  3. [SOLVED] MySensors MQTT Gateway - offline
10 Posts 2 Posters 1.6k Views 2 Watching
  • R
    R
    ribaaa
    Re: OpenHAB Mysensors binding 2.4: cant get mqtt gateway online
    I have strange problem with MQTT:
    MySensors MQTT Gateway is offline, allthough lof is at one point saying that is connected?!
    Here is log:
    2019-07-06 18:21:56.815 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
    2019-07-06 18:21:56.862 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
    2019-07-06 18:21:56.868 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
    2019-07-06 18:21:56.911 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
    2019-07-06 18:21:56.937 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=404, service.bundleid=242, service.scope=singleton} - org.openhab.binding.mysensors
    2019-07-06 18:21:56.944 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
    2019-07-06 18:21:56.947 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
    2019-07-06 18:21:56.941 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Connected to MQTT broker!
    2019-07-06 18:21:56.991 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mysensors-in/+/+/+/+/+
    2019-07-06 18:21:57.029 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2019-07-06 18:21:57.036 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-out, Message: 0;0;3;0;2;
    2019-07-06 18:21:58.045 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2019-07-06 18:21:58.082 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-out, Message: 0;0;3;0;2;
    2019-07-06 18:21:59.026 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2019-07-06 18:21:59.029 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-out, Message: 0;0;3;0;2;
    2019-07-06 18:22:00.026 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2019-07-06 18:22:00.030 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-out, Message: 0;0;3;0;2;
    2019-07-06 18:22:01.026 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
    2019-07-06 18:22:01.029 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-out, Message: 0;0;3;0;2;
    2019-07-06 18:22:02.027 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Cannot start reading/writing thread, probably sync message (I_VERSION) not received. Try set startupCheckEnabled to false
    2019-07-06 18:22:02.058 [INFO ] [ateway.MySensorsNetworkSanityChecker] - Network Sanity Checker thread stopped
    ==> /var/log/openhab2/events.log <==
    2019-07-06 18:22:02.086 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:728b59f4' changed from INITIALIZING to OFFLINE
    ==> /var/log/openhab2/openhab.log <==
    2019-07-06 18:22:02.092 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: []
    2019-07-06 18:22:02.105 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    2019-07-06 18:23:22.767 [hingStatusInfoChangedEvent] - 'mqtt:systemBroker:mosquitto' changed from UNINITIALIZED to REMOVING
    Any idea what this means
    Mosquitto log looks like it is working OK, at least to me?!
    1562430021: mosquitto version 1.4.10 terminating
    1562430038: mosquitto version 1.4.10 (build date Wed, 13 Feb 2019 00:45:38 +0000) starting
    1562430038: Config loaded from /etc/mosquitto/mosquitto.conf.
    1562430038: Opening ipv4 listen socket on port 1883.
    1562430038: Opening ipv6 listen socket on port 1883.
    1562430085: New connection from 127.0.0.1 on port 1883.
    1562430085: New client connected from 127.0.0.1 as paho44685311961 (c1, k60, u'openhabian').
    1562430085: Sending CONNACK to paho44685311961 (0, 0)
    1562430116: Received SUBSCRIBE from paho44685311961
    1562430116:     mysensors-in/+/+/+/+/+ (QoS 0)
    1562430116: paho44685311961 0 mysensors-in/+/+/+/+/+
    1562430116: Sending SUBACK to paho44685311961
    1562430117: Received PUBLISH from paho44685311961 (d0, q0, r0, m0, 'mysensors-out/0/0/3/0/2', ... (0 bytes))
    1562430118: Received PUBLISH from paho44685311961 (d0, q0, r0, m0, 'mysensors-out/0/0/3/0/2', ... (0 bytes))
    1562430119: Received PUBLISH from paho44685311961 (d0, q0, r0, m0, 'mysensors-out/0/0/3/0/2', ... (0 bytes))
    1562430120: Received PUBLISH from paho44685311961 (d0, q0, r0, m0, 'mysensors-out/0/0/3/0/2', ... (0 bytes))
    1562430121: Received PUBLISH from paho44685311961 (d0, q0, r0, m0, 'mysensors-out/0/0/3/0/2', ... (0 bytes))
    1562430181: Received PINGREQ from paho44685311961
    • T
      TimO
      Well, the Openhab and Mosquitto side looks good so far. I don't see a connection from the MySensors MQTT gateway in den Mosquitto log.
      What gateway are you using?
      • R
        R
        ribaaa
        MySensors MQTT gateway is offline.
        I can not make it working .....
        Here are my settings
        org.eclipse.smarthome.mqttbroker.cfg
        name=mosquitto
        host=localhost
        secure=false
        port=1883
        username=openhabian
        retain=false
        clientId=openhabRibaaa
        mqtt-eventbus.cfg
        broker=mosquitto
        Broker Name = mosquitto
        Subscription Topic = mysensors-in
        Publish Topic = mysensors-out
        Enabled: "Enabled the startup check"
        Enabled: "Enabled network sanity check"
        • R ribaaa
          name=mosquitto
          host=localhost
          secure=false
          port=1883
          username=openhabian
          retain=false
          mqtt-eventbus.cfg
          broker=mosquitto
          TimO
          @ribaaa What type of MQTT gateway are you using? RPi, Arduino...? I don't see it in den Mosquitto log. The Openhab side looks good, but there is no gateway responding to the requests send to Mosquitto.
