  3. OpenHAB
  4. Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
60 Posts 19 Posters 23.4k Views 23 Watching
  • J
    J
    Jet
    Here are step by step instructions for taking a vanilla OpenHabian 2.2 and adding MQTT Gateway and MySensors to it. This may change, but at the date of this post and with the versions / snapshots below, this currently works:
    Pre-requisites / configuation:
    • Raspberry-Pi 3 Model B (the only one I'm using, others may work)
    • GatewayW1500MQTTClient.ino with nrf24L01+ https://github.com/mysensors/MySensors/blob/master/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
      (note: If using encryption or many of the features, a 328p will be too small, I'm using a 2560) We call this the MySensors MQTT Gateway
    • OpenHABian Rasperry Pi Image V1.4.1: https://bintray.com/openhab/bin/download_file?file_path=openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb.img.xz
    • A working SD Card (I was using a Lexar 300X Class 10 that was randomly corrupting files on reboot)
    • This works with OpenHAB 2.2 Stable (at the current date)
    • openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb.img written to an SD Card (recommend 8GB or larger)
    GatewayW1500MQTTClient I have setup as follows:
    #define MY_RF24_PA_LEVEL RF24_PA_MIN // ONLY FOR nrf24L01+ Enhanced, it reduces the output of the nrf24L01 otherwise rfaxis power amp overloads and starts corrupting messages
    #define MY_RF24_CHANNEL (109) // 0-126: Note specifying a channel >= 108 clears most of the wifi interference.
    // Security (Signing)
    #define MY_SIGNING_SOFT
    //For the software backed signing backend, an unconnected analog pin is required on boards that does not provide a hardware based random generator unit to set a
    //random seed for the pseudo-random generator. It is important that the pin is floating, or the output of the pseudo-random generator will be predictable, and thus compromise the signatures.
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A12
    #define MY_DEFAULT_ERR_LED_PIN 7 // Error led pin
    #define MY_DEFAULT_RX_LED_PIN 8 // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN 9 // the PCB, on board L
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #define MY_SOFT_SPI_SCK_PIN A0
    #define MY_SOFT_SPI_MISO_PIN A2
    #define MY_SOFT_SPI_MOSI_PIN A1
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #define MY_MAC_ADDRESS 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX <--- CHANGE TO YOUR MAC ADDRESS
    // Static ip setup, otherwise if not defined, dhcp is used
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, XXX, XXX <--- SET THIS TO THE ADDRESS OF YOUR RASPBERRY PI
    #define MY_PORT 1883
    #define MY_MQTT_USER "openhabian" <--- MUST MATCH THE USERNAME FOR MOSQUITTO ON THE PI
    #define MY_MQTT_PASSWORD "XXXXX" <--- SET THIS TO YOUR A PASSWORD - MUST MATCH THE ONE FOR MOSQUITTO ON THE PI"
    // Set MQTT client id
    Steps:
    1. Boot Raspberry pi from SD Card connected to ethernet (if you have any wifi connectivity problems, parts of the installation fail, and you get an incomplete install, that doesn't necessarily fail to complete, hence use ethernet till built)
    2. After about 2-3 mins, connect to the Pi with: ssh openhabian@IP_ADDRESS (password: openhabian) and you will see the install in progress
    3. Watch until installation has finished (approx 25mins depending on connection speed), the last entry will be "First time setup successfully finished". There should be no errors (except: sed: -e expression #1, char 5: unterminated address regex), if you're getting other errors, retry it (you need to make up the SD Card with the image again), if errors are randomly happening, suspect the SD Card.
    4. Ctrl-C and type sudo reboot
    5. Verify Installation: After about 5 mins you should be able to connect to: http://IP_ADDRESS:8080, select Standard Setup and wait until PaperUI and HABPanel have appeared
      Also: http://IP_ADDRESS:9001 should show no errors
    6. ssh openhabian@IP_ADDRESS
      sudo openhabian-config
      Change openhab-cli password:
      System Settings / Change Passwords / openHAB Console: and set to something, we'll need this when logging into openhab-cli, we'll call this password_openhab-cli
      Add Mosquitto:
      Optional Components / Mosquitto, set password to something (we'll call this password_mosquitto), needs to match the one in your MySensors gateway and the one in the next step.
