  3. Trouble with the JSN SR04T
23 Posts 5 Posters 8.4k Views 4 Watching
    Sundeep Goel
    wrote on last edited by Sundeep Goel
    I am having some trouble with the JSN SR04T - I am using it to measure the water level in a overhead tank. However, the readings keep varying between 20-30cm only. I assumed this was because of the wide beam spread / echo, so tried to build a stand pipe using design from https://blog.lesman.com/2014/04/29/does-ultrasonic-level-measurement-work-with-a-standpipe/.
    However, this did not work out, key issue which i ran into was that the diameter to height ratio of beyond 1:1 is not working out, kept getting same erronious readings when i increased the height of the sensor in the pipe. With a bit of experimentation, worked out that a height of 1.2cm is the max you can go for inside 2cm inner diameter pipe.
    With this setup i.e taking the transducer out of its plastic casing, inserting it inside a 2cm tank nipple, keeping the sensor face at height of 1.2 from end, getting readings which are better but still not fully accurate.
    Please suggest
    • Proper standpipe design for this sensor to limit the angle of detection
    • Ways to trouble shoot the problem further.
    • any reading material on proper design of standpipe / waveguide for this sensor
    bgunnarbB zboblamontZ 2 Replies Last reply
    • S Sundeep Goel
      Please suggest
      bgunnarbB
      bgunnarbB
      bgunnarb
      @sundeep-goel
      Oh! This sounds a lot like the problems I have had for the past year. Like @zboblamont I have been pulling my hair trying to find a solution.
      The tank is a square profile septic tank, cross section 1 x 1 m. Access to the tank is through a manhole some 60 cm diameter.
      First i tried mounting the sensor in the lid of the manhole but all the time I ended up with measurements like 20 - 30 cm, no matter what the liquid level was.
      I then tried to mount a baffle around the sensor trying to limit the beam spread so that the sensor would not see the corrugated wall of the manhole. No luck!
      Next idea was to increase the powerfeed to the sensor. First it was powered from one of the digital pins of the Arduino, giving some 4.x volts. So, thinking this was below specs, I built a circuit that gave the sensor proper 5 V as needed. No luck!
      The final solution was to mount the sensor at the bottom end of a plastic tube, 30 mm outer dia and then feed the cable through the tube and out to the electronics. The tube is attached to the wall of the manhole using a plastic clip. Please see attached photos. Success!
      So clearly my problem was caused by the sensor getting reflexes from the corrugated wall of the manhole.
      I have never been so busy since I retired!
      • S Sundeep Goel
        Please suggest
        zboblamontZ
        zboblamontZ
        zboblamont
        @bgunnarb There are many confusing models with the same JSN-SR04T model name out there, the single button version (a la bumper mounted parking sensor) is the version we both settled on as it is a snug fit in the end of a 3/4" collar adapter.
        The JSN-SR04T-2.0 (sensor on cable type) was advertised as 3v capable (original non 2.0 was 5v only), but readings were weird. I even tried feeding it 5v which appeared to work, but which then caused other complications with dual voltages.
        Revisiting the problem I stumbled over a comment that the Trigger HIGH before reading should be 15 microseconds, reworked the sketch and it has worked flawlessly ever since on a 3.3v node.
        As you found, mounting on the end of a pipe to position the head for clear perpendicular flight to the surface >=200mm is crucial. During raw water tank recalibration this summer the exposed ledges caused no inconsistencies at all right down to the STOP-PUMP electrode, but it IS getting two consecutive readings and verifying within known range before sending anyway.
        @sundeep-goel Not quite clear what casing you removed from the ultrasonic, the waterproof button should fit directly into a 20mm socket, and the cable runs up the tube.
        So long as your sensor is >=200mm from the surface, side reflections should be minimal unless it is a very narrow overhead tank with ledges to reflect, in which case consider inserting plastic sheets into the tank to null them?
        Perhaps a little more detail would help understand the physical problem you are trying to address....
        S 1 Reply Last reply
        • bgunnarbB
          bgunnarbB
          bgunnarb
          Yes, I take five consecutive readings 100 ms apart and calculate the median value of the readings that fall within allowed limits. Off-scale readings are discarded before calculating the median value.
          It has been running for two weeks now and seems to be accurate and stable.
