:
      Gateway Wiring:
      A2 - MISO
      A1 - MOSI
      A0 - SCK
      6 - CSN/NSS
      5 - CE
      Node:
      Node Debug Print:
       __  __       ____
              |___/                      2.3.0
      73 TSM:INIT
      74 TSF:WUR:MS=0
      81 TSM:INIT:TSP OK
      86 TSF:SID:OK,ID=10
      87 TSM:FPAR
      2134 TSM:FPAR
      4180 TSM:FPAR
      6227 TSM:FPAR
      8271 !TSM:FPAR:FAIL
      8272 TSM:FAIL:CNT=1
      8274 TSM:FAIL:DIS
      8276 TSF:TDI:TSL
      Node Code:
      // Singing issues:
      	sleep(5);
      		sentValue = value1;
      Node Wiring:
      @kduino looks like all functions (present, setup, loop) are missing.
      • kduinoK
        kduinoK
        kduino
        Hi, I've cut present, setup and loop not to waist to much space. I edit and add them too...
        Unfortunately as you can see, the gateway is not receiving anything and therefore not answering the node.
        I will test with different hardware now, if there is something weird.
        • kduinoK kduino
          @kduino thanks for clearing that up.
          st=OK:
          means that the node is getting a hardware acknowledgement on the sent message. So something (probably the gateway unless you have other MySensors nodes nearby) receives the message and acknowledges it, but then nothing happens.
          Could you add #define MY_DEBUG_VERBOSE_RF24 to both sketches to see if that can give a clue?
          • kduinoK
            kduinoK
            kduino
            Wow cool, so the hardware is basically running, but for some reason, the gateway doesn't accept the message.
            I'll double-check the signing algorithm (perhaps I comment it to see, if there are arriving unsigned messages) and I will post the result.
            Strange thing. Thank you very much!
            I'll do this tonight.
            AnticimexA 1 Reply Last reply
            • kduinoK kduino
              AnticimexA
              AnticimexA
              Anticimex
              @kduino looks like communication fails already during parent lookup. Signing should not kick in until after that so I don't think that is the issue. But you could always try to disable signing to see if it affects things (the added code from signing could lead to stack problems which might manifest itself in many obscure ways, in case you are limited in RAM).
              • kduinoK
                kduinoK
                kduino
                This is what is coming out of the gateway debug:
                53 TSM:INIT
                54 TSF:WUR:MS=0
                55 RF24:INIT
                56 RF24:INIT:PIN,CE=5,CS=6
                59 RF24:WBR:REG=0,VAL=14
                66 RF24:WBR:REG=3,VAL=3
                68 RF24:WBR:REG=4,VAL=95
                70 RF24:WBR:REG=5,VAL=76
                72 RF24:WBR:REG=6,VAL=37
                74 RF24:WBR:REG=16,VAL=115
                77 RF24:WBR:REG=29,VAL=4
                79 RF24:RBR:REG=6,VAL=37
                81 RF24:RBR:REG=5,VAL=76
                83 RF24:WBR:REG=2,VAL=2
                87 RF24:WBR:REG=1,VAL=0
                89 RF24:WBR:REG=28,VAL=3
                91 RF24:FRX
                92 RF24:FTX
                93 RF24:WBR:REG=7,VAL=112
                96 TSM:INIT:TSP OK
                97 TSM:INIT:GW MODE
                99 RF24:WBR:REG=2,VAL=3
                101 RF24:WBR:REG=1,VAL=1
                103 RF24:STL
                105 RF24:WBR:REG=0,VAL=15
                107 RF24:WBR:REG=10,VAL=0
                109 TSM:READY:ID=0,PAR=0,DIS=0
                112 MCO:REG:NOT NEEDED
                114 RF24:RBR:REG=23,VAL=17
                16766 GWT:TIN:IP=192.168.178.XYZ
                17769 MCO:BGN:STP
                17771 RF24:RBR:REG=6,VAL=37
                17774 RF24:RBR:REG=5,VAL=76
                17776 MCO:BGN:INIT OK,TSP=1
                17779 RF24:RBR:REG=23,VAL=17
                17782 RF24:RBR:REG=23,VAL=17
                17784 RF24:RBR:REG=23,VAL=17
                17787 RF24:RBR:REG=23,VAL=17
                Last line is repeating for ever
                Just to be sure I insert the gateway code again:
                #define MY_SOFTSPI
                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 46
                // Singing issues:
                • kduinoK
                  kduinoK
                  kduino
                  What I have to mention: The setting was running great as a Serial Gateway config. But when I changed to ethernet gateway I was not able to restore this condition together with the W5100 shield. Moreover I don't know if the pin4 is making some trouble. As far as I know its used for writing to the sd card (which I don't use...).