      Exit
    7. Configuring MQTT:
      IMPORTANT: DO NOT INSTALL THE MQTT BINDING IN THE PAPER UI, IT CONFLICTS WITH MYSENSORS
    cd /srv/openhab2-conf/services
    nano org.eclipse.smarthome.mqtt.cfg   (or use your favorite editor)
    add:
    mosquitto.url=tcp://localhost:1883
    mosquitto.user=openhabian
    mosquitto.pwd=YOUR_PASSWORD_GOES_HERE   (This is password_mosquitto referenced previously)
    mosquitto.qos=1
    mosquitto.retain=true
    mosquitto.async=false
    (NOTE: We don't add clientId here, it causes problems and prevents both OpenHab and MySensors connecting due to multiple id's (persistance in use errors).  Allowing the id's to be auto and uniquely assigned, will prevent this clash)
    save the file and exit
    nano mqtt-eventbus.cfg
    Add:
    broker=mosquitto
    sudo chown openhab:openhabian org.eclipse.smarthome.mqtt.cfg mqtt-eventbus.cfg
    Remove the backup files:
    cd /var/lib/openhab2/config/org/openhab
    rm mqtt-eventbus.config
    cd ../eclipse/smarthome
    rm mqtt.config
    sudo reboot
    Power cycle or switch on your already configured MySensors MQTT Gateway
    1. ssh openhabian@IP_ADDRESS
      After a few minutes, visit: http://IP_ADDRESS:9001
      You should have no errors.
    2. Installing MySensors:
      openhab-cli console
      (if password prompt doesn’t appear after a while, ctrl-c and try again, it can take a while or timeout the first few times after installation, this is password_openhab-cli)
    feature:install openhab-transport-serial
    feature:install esh-io-transport-mqtt
    CTRL-D
    cd /srv/openhab2-addons
    wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jar
    sudo chown openhab:openhabian org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jar
    openhab-cli console
    Check the features and services we need are active:
    feature:list | grep openhab-transport-serial	(Should say Started)
    feature:list | grep esh-io-transport-mqtt	(Should say Started)
    bundle:list | grep MySensors			(Should say Active)
    bundle:list | grep nrjavaserial			(Should say Active)
    CTRL-D
    sudo reboot
    Check mosquitto is running and gateway is connected:
    cd /var/log/mosquitto
    tail -f mosquitto.log
       526088756: mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) starting
       1526088756: Config loaded from /etc/mosquitto/mosquitto.conf.
       1526088756: Opening ipv4 listen socket on port 1883.
       1526088756: Opening ipv6 listen socket on port 1883.
       1526088764: New connection from 192.168.20.143 on port 1883.
       1526088764: New client connected from 192.168.20.143 as mysensors-1 (c1, k15, u'openhabian'). <-- This is the MySensors MQTT Gateway connecting)
       1526088783: New connection from 127.0.0.1 on port 1883.						<-- This is the MQTT Service on the Raspberry Pi Connecting
       (If you're not seeing the above, power cycle the MySensors MQTT Gateway)
    CTRL-C
    1. Adding MySensors Binding in PaperUI:
      Visit: http://IP_ADDRESS:8080 and click on PaperUI
    Choose Inbox / + / MySensors Binding / MySensors MQTT Gateway
       Enable: "Enabled the startup check"
       Enable: "Enabled network sanity check"
       (all other settings remain at the default, but you might want to change Imperial/Metric for your preference)
       Click the "Blue" Checkmark at the top to save.
    Choose Configuration / Things (you may have to reload the page)
       MySensors MQTT Gateway should be ONLINE, if not, check your Gateway is configured correctly.
    sudo reboot
    1. After a few minutes, visit: http://IP_ADDRESS:9001
      Visit Configuration / Things, MySensors MQTT Gateway should still be ONLINE
      tail mosquitto.log
      It should look like this:
    1526089285: mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) starting
    1526089285: Config loaded from /etc/mosquitto/mosquitto.conf.
    1526089285: Opening ipv4 listen socket on port 1883.
    1526089285: Opening ipv6 listen socket on port 1883.
    1526089294: New connection from 192.168.20.143 on port 1883.