          • zboblamontZ zboblamont
            Sundeep Goel
            @zboblamont said in Trouble with the JSN SR04T:
            Needed to remove the plastic to fit sensor inside a standpipe 1.5cm diameter (baffle) to reduce reflecting from side of the tank (which i assumed was causing most of the issues.
            Note : If i insert the sensor face more than 1.2cm away from the pipe edge, keep getting 20cm readings only. Same happening if i go for a pipe with a larger diameter.
            Even after this, i keep getting erratic readings
            The left one is not as erratic - but innaccurate , the right one is completely bonkers :)
            • S Sundeep Goel
              zboblamontZ
              zboblamontZ
              zboblamont
              @sundeep-goel I still don't understand why you didn't use a 2cm adaptor, it is a snug fit for the original waterproof sensor head. Fitting it inside a pipe may be perceived as narrowing the field of view, but mounting it to ensure it's emission axis is parallel to the pipe is no easy task.
              Details I meant were for your physical tank to verify why side reflections may be an issue, and consider alternatives. I was concerned initially over side reflections, but no actual problems were found with the sensor mounted on the end of a pipe.
              Clearly your standpipe experiments are not working, perhaps a fresh pair of eyes might help identify alternatives.
              For starters, is the JSN the 5v or 3v version, and is the pulse set for 15 microseconds, etc...
              • bgunnarbB bgunnarb
                zboblamontZ
                zboblamontZ
                zboblamont
                @bgunnarb I looked at that median methodology also, but plumped for two consecutive readings instead, again within verified limits. Both installs are fired by RTC hourly, the only refinement added was to limit attempts to 10 after discovering a condensation drip had the ultrasonic running continuously... An unforeseen effect of the steel pipe in sub-zeroes, may yet dismantle it and change to plastic inside the tank...
                  Sundeep Goel
                  How do I check for this? Am using the ultrasonic Arduino library
                  • S Sundeep Goel
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @sundeep-goel
                    Can we please establish a baseline of what you are using and the physical parameters, a fresh pair of eyes is only useful if the blinds are removed.
                    No idea what trigger time the library you refer uses, but can confirm that the standard and improved Ping versions trialled originally were inconsistent. Hence I use a basic manual sketch where the parameters are set, the 15 microsecond trigger was modified later and found to give consistent and repeatable readings. From vague memory the original trigger was 150.
                    I was/am using an original unmodified exposed button on the end of a pipe, and I don't suppose you have a spare original sensor head available.
                    Perhaps we might establish the method you use was originally tested in free air before the install or stand-pipe were developed, and found reliable and consistent?
                      Sundeep Goel
                      I agree, let me try and address all the queries.
                      1. This sensor is mounted on top of a 1000 ltr plastic tank (image attached)
                      2. The sensor is a 5V version, which is feed from a 3.3V esp8266 (image attached) - Can this be an issue even though it si working fine outside the tank?
                      3. Sensors work fine outside the tank, within orig mounting and also inside the standpipe (as long as the sensor face is no deeper than 1.2cm from end of standpipe - image attached)
                      4. Looking into the code of the ultrasonic library, trigger pulse seems to be 10 microseconds which is as per the documentation. Should i increase this to 15ms?
                        digitalWrite(trig, LOW);
                        delayMicroseconds(2);
                        digitalWrite(trig, HIGH);
                        delayMicroseconds(10);
                      Tank - total height say 130cm
                      Mounting Hole - its offset from the side by 25cms
                      Inside of the tank
                      JSN 04T driver module
                      Sensor head mounted inside standpipes
                      • S Sundeep Goel
                        Inside of the tank
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @sundeep-goel Excellent... Tank is typical eastern roof mounted PVC/GRP. That size and shape should give you no side reflections at all but your sensor would be better centralised - If you are using threaded couplers, I suggest a 90 degree under your current entry, a short extension to the centre, then down to just above 200mm from top water level. That way if you need clear access through the hatch, the pipe can be swung to one side.
                        The inlet is usually direct discharge which will cause ripples, easily solved by attaching a drop pipe to push the discharge under water. In the discharge is flush on the inside, a small drain pipe with a Tee can be tied to it, but may need a brick tied to the bottom to keep it from moving.
                        Can you confirm the JSN model number does not have 2.0 on the end which would make it 3v compatible. Otherwise you need level converter to 3.3v.
