  3. Can't even get a base Mysensors sketch to work
7 Posts 4 Posters 1.3k Views 4 Watching
  • HomerH
    HomerH
    Homer
    Hi all
    I want to create a sensor which is a motion sensor and a controller of two dimmable LED strips. When I upload the sketch that I hope will work, it looks like the motion part of it doesn't stop sending info, so I decided to start small to try and work out the issue.
    When I upload the Dimming LED sketch on its own, it all seems to work fine according to the serial monitor. Then I wipe the arduino and upload the motion part only, and the serial monitor goes crazy! The Mysensors sign or whatever it's called shows in the serial monitor, then it scrolls on and on, printing either a '1' or '0' on each line and it doesn't stop, and it's FAST!
    I am using an Arduino Nano. The motion sketch is the base example provided on Mysensors, but here it is anyways:
    // Enable debug prints
    // #define MY_DEBUG
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
        present(CHILD_ID, S_MOTION);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
    I have even tried this sketch as it is on another Arduino Nano and I still get the same result. I'm keen to hear your thoughts.
    • HomerH
      HomerH
      Homer
      OK.... I have solved the biggest issue by rebooting my computer. Silly me! The base motion sketch works as it should, kind of.... it does seem to be sending messages quite quickly. Anyways I have uploaded my motion and 2 led dimmer sketch and am in the process of joining it to my Vera Controller, but it still does seem to be sending messages very often. Can someone review my sketch and offer feedback? Please note that I did take the very easy route and adapted a RGB controller sketch for the led dimming part; I plan to just be using 2 of the lights in the sketch to control my 2 led strips. When I have more time I plan to learn how to do it properly.
      Here is the sketch as it stands:
      #define SN   "Motion+2 LED Dimmer"
      #define SV   "v1"
      //#define MY_REPEATER_FEATURE
      #define CHILD_ID 7   // Id of the sensor child
      // Arduino pin attached to MOSFET Gate pin
      #define RED_PIN 7
      #define GREEN_PIN 5
      #define BLUE_PIN 6
      // Define message name and type to send sensor info
      MyMessage RedStatus(RED_PIN, V_DIMMER);
      MyMessage GreenStatus(GREEN_PIN, V_DIMMER);
      MyMessage BlueStatus(BLUE_PIN, V_DIMMER);
      MyMessage Status(1, V_DIMMER);
      MyMessage rgbShowState(0, V_LIGHT);
      // Serial.print translate sensor id to sensor name
      char color[][6] = {"","","","RED","","GREEN","BLUE"};
      // Vars for rgbShow function
      int redval = 0;
      int greenval = 0;
      int blueval = 0;
      long time=0;
      int isShow;
        // Define pin mode (pin number, type)
        pinMode(RED_PIN, OUTPUT);
        pinMode(GREEN_PIN, OUTPUT);
        pinMode(BLUE_PIN, OUTPUT);
        // Correct saved RGB value for first start
        saveState(RED_PIN, constrain((int8_t)loadState(RED_PIN), 0, 100));
        saveState(GREEN_PIN, constrain((int8_t)loadState(GREEN_PIN), 0, 100));
        saveState(BLUE_PIN, constrain((int8_t)loadState(BLUE_PIN), 0, 100));
        // Get value from eeprom and write to output
        analogWrite(RED_PIN, 255 * loadState(RED_PIN) / 100);
        analogWrite(GREEN_PIN, 255 * loadState(GREEN_PIN) / 100);
        analogWrite(BLUE_PIN, 255 * loadState(BLUE_PIN) / 100);
        Serial.print("Load from eeprom RED: ");
        Serial.print(loadState(RED_PIN));
        Serial.println("%");
        Serial.print("Load from eeprom GREEN: ");
        Serial.print(loadState(GREEN_PIN));
        Serial.print("Load from eeprom BLUE: ");
        Serial.print(loadState(BLUE_PIN));
        // Send RGB value to controler (request ack back: true/false)
        Serial.println("Send eeprom value to controler");
        send( RedStatus.set(loadState(RED_PIN)), false );
        send( GreenStatus.set(loadState(GREEN_PIN)), false );
        send( BlueStatus.set(loadState(BLUE_PIN)), false );
        // Correct RGB show state for first start and load it (set to 'On' at first start)
        saveState(0, constrain((int8_t)loadState(0), 0, 1));
        isShow=loadState(0);
        // Send RGB show state to controler (request ack back: true/false)
        send( rgbShowState.set(isShow), false);
        if (isShow==1){Serial.println("RGB show running..."); }
        Serial.println("Ready to receive messages...");
      void presentation()  {
        // Present sketch (name, version)
        sendSketchInfo(SN, SV);
        // Register sensors (id, type, description, ack back)
        present(RED_PIN, S_DIMMER, "RED LED", false);
        present(GREEN_PIN, S_DIMMER, "GREEN LED", false);
        present(BLUE_PIN, S_DIMMER, "BLUE LED", false);
        present(0, S_LIGHT, "Show button LEDs", false);
        // Register Motion sensor to gw (they will be created as child devices)
        if (message.isAck())
          Serial.println("Got ack from gateway");
        if (message.type == V_LIGHT)
          // Incoming on/off command sent from controller ("1" or "0")
          int lightState = message.getString()[0] == '1';
          // if receive RGB Show On commands, start the show
          if (message.sensor==0 && lightState==1){ rgbShowOn(); }
              // if receive RGB Show Off commands, stop the show
          else if (message.sensor==0 && lightState==0){ rgbShowOff(); }
          // if receive RGB switch On command
          else if (lightState==1)
                  Serial.print("Incoming change for ");
                  Serial.print(color[message.sensor]);
                  Serial.println(": On");
                  Serial.print("Load from eeprom: ");
            if ( loadState(message.sensor) == 0)
              // Pick up last saved dimmer level from the eeprom