    1526089294: New client connected from 192.168.20.143 as mysensors-1 (c1, k15, u'openhabian').
    1526089312: New connection from 127.0.0.1 on port 1883.
    CONGRATULATIONS, gateway and mysensors are now setup
    1. Now you want to add some mysensors things into PaperUI. Easiest way is to power cycle the sensor, this should result in the sensor appear in the Inbox in PaperUI. For example, I built an RGB Light, when I power cycle it, I see in the Inbox:
      MySensors Device (1;1) RGB Light Sensor: mysensors:rgbLight:a6e1bcda:rgblight_1_1
      Click on the Blue checkmark, and click "Add As Thing"
      Go to Configuration / Things, and you should see the MySensors Device(1;1) show up
      Click the bolded title of the sensor (MySensors Device (1;1) and check the blue circles you want to see the data for one by one. Each one pops up a "Link Channel" message, change item to "Create new item" and select "Link"
      That newly added item will now show up in Configuration / Items and also in "Control" so you can change it's status
    2. If you're new to this, checkout HABPanel, use PaperUI to setup items, but HABPanel to present a UI for use.
    • MasMatM
      MasMatM
      MasMat
      Great instructions, thanks!
      My problems started yesterday with my OpenHab2 updating to 2.3.0.
      I'm using Rpi Zero W / DietPi - conf to MQTT gw. Mosquitto and mysgw service work OK. Everything else doesn't.
      My problems briefly from the logs:
      1527624943: New client connected from 127.0.0.1 as mygateway1 (c1, k15, u'masi').
      1527626485: New connection from 127.0.0.1 on port 1883.
      1527626485: New client connected from 127.0.0.1 as mosqsub/3760-DietPi (c1, k60, u'masi').
      1527626499: Socket error on client mosqsub/3760-DietPi, disconnecting.
      OpenHab (edited):
      2018-05-29 23:17:17.655 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
      2018-05-29 23:17:17.880 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
      2018-05-29 23:17:18.019 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=116, service.bundleid=13, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=15} - org.openhab.binding.mysensors
      2018-05-29 23:19:24.908 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, Tiedostoa tai hakemistoa ei ole)
      2018-05-29 23:19:25.184 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
      2018-05-29 23:19:25.985 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
      2018-05-29 23:19:26.257 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
      2018-05-29 23:19:26.315 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [0, 1, 99, 4, 5]
      2018-05-29 23:19:26.594 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
      2018-05-29 23:19:26.795 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
      2018-05-29 23:19:26.834 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=280, service.bundleid=13, service.scope=singleton} - org.openhab.binding.mysensors
      2018-05-29 23:19:26.925 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
      2018-05-29 23:19:27.032 [INFO ] [ateway.MySensorsNetworkSanityChecker] - Network Sanity Checker thread stopped
      2018-05-29 23:19:27.191 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,1,99,4,5]
      2018-05-29 23:19:27.242 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
      2018-05-29 23:19:27.250 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
      I've gone through your steps, Mysensors MQTT gateway remain offline.
      What I'm wondering (since the directory structure is different), what is the total content of file: mqtt-eventbus.cfg? Can you post?
      Ideas?
      • A
        A
        andre_m87
        Hey,
        same Problem here. After upgrading to OpenHAB 2.3 i receive the same errors in my /var/log/openhab2/openhab.log
        2018-05-31 16:28:42.776 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
        2018-05-31 16:28:42.918 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
        T 1 Reply Last reply
        • A andre_m87
          Hey,
          TimO
          @andre_m87 & @MasMat : I have the same problem here. Looks like a change in the OpenHAB MQTT implementation.
          I'm working on it.
          • T
            TimO
            @andre_m87 & @MasMat : I found a solution and indeed the MQTT implementation in OH2 (ESH) changed. This was a hard nut to crack, so it took me a while.
            Here are the steps you need to do:
            1. Rename: org.eclipse.smarthome.mqtt.cfg to org.eclipse.smarthome.mqttbroker.cfg
            2. Change the content to:
            name=mosquitto
            host=192.168.2.3
            secure=false
            port=1883
            username=USERNAME
            password=PASSWORD
            retain=false
            If you're using a secure connection (SSL): change secure to true and use the correct port.