                        I suggest flush facing the sensor to it's housing.
                        From what I read the 15 microsecond is important.
                        I've attached a water tank sketch which you will have to alter for your setup, pins and parameters... My apologies that it's a bit of a mess as it's been through 6 different itterations...
                        #include <T2WhisperNode.h>
                        #include <RTClibExtended.h>
                        //#define MY_DEBUG //Comment out once all working saving memory
                        #define MY_RADIO_RFM69
                        #define MY_RFM69_FREQUENCY RFM69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
                        #define MY_RFM69_NETWORKID 101  // Default is 100 in lib. Uncomment it and set your preferred network id if needed
                        #define MY_NODE_ID 7  //Manually set the node ID here. Comment out to auto assign
                        //A define should be added to provide minimum power output to provide decent RSSI to the Gateway if ATC not available
                        #include <MyConfig.h>
                        #define SN "Node7water3vWNfinalRTC"
                        #define SV "6"
                        #define FIRST_CHILD_ID 1
                        #define SECOND_CHILD_ID 2
                        #define THIRD_CHILD_ID 3
                        #define REED_PIN 3   // Arduino Digital I/O pin for button/reed switch
                        #define BatteryOn 14
                        #define BatteryIn A6
                        #define Trigpin 17
                        #define Echopin 16
                        #define Ultrapin 15
                        #define flasher 6
                        int halfday=12;
                        int tankdepth, tankpercent,tankvolume,distance,test,test2,counter;
                        long duration;
                        volatile int ultrasonic;
                        RTC_DS3231 RTC;      //we are using the DS3231 RTC
                        MyMessage msg1(FIRST_CHILD_ID, V_LEVEL);
                        MyMessage msg2(SECOND_CHILD_ID, V_LEVEL);
                        MyMessage msg3(THIRD_CHILD_ID, V_VOLTAGE);
                        unsigned long SLEEP_TIME = 0;//1800000; Sleep time between reports (in milliseconds)
                        void setup ()
                           pinMode(REED_PIN, INPUT_PULLUP);//Output of DS3231 INT pin is connected to D3 INT1 for RTC wake-up
                           pinMode(BatteryOn, OUTPUT);//WN battery sample activation
                           pinMode(BatteryIn, INPUT);//WN ADC for battery read
                           pinMode(Ultrapin,OUTPUT);
                           pinMode(Trigpin, OUTPUT);
                           pinMode(Echopin,INPUT);
                           pinMode(flasher,OUTPUT);
                           analogReference(INTERNAL);//All voltage reads are to 1.1 internal datum
                           sleep(100);//Allow things to settle was 1000
                           Wire.begin ();
                           RTC.begin();
                           RTC.adjust(DateTime(__DATE__, __TIME__));   //set RTC date and time to COMPILE time
                        //clear any pending alarms
                           RTC.armAlarm(1, false);
                           RTC.clearAlarm(1);
                           RTC.alarmInterrupt(1, false);
                           RTC.armAlarm(2, false);
                           RTC.clearAlarm(2);
                           RTC.alarmInterrupt(2, false);
                          //Set SQW pin to OFF
                           RTC.writeSqwPinMode(DS3231_OFF);
                          //Set alarm1 every hour at XX:50
                           RTC.setAlarm(ALM1_MATCH_MINUTES, 0, 50, 0, 0);//set wake-up time here
                           RTC.alarmInterrupt(1, true);//Alarm on
                         void presentation(){
                          sendSketchInfo(SN, SV);
                          present(FIRST_CHILD_ID, S_DUST);
                          present(SECOND_CHILD_ID, S_DUST);
                          present(THIRD_CHILD_ID, S_MULTIMETER);
                        void loop(){
                        // Power up US
                            VON();
                           sleep(100);//Delay to stabilise
                           digitalWrite(Trigpin,HIGH);
                           sleep (100);
                           digitalWrite(Trigpin,LOW);
                           sleep(100);/// Allow decay of pulse
                           int voltread;
                           counter=0;
                           tankdepth=0;
                           while ((tankdepth<350||tankdepth>1130)&&counter<=10){//10 attempts to get proper range, recalibrated 6/7/2019
                           READULTRASONIC();
                           counter++;
                        //Recalibrated 6/7/2019 -Depth to physical cut-off 1112, surface full 380, range 732, metered 1812L, factor 2.475
                        //Recalculated-Sensor cut-off 1101, surface 362, range 739, metered 1812L, factor 2.45
                          float tankpercent=100-((1101-tankdepth)/7.39);//750 effective range
                           int tankvolume=(1101-tankdepth)*2.45;//Set to low level cut off Sensor-Recalibrated 6/7/2019 from 2.3727
                           //Total recalulated volume 1812 litres
                           if(tankdepth>350&&tankdepth<1150){//Don't report if value is outwith known range
                           VOFF();
                           sleep(100);
                           send(msg1.set(tankvolume));//This is actual volume
                           sleep(100);
                           send(msg2.set(tankpercent,1));//This is remainder to start of 39cm Freeboard
                           sleep(100);
                           VOFF();//If 2nd flash, reading sent, only 1 is fail
                        // Call for battery reading, send in every 12th RTC call?