                  YveauxY 1 Reply Last reply
                  • kduinoK kduino
                    YveauxY
                    YveauxY
                    @kduino Could you give this a try? Add the following to your sketch:
                    #define SD_SS_PIN                     (4)  // chip-select for SD card (unused, pull high!)
                    void before() {
                        pinMode(SD_SS_PIN, OUTPUT);
                        digitalWrite(SD_SS_PIN, HIGH);
                    • kduinoK
                      kduinoK
                      kduino
                      I'll try this as soon as possible. Although the ip network connection doesn't seem to be the issue since ip dedication is without problem.
                      alexsh1A 1 Reply Last reply
                      • kduinoK kduino
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @kduino Did you manage so solve it please?
                        • SpannersS
                          SpannersS
                          Spanners
                          wrote on last edited by Spanners
                          I'm experiencing the same issue with 2x Uno+NRF24+W5100 Shields that I tried to upgrade from 2.2.0 to 2.3.1 yesterday with Arduino IDE 1.8.8
                          I didn't modify the sketch. It does nothing funky like run other sensors, use signing or encryption.
                          I have the code to disable the the SD reader in setup() already. Haven't tried in before() yet.
                          The devices had been working fine previously.
                          I have upgraded 2 other W5100 Ethernet gateways based on FreeTronics EtherTen and EtherMega to 2.3.1 with no issues.
                          I have upgraded a Nano based Repeater with 2.3.1 with no issues.
                          I have upgraded an Energy Monitoring Sensor with 2.3.1 and it works fine with the FreeTronics gateways but not with the Uno gateways.
                          On the Uno Gateways:
                          I have tried downgrading to MyS 2.2.0
                          I have tried downgrading Ethernet library from 2.0 to 1.x (can't remember exact version)
                          Tried downgrading the AVR boards definition in the IDE
                          Thus far have not been able to get them working on any combination of older code. Any suggestions on how to troubleshoot further would be most welcome.
                          • SpannersS Spanners
                            YveauxY
                            YveauxY
                            @spanners said in Arduino Uno with Ethernet Shield W5100 not working:
                            Please do so. It makes a big difference!
                            SpannersS 1 Reply Last reply
                            • YveauxY Yveaux
                              SpannersS
                              SpannersS
                              Spanners
                              @yveaux - unfortunately not that much of a difference that the two Uno's started working..
                              0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
                              16:26:38.766 -> 10006 TSM:INIT
                              16:26:38.766 -> 10008 TSF:WUR:MS=0
                              16:26:38.766 -> 10015 TSM:INIT:TSP OK
                              16:26:38.766 -> 10017 TSM:INIT:GW MODE
                              16:26:38.766 -> 10019 TSM:READY:ID=0,PAR=0,DIS=0
                              16:26:38.766 -> 10022 MCO:REG:NOT NEEDED
                              16:26:39.349 -> 10586 GWT:TIN:IP=10.0.0.244
                              16:26:40.337 -> 11589 MCO:BGN:STP
                              16:26:42.372 -> 13596 MCO:BGN:INIT OK,TSP=1
                              16:26:42.372 -> 13603 TSM:READY:NWD REQ
                              16:26:42.399 -> 13641 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                              Then they just sit there.
                              With verbose NRF debug on:
                              20777 RF24:RBR:REG=23,VAL=17
                              20780 RF24:RBR:REG=23,VAL=17
                              20783 RF24:RBR:REG=23,VAL=17
                              20786 RF24:RBR:REG=23,VAL=17
                              20788 RF24:RBR:REG=23,VAL=17
                              20791 RF24:RBR:REG=23,VAL=17
                              20794 RF24:RBR:REG=23,VAL=17
                              20796 RF24:RBR:REG=23,VAL=17
                              20799 RF24:RBR:REG=23,VAL=17
                              Goes on forever
                              Edit:
                              /epic_facepalm Tried everything including downgrading the IDE to 1.8.5, all the libraries etc..
                              Out of desperation I thought I'd try the Uno Gateways on the same MY_RF24_CHANNEL/MY_RF24_BASE_RADIO_ID as my production MyS network and they started picking up transmits.
                              Focus now changed to the test sensor. I started replacing hardware and discovered a flaky Dupont pin for the GND connection on my NRF radio... on the sensor I was using to test with.. of course... So between validating that my test sensor worked on the other gateways and then testing the upgraded gateways, the sensor ceased transmitting reliably.
                              That my friends, is Murphy's law as applied to MySensors builds.
                                Goes on forever
                                Edit:
                                YveauxY
                                YveauxY
                                @spanners I told you it would make a big difference :-)
                                Thanks for reporting back!