            Another intersting feature in OpenHAB 2.3 is the embedded broker, so there is no need to have a separate MQTT server up and running.
            jogantJ 1 Reply Last reply
            • T TimO
              name=mosquitto
              host=192.168.2.3
              secure=false
              port=1883
              username=USERNAME
              password=PASSWORD
              retain=false
              jogantJ
              jogantJ
              jogant
              wrote on last edited by jogant
              @timo unfortunately this solution doesn't work for me.
              After update oh to version 2.3 I don't get mqtt to work. Prior I used mqtt for mysensors and for eventbus. I configured two broker connections and set up a mysensors-mqtt-bridge via things-file. In the broker all events from openhab arrived and all mysensors-messages arrived in openhab.
              After update mysensors doesn't work at all, allthough I followed your instructions. If I setup mqtt1 binding I can see eventbus messages in mqtt broker but my mysensors-mqtt-gateway remains initializing.
              What I'm doing wrong?
              • jogantJ jogant
                TimO
                @jogant Yeah. :-( There are still some problems with 2.3 to fix. The binding works fine within the development IDE, but only there. I'm still looking into it.
                • MasMatM
                  MasMatM
                  MasMat
                  Did that, MQTT bridge stuck at "initializing". Not the full answer yet, but thanks @timo for your effort!
                  Openhab.log when I checked the Services - MQTT in Paper UI
                  2018-06-08 00:59:19.162 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
                  2018-06-08 00:59:19.221 [WARN ] [me.config.core.internal.ConfigMapper] - Could not set field value for field 'port': For input string: "1883.0"
                  java.lang.NumberFormatException: For input string: "1883.0"
                  	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
                  	at java.lang.Integer.parseInt(Integer.java:580) [?:?]
                  	at java.lang.Integer.valueOf(Integer.java:766) [?:?]
                  	at org.eclipse.smarthome.config.core.internal.ConfigMapper.objectConvert(ConfigMapper.java:159) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
                  	at org.eclipse.smarthome.config.core.internal.ConfigMapper.as(ConfigMapper.java:98) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
                  	at org.eclipse.smarthome.config.core.Configuration.as(Configuration.java:54) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
                  	at org.eclipse.smarthome.io.transport.mqtt.internal.MqttBrokerConnectionServiceInstance.modified(MqttBrokerConnectionServiceInstance.java:77) [207:org.eclipse.smarthome.io.transport.mqtt:0.10.0.oh230]
                  	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                  	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                  	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                  	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                  	at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeModifiedMethod(SingleComponentManager.java:772) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:727) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:645) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:609) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:426) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:284) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$1.configurationEvent(RegionConfigurationSupport.java:89) [41:org.apache.felix.scr:2.0.12]
                  	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:2090) [8:org.apache.felix.configadmin:1.8.16]
                  	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:2058) [8:org.apache.felix.configadmin:1.8.16]
                  	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [8:org.apache.felix.configadmin:1.8.16]
                  	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [8:org.apache.felix.configadmin:1.8.16]
                  	at java.lang.Thread.run(Thread.java:748) [?:?]
                  2018-06-08 00:59:19.340 [WARN ] [.MqttBrokerConnectionServiceInstance] - Ignore existing broker connection configuration for: mosquitto```
                  • MasMatM MasMat
                    TimO
                    wrote on last edited by TimO
                    @masmat please check your MQTT configuration. You're receiving an exception because it's trying to set "1883.0" for the value port.
                    MasMatM 1 Reply Last reply
                    • T TimO
                      MasMatM
                      MasMatM
                      MasMat
                      @timo I did. I can't figure out where it's finding that .0 it adds to the 1883 port I have in the cfg-file
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        How close is this for 2.3? Worth a try? or should I hold? Thanks for the work so far on it!
                        Home Automation Tinkerer
                        www.CrankyCoder.net
                        Gateway: MQTTClientGateway
                        MySensors: 2.3
                        • CrankyCoderC CrankyCoder
                          jogantJ
                          jogantJ
                          jogant
                          @crankycoder Unfortunately there are still issues with the mqtt implementation. I reverted back to 2.2 yesterday as all my fiddling didn't help.