                           if(halfday==12){
                           digitalWrite(BatteryOn, HIGH);
                           voltread = analogRead(BatteryIn);
                           float voltage = (7.272 * voltread) / 1024;
                           sleep(5);
                           digitalWrite(BatteryOn, LOW);
                           send(msg3.set(voltage,2));
                           sleep(50);
                           voltread=0;
                           sleep(50);
                           halfday=0;//Reset for 12 hourly cycle
                           halfday++;//Increment hourly cycle
                        // Rearm alarm
                           Wire.begin();
                           RTC.begin();
                           sleep(50);
                           Wire.end();
                           sleep(50);
                        //Go deep sleep until RTC interrups
                           sleep(digitalPinToInterrupt(REED_PIN),FALLING, SLEEP_TIME);
                        sleep(100);///Time to recover
                        //First clear the alarm
                           Wire.begin();
                           RTC.begin();
                           RTC.clearAlarm(1);
                          }  // end of loop
                        void VON(){
                          digitalWrite(Ultrapin, HIGH);
                          digitalWrite(flasher,HIGH);
                          sleep (6);
                          digitalWrite(flasher,LOW);
                        void VOFF(){
                          digitalWrite(Ultrapin, LOW);
                          sleep (10);
                          sleep (6);
                          void READULTRASONIC(){//JSN-SR04-2.0
                        //Main loop checks valid range on a defined number of readings
                          tankdepth=0;
                          duration=0;
                          distance=0;
                          test=1;
                          test2=3;
                        // Normal range should lie between 389 and 989 absolutely empty is 1520
                        while (test!=test2){// Get two consecutive readings
                          digitalWrite(Trigpin, LOW);
                          delayMicroseconds(50);//Was 100
                          digitalWrite(Trigpin, HIGH);
                          delayMicroseconds(15);//Was 150
                          duration = pulseIn(Echopin, HIGH);
                          distance = duration/5.82;//This is in mm
                         if (test!=distance){
                            test=distance;
                            distance=0;
                           else{
                            test2=distance;
                          delay(100);
                          tankdepth=distance;
                          #define SV "6"
                          #define Trigpin 17
                          #define Echopin 16
                          #define Ultrapin 15
                          #define flasher 6
                          int halfday=12;
                          long duration;
                          void setup ()
                             Wire.begin ();
                             RTC.begin();
                             RTC.clearAlarm(1);
                             RTC.clearAlarm(2);
                          void loop(){
                          // Power up US
                              VON();
                             sleep (100);
                             int voltread;
                             counter=0;
                             tankdepth=0;
                             READULTRASONIC();
                             counter++;
                             VOFF();
                             sleep(100);
                             sleep(100);
                             sleep(100);
                             if(halfday==12){
                             sleep(5);
                             sleep(50);
                             voltread=0;
                             sleep(50);
                          // Rearm alarm
                             Wire.begin();
                             RTC.begin();
                             sleep(50);
                             Wire.end();
                             sleep(50);
                             Wire.begin();
                             RTC.begin();
                             RTC.clearAlarm(1);
                            }  // end of loop
                          void VON(){
                            sleep (6);
                          void VOFF(){
                            sleep (10);
                            sleep (6);
                            tankdepth=0;
                            duration=0;
                            distance=0;
                            test=1;
                            test2=3;
                              test=distance;
                              distance=0;
                             else{
                              test2=distance;
                            delay(100);
                            tankdepth=distance;
                          Sundeep Goel
                          I thought about this, however, our tanks have a typical float ball which will mess up the reflections from the center. This was one of the major reasons for putting the sensor off-center and also inside a standtube.
