  3. Vera
  4. Mysensors, Vera and UI7
veramysensor 1.4ui7
4 Posts 2 Posters 3.6k Views 1 Watching
  • D
    D
    Dean
    I'm still having problems with communication between my sensors and my Vera 3. I have no issues with updates coming from the sensor, but when I send a message to a sensor it doesn't always work. The wife is getting a title frustrated when lights won't turn on at night.....
    I seem to be having this issue around the same time i upgraded from UI5 to UI7.. So my question is, do we have anyone here who has actually found UI7 to work just as well for them as UI5?
    • D
      D
      Dean
      I guess there must be something going on with me hardware if I'm the only one with this issue..
      • K
        K
        kalle
        Maybe it is a solution for you to downgrade to UI5, because it works fine with MySensors:
        http://download.mios.com/rt3662_betafirmware/rt3662_Luup_ui5-1.5.672-en-mios.squashfs
        "Then from SETUP > Firmware under : Advanced: URL for Vera custom firmware: paste it and press on download.
        Save a back-up when you are prompted and start the upgrade.
        The upgrade can take up to 15-20 minutes and you should be on the same location with the unit when you do it."
        • D
          D
          Dean
          I was running UI5 for a while but thought I would take a stab at UI7 again. I'm now back to UI5.