                      analogWrite(message.sensor, 255 * loadState(10*message.sensor) / 100);
                      // Save loaded value to current
                      saveState(message.sensor, loadState(10*message.sensor));
                      Serial.print(loadState(10*message.sensor));
                      // Send value to controler
                      Serial.println("Send value to controler");
                      send(Status.setSensor(message.sensor).set(loadState(10*message.sensor)),false);
                      analogWrite(message.sensor, 255 * loadState(message.sensor) / 100);
                      Serial.print(loadState(message.sensor));
                      send(Status.setSensor(message.sensor).set(loadState(message.sensor)),false);
                  // Stop the show if it's running
                  if (isShow==1){ rgbShowStop(message.sensor); }
          // if recieve switch Off command
          else if (lightState==0)
            // Write output to 0 (Off)
                  analogWrite(message.sensor, 0);
                  // Save old value to eeprom if it'was not zero
                  if ( loadState(message.sensor) != 0 )
                      saveState(10*message.sensor, constrain((int8_t)loadState(message.sensor), 0, 100));
                  // Save new value to eeprom
                  saveState(message.sensor, 0);
            Serial.print(": ");
            Serial.println("Off");
                  Serial.print("Store old value: ");
        else if (message.type == V_DIMMER)
            uint8_t incomingDimmerStatus = message.getByte();
            // limits range of sensor values to between 0 and 100
            incomingDimmerStatus = constrain((int8_t)incomingDimmerStatus, 0, 100);
            // Change Dimmer level
            analogWrite(message.sensor, 255 * incomingDimmerStatus / 100);
            //Save value to eeprom
            saveState(message.sensor, incomingDimmerStatus);
            Serial.print(": ");
            Serial.print(incomingDimmerStatus);
      void rgbShow()
        time = millis();
        redval = 128+250*cos(2*PI/300000*time);
        greenval = 128+250*cos(2*PI/300000*time-222);
        blueval = 128+250*cos(2*PI/300000*time-111);
        // limits range of sensor values to between 0 and 255
        redval = constrain(redval, 0, 255);
        greenval = constrain(greenval, 0, 255);
        blueval = constrain(blueval, 0, 255);
      void rgbShowOn()
        // define show On
        isShow=1;
        // Save state
        saveState(0, 1);
        Serial.println("Show must go on");
      void rgbShowOff()
        // define show Off
        isShow=0;
        // Save state
        saveState(0, 0);
        // Save RGB value to eeprom
        saveState(RED_PIN, 100 * redval / 255);
        saveState(GREEN_PIN, 100 * greenval / 255);
        saveState(BLUE_PIN, 100 * blueval / 255);
        Serial.println("Stop the show");
        // Send actual RGB value and state to controler and request ack back (true/false)
        send( rgbShowState.set(0), false);
      void rgbShowStop(int sensor)
         // define show Off
         isShow=0;
         // Save state
         saveState(0, 0);
         if (sensor != RED_PIN)
          if (sensor != GREEN_PIN)
          if (sensor != BLUE_PIN)
      YveauxY electrikE 2 Replies Last reply
      • HomerH Homer
        #define SV   "v1"
        #define RED_PIN 7
        #define GREEN_PIN 5
        #define BLUE_PIN 6
        int redval = 0;
        int greenval = 0;
        int blueval = 0;
        long time=0;
        int isShow;
              Serial.print(": ");
              Serial.print(": ");
        void rgbShow()
          time = millis();
        void rgbShowOn()
          // define show On
          isShow=1;
          // Save state
          saveState(0, 1);
        void rgbShowOff()
          // define show Off
          isShow=0;
          // Save state
          saveState(0, 0);
           // define show Off
           isShow=0;
           // Save state
           saveState(0, 0);
        @homer I've had good results by introducing a short wait time before sleeping ; e.g use wait(30000) to ignore any false triggers from the sensor.
        F 1 Reply Last reply
        • YveauxY Yveaux
          F
          F
          FlyingDomotic
          @yveaux: Would 30 seconds be a short wait time? ;-)
          • HomerH Homer
            #define SV   "v1"
            #define RED_PIN 7
            #define GREEN_PIN 5
            #define BLUE_PIN 6
            int redval = 0;
            int greenval = 0;
            int blueval = 0;
            long time=0;
            int isShow;
                  Serial.print(": ");
                  Serial.print(": ");
            void rgbShow()
              time = millis();
            void rgbShowOn()
              // define show On
              isShow=1;
              // Save state
              saveState(0, 1);
            void rgbShowOff()
              // define show Off
              isShow=0;
              // Save state
              saveState(0, 0);
               // define show Off
               isShow=0;
               // Save state
               saveState(0, 0);
            electrikE
            electrikE
            electrik
            @homer what information is shown on the serial monitor?
            • F FlyingDomotic
              @flyingdomotic said in Can't even get a base Mysensors sketch to work:
              For a PIR sensor I would say yes.
              A PIR triggers an alarm or switches on a lamp, so usually there is no need to do this more often than once every 30 seconds I would say.
              So what's the use in reporting the PIR triggers more often?
              • YveauxY Yveaux
                F
                F
                FlyingDomotic
                @yveaux : you're right! PIR are not so fast.
                12.5k