          • R
            R
            ribaaa
            It is RPI (NRF24L01 connected to GPIO pins)
            • R ribaaa
              TimO
              @ribaaa Is the MySensors gateway service running and connected to Mosquitto?
              R 1 Reply Last reply
              • T TimO
                R
                R
                ribaaa
                Sorry for stupid question.
                How do I check this?
                I have did all steps according to
                https://forum.mysensors.org/topic/9346/getting-mysensors-mqtt-gateway-working-on-openhab-2-2-stable (I did mqtt broker according to OH 2.3 requirement)
                and did not manged to get MySensors MQTT Gateway online
                • R
                  R
                  ribaaa
                  I think I managed to set MySensors gateway, but still MQTT GW in OH is offline
                  Make options were:
                  ./configure --my-transport=rf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=RibaaaMQTTgw --my-debug=enable --my-mqtt-user=openhabian
                  Here is Mosquitto log
                  1562532386: Config loaded from /etc/mosquitto/mosquitto.conf.
                  1562532386: Opening ipv4 listen socket on port 1883.
                  1562532386: Opening ipv6 listen socket on port 1883.
                  1562532386: New connection from 127.0.0.1 on port 1883.
                  1562532386: New client connected from 127.0.0.1 as RibaaaMQTTgw (c1, k15).
                  1562532386: Sending CONNACK to RibaaaMQTTgw (0, 0)
                  1562532386: Received PUBLISH from RibaaaMQTTgw (d0, q0, r0, m0, 'mysensors-out/0/255/0/0/18', ... (5 bytes))
                  1562532386: Received SUBSCRIBE from RibaaaMQTTgw
                  1562532386:     mysensors-in/+/+/+/+/+ (QoS 0)
                  1562532386: RibaaaMQTTgw 0 mysensors-in/+/+/+/+/+
                  1562532386: Sending SUBACK to RibaaaMQTTgw
                  1562532424: Received PINGREQ from RibaaaMQTTgw
                  1562532424: Sending PINGRESP to RibaaaMQTTgw
                  1562532425: Received PUBLISH from RibaaaMQTTgw (d0, q0, r0, m0, 'mysensors-out/3/1/1/0/16', ... (1 bytes))
                  1562532425: Received PUBLISH from RibaaaMQTTgw (d0, q0, r0, m0, 'mysensors-out/3/254/1/0/38', ... (4 bytes))
                  1562532432: New connection from 127.0.0.1 on port 1883.
                  1562532433: New client connected from 127.0.0.1 as paho45203016857 (c1, k60, u'openhabian').
                  1562532433: Sending CONNACK to paho45203016857 (0, 0)
                  1562532439: Received PINGREQ from RibaaaMQTTgw
                  1562532439: Sending PINGRESP to RibaaaMQTTgw
                  RibaaaMQTTgw is MySensors GW
                  paho45203016857 is client from org.eclipse.smarthome.mqttbroker.cfg file ( I base that conclusion on username)
                  Here are MySensors logs
                  Jul 07 22:46:25 INFO  Starting gateway...
                  Jul 07 22:46:25 INFO  Protocol version - 2.3.1
                  Jul 07 22:46:26 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,REL=255,VER=2.3.1
                  Jul 07 22:46:26 DEBUG TSF:LRT:OK
                  Jul 07 22:46:26 DEBUG TSM:INIT
                  Jul 07 22:46:26 DEBUG TSF:WUR:MS=0
                  Jul 07 22:46:26 DEBUG TSM:INIT:TSP OK
                  Jul 07 22:46:26 DEBUG TSM:INIT:GW MODE
                  Jul 07 22:46:26 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                  Jul 07 22:46:26 DEBUG MCO:REG:NOT NEEDED
                  Jul 07 22:46:26 DEBUG MCO:BGN:STP
                  Jul 07 22:46:26 DEBUG MCO:BGN:INIT OK,TSP=1
                  Jul 07 22:46:26 DEBUG GWT:RMQ:MQTT RECONNECT
                  Jul 07 22:46:26 ERROR connect: Connection refused
                  Jul 07 22:46:26 ERROR failed to connect
                  Jul 07 22:46:26 DEBUG TSM:READY:NWD REQ
                  Jul 07 22:46:26 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                  ..... more RECONNECT retries
                  Jul 07 22:46:26 DEBUG connected to 127.0.0.1
                  Jul 07 22:46:26 DEBUG GWT:RMQ:MQTT CONNECTED
                  Jul 07 22:46:26 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                  Jul 07 22:46:33 DEBUG TSF:MSG:READ,3-3-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
                  Jul 07 22:46:33 DEBUG GWT:TPS:TOPIC=mysensors-out/3/1/1/0/16,MSG SENT
                  Jul 07 22:46:35 DEBUG TSF:MSG:READ,3-3-0,s=1,c=1,t=16,pt=2,l=2,sg=0:0
                  • R
                    R
                    ribaaa
                    I managed to get it online...... somehow?!
                    • R ribaaa
                      TimO
                      @ribaaa My guess: you restarted Openhab or the binding. I'm glad it works now!
                      12.5k