                          ![0_1563969848049_ball-float-valve-500x500.jpg]
                          (/assets/uploads/files/1563969850870-ball-float-valve-500x500.jpg)
                          Can you please elaborate on this? do you mean something like?
                          if yes, wont there be reflections from the elbow ?
                          the board does not have a number on it. The link to the item is : link text. Seem to be a non 2.0 version. However, since the unit is getting trigged, and also detecting echos - can the operating voltage still be an issue ?
                          I'll try with 15 us, changing the library is not a big deal.
                          I'll also try adding a voltage divider across the ECHO output into the GPIO pin to see if that makes a differnce.
                          • S Sundeep Goel
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @sundeep-goel Looking back at the tank photo your inlet is at the opposite side of the tank and presumably your sensor head is just over 200mm to the top water level when full? There should be no way that head is seeing the float when full even if the float is directly below the hatch.
                            I'm confused by what you are saying about the board - Accepted it is the 5v version, but you say you are detecting echo away from the tank, but is the distance reliably and consistently correct?
                            Presumably this is via a 5v-3.3v level converter?
                            You misunderstood the bend suggestion - Ultrasonics don't handle bends well but cables do ;). I was looking at the possibility of extending the cable pipe with the sensor on the end pointing down nearer centre. Unfortunately that will be very close to the float if it's a long arm.
                            What you could try is tying the float up until level drops and hang the sensor through the hatch and to see if it works reliably there.
                            If it does, you may have to find a source a replacement float valve with a shorter arm, or possibly find a compact version usually marketed as "silent" (The float in these rises up a tube to close the valve, but unlike the arm type they run at full flow longer until the last few cm).
                            Let's see what your tests reveal....
                              Sundeep Goel
                              Got you, will try this and a couple of others. Will post back the results.
                              On a related topic, is this sensor good sensing water level [link text](GY-VL53L0XV2 Laser Distance Module I2C IIC 3.3V/5V
                              https://s.click.aliexpress.com/e/73Fe2bm)
                              • S Sundeep Goel
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @sundeep-goel No idea !
                                  Sundeep Goel
                                  The sensor is working perfect outside the tank - tested both with 10us and 15us. Also, same with / without a voltage divider.
                                  Saw a possible issue in the code
                                  Ultrasonic ultrasonic1(4, 13);  // An ultrasonic sensor HC-04
                                  Ultrasonic ultrasonic2(4, 12);  // An ultrasonic sensor HC-04
                                  Was using same trigger pins on the esp for both sensor, ideally this should not have been creating a problem. but just to be sure, tried with only one sensor - worked fine outside the tank
                                  Inside the tank in all cases, back to square one i.e. readings between 20-25cm only.
                                  For now , putting this sensor aside and switching to the IR laser sensor VL53L0X. Lets see how that does, will post back the results soon
                                  • S Sundeep Goel
                                    Sundeep Goel
                                    @sundeep-goel said in Trouble with the JSN SR04T:
                                    replaced JSN SR04T with VL53L0X
                                    So far the tests in a experimental setup (i.e. using a mug of water as a reflective surface are good), will install in the tank tomorrow morning, fingers crossed.
                                    • S Sundeep Goel
                                      Sundeep Goel
                                      Installed under a tank nipple (needed to attach to lower end, was getting issues at the end)
                                      getting steady readings now
                                      in brief, too many issues with the JSN SR04T sensor in my tank, Laser TOF Sensor VL53L0X is better and cheaper in given setup.
                                      • S Sundeep Goel
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @sundeep-goel Glad you found a solution, hopefully it will continue to prove reliable over time in your environment, presumably dust is not a problem from the presence of water, nor condensation through ventilation (loose lid)
                                        Out of curiosity, what the range is that version, I've seen 1m and 2m quoted for the same model number..?
                                          Sundeep Goel
                                          I have tested till around 2meters succesfully. I read somewhere that you can also switch to another mode to increase range, haven't tried that though.
                                          Let me know if you need more information, as of now I have added only one sensor, will be adding one more next week, so can run more tests then
                                          Papari DasP 1 Reply Last reply
