  3. nRF5 Multi Sensor Board (12-14€)
52 Posts 24 Posters 30.6k Views 30 Watching
  • MiKaM
    MiKaM
    MiKa
    I got this error, what wrong???
    Using precompiled core
    "C:\Users\MiKa\AppData\Local\Arduino15\packages\sandeepmistry\tools\gcc-arm-none-eabi\5_2-2015q4/bin/arm-none-eabi-gcc" "-LC:\Users\MiKa\AppData\Local\Temp\arduino_build_372810" -Os -Wl,--gc-sections -save-temps "-LC:\Users\MiKa\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.5.1\cores\nRF5/SDK/components/toolchain/gcc/" "-LC:\Users\MiKa\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.5.1\cores\nRF5/SDK/components/softdevice/none/toolchain/armgcc/" "-Tnrf51_xxaa.ld" "-Wl,-Map,C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810/_22_Door_Sensor.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0 -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810/_22_Door_Sensor.ino.elf" "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch\app_error.c.o" "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch\app_error_weak.c.o" "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch\app_gpiote.c.o" "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch\MyBoardNRF5.cpp.o" "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch_22_Door_Sensor.ino.cpp.o" "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\core\variant.cpp.o" -Wl,--start-group -lm "C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810/..\arduino_cache_2928\core\core_MySensors_nRF5_MyBoard_nRF51822_chip_xxaa,bootcode_none,lfclk_lfxo_89b01c12b33d173746e7c52b6a4ab42a.a" -Wl,--end-group
    C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810/..\arduino_cache_2928\core\core_MySensors_nRF5_MyBoard_nRF51822_chip_xxaa,bootcode_none,lfclk_lfxo_89b01c12b33d173746e7c52b6a4ab42a.a(WInterrupts.c.o): In function `GPIOTE_IRQHandler':
    C:\Users\MiKa\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.5.1\cores\nRF5/WInterrupts.c:129: multiple definition of `GPIOTE_IRQHandler'
    C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch\app_gpiote.c.o:C:\Users\MiKa\AppData\Local\Temp\arduino_build_372810\sketch/app_gpiote.c:79: first defined here
    c:/users/mika/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .heap by 4 bytes
    c:/users/mika/appdata/local/arduino15/packages/sandeepmistry/tools/gcc-arm-none-eabi/5_2-2015q4/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .stack_dummy by 4 bytes
    Using library MySensors-development at version 2.3.0-alpha in folder: C:\Users\MiKa\Documents\Arduino\libraries\MySensors-development
    exit status 1
    Error compiling for board MyBoardNRF5 nRF51822.
    Nca78N 1 Reply Last reply
    • MiKaM MiKa
      exit status 1
      @mika sorry I think I forgot to include in the code the instruction :
      In the WInterrupt.c file before the GPIOTE_IRQHandler you need to include a weak attribute so it can be overridden :
      __attribute__ ((weak))
      void GPIOTE_IRQHandler()
      It's the file linked in your error message :
      • MiKaM
        MiKaM
        MiKa
        @nca78 said in nRF5 Multi Sensor Board (12-14€):
        attribute ((weak))
        Thanks,Compilation OK :+1:
          mechand
          Dear colleagues!
          I have this nice nRF51 sensor tag. May be you can help me to understand the limitations of this board.
          I want to make wireless water tank cap opening sensor. I have another device (my own development) with bluetooth BLE interface, with external power supply which will act as receiver.
          And I'd like to use nRF51 as wireless battery powered cap opening sensor. As I can understand in Aliexpress-version it is not possible (short battery life). I think I must make new firmware at least.
          But is it possible to do onboard ?
          1. Switch off BLE transmission but still make onboard analysis of fuel cap movement with MPU6050
          2. When cap open event is detected (my MPU6050 data) - wake up BLE and start transmission.
          Or may be Low power BLE mode will shut up MPU6050 transmission too and this mission is impossible?
          Many thanks!
          • M mechand
            Dear colleagues!
            Many thanks!
            @mechand use MySensors you can send a message only when you want without any tricks with BLE.
            And BLE/radio and accelerometer are 2 different things so you should be able to shut down BLE and go to sleep after configuring the accelerometer to generate an interrupt if it detects movement. But if you want to stick to BLE the solution is probably to advertise with big intervals, current battery drain is not due to BLE but due to a hardware problem with pin interrupts.
            • Nca78N Nca78
              mechand
              • A artag
                I got some of these from ebay, but they're fitted with nrf51802 QFAAA1 instead of a 51822. I can't find the memory sizes etc. for the 51802 - can they be used ?
                JokgiJ
                JokgiJ
                Jokgi
                @artag The nRF51802 QFAA has 256k Flash and 16k RAM. It is pin to pin compatible with the nRF51822QFAA in the QFN48 package, 6x6 mm. Note that some of the parameters for the nRF51802 are slightly looser then the nRF51822. (Current consumption, wakeup time, sensitivity)
                • alowhumA
                  alowhumA
                  alowhum
                  Are people still happy with / using this little device?
                  • G
                    G
                    Guy Sheffer
                    Looks like no one is active. I am also curious.
                    • Z
                      Z
                      zafirkalvin
                      wrote on last edited by zafirkalvin
                      #43
                      Im using now mainly NRF51 and SAMD21 MCU, TutuApp Onlinesbi aadhar card both of them have lot of advantages FLASH, interrupt on all pins, consumption.....
                        silkscale
                        Banned
                        • F
                          F
                          flisterten
                          Banned
                          • F
                            F
                            flisterten
                            Banned
                            • F
                              F
                              flisterten
                              Banned
                              • L
                                L
                                luciavid
                                Have someone ready working arduino sketch for this board for sharing?
                                • L
                                  L
                                  luciavid
                                  any update... . ?
                                  • K
                                    K
                                    khaanekii
                                    Banned
                                    I have got the accelerometer (MPU6050) working as a service in nordic mbed, and I thought I would throw in some of what I learned to add to the great work you have done.
                                    • B
                                      B
                                      basaksts
                                      Hello, i have an nRF51 Sensor Tag Module. But i couldnt find sensor examples which is writing on Arduino. Also I need an bootloader but, i couldnt find any. Is there anyone have these?
                                      monteM 1 Reply Last reply
                                      • B basaksts
                                        monteM
                                        monteM
                                        monte
                                        https://github.com/sandeepmistry/arduino-nRF5
                                        Install this and find libraries for whatever sensors you have on that board.
                                        @basaksts said in nRF5 Multi Sensor Board (12-14€):
                                        No, you really don't. You need ST-Link, or J-Link SWD programmer/debugger. Connect it to SWDIO, SWCLK, 3.3V and GND and program it using Arduino IDE.
