  3. Using the relay actuator example to light LED directly off the digital outputs?
1 Posts 1 Posters 652 Views 1 Watching
  • S
    StKilda
    Hey. I've successfully set up an energy pulse sensor talking via a gateway to a Raspberry pi (running Domoticz) (Yay!). While I can see the Watts data on Domoticz - I want to display some elements in a basic format. For example when watts is zero to light an LED on a remote display and When watts is greater than x to light a different LED.
    Looking at the relay actuator example - it seems I could pretty much use this code telling the arduino that it's controlling x "relays" and then running the led (and series resistor) off the digital output?
    Does domoticz pick up the fact that the hardware has x relays and allow me to then use blocky to logic which "relays" (ie LED) are activated etc?
    Thanks for the help!
    StKilda