                          • CrankyCoderC
                            CrankyCoderC
                            CrankyCoder
                            my setup is still just using the direct mqtt subscription so i will hold off.
                            is there any discovery working (in 2.2 that is) how about once you configure the things. do you get all the properties of that item from when it presents?
                            www.CrankyCoder.net
                            MySensors: 2.3
                              jogantJ
                              jogantJ
                              jogant
                              @crankycoder in 2.2 with appropriate binding mysensors is working pretty well. All variables are presented with mysensors lib 2.2.
                              I only updated openhab to 2.3 as this release was presented on my debian system. But I didn't get 2.3 working with mysensors mqtt.
                              • CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                I did an upgrade the other week from 1.8 to 2.2. Then right about the time I had some stuff working 2.3 came out. So I figured since I have to do all the learning curve anyways I might as well stick with 2.3. The variables being presented in mysensors would be HUGE for me. But hopefully it's not too far out.
                                www.CrankyCoder.net
                                MySensors: 2.3
                                • jogantJ
                                  jogantJ
                                  jogant
                                  @TimO : are there any news concerning compatibility to version 2.3?
                                  Thanks for your work!
                                  • jogantJ jogant
                                    TimO
                                    @jogant There already is a working version (2.4 SNAPSHOT) available on the marketplace and on my server. Please let me know if you expierence any problems.
                                    • T TimO
                                      jogantJ
                                      jogantJ
                                      jogant
                                      @timo unfortunately this also does not work for me. I followed your manual very well but I always get errors. It starts after installing feature:install esh-io-transport-mqtt and mysensors binding:
                                      16:59:57.772 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
                                      16:59:57.806 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.96.8' with clientid paho1135997459230242 and file store '/var/lib/openhab2/mqtt/192.168.96.8'
                                      16:59:57.867 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                                      org.eclipse.paho.client.mqttv3.MqttException: MqttException
                                              at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) [229:org.eclipse.paho.client.mqttv3:1.0.2]
                                              at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:604) [229:org.eclipse.paho.client.mqttv3:1.0.2]
                                      Caused by: java.net.SocketException: Connection reset
                                              at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
                                              at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
                                              at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
                                              at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
                                              at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
                                              at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
                                              at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
                                              at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
                                              at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:89) ~[?:?]
                                              at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:590) ~[?:?]
                                              ... 1 more
                                      and reconection starts every 10 seconds.
                                      It must be interference with mqtt1 bindung that I use for eventbus.
                                      The mqtt-bridge remains Offline.
                                      What is wrong?
                                      • jogantJ jogant
                                                ... 1 more
                                        What is wrong?
                                        TimO
                                        @jogant Indeed this looks like an error in your configuration. I suspect the MQTT configuration. Did you change the MQTT configuration according my posting above? I've also added a text to the Wiki. The name and content of the MQTT configuration differs between OpenHAB 2.2 and 2.3.
                                        jogantJ 2 Replies Last reply
                                        • T TimO
                                          jogantJ
                                          jogantJ
                                          jogant
                                          @timo with 2.2 I had two configurations which were very similar.
                                          I have one mosquitto mqtt broker on localhost, version 1.5.
                                          The mqtt1 binding is for my mqtt-eventbus connection is called mosquitto and the config file (mqtt.cfg) is as follows:
                                          mosquitto.url=tcp://192.168.96.8:1883
                                          mosquitto.retain=false
                                          mosquitto.clientId=openhab
                                          mosquitto.user=user
                                          mosquitto.pwd=pwd
                                          With OH2.2 this configuration works. It also works with 2.3 as I can see all openhab events on my mosquitto.
                                          My mysonsors binding is configured by org.eclipse.smarthome.mqttbroker.cfg config file which looks as follows:
                                          name=mosquittomys
                                          host=192.168.96.8
                                          port=1883
                                          retain=false
                                          username=username
                                          password=password
                                          clientId=openhabMys
                                          I also tried without authentication and also without clientId, all to no succuess.
                                          I cleaned /var/lib/openhab2/cache/ folder and /var/lib/openhab2/tmp/ folder.
                                          I looked at /var/lib/openhab2/config folder for resulting runtime configuration, but all looks fine. Do you have any further idea?
