  3. Weather Station with Scene Activator!!!
51 Posts 3 Posters 35.5k Views 3 Watching
  • korttomaK
    korttomaK
    korttoma
    Did not try it but how about this:
            if (message.sensor==CHILD_ID_SCENE){
                if (message.type == V_VAR1){
                    OutdoorTemp = atoi(message.data);
                    DEBUG_PRINTLN(F("OutdoorTemp recieved:"));
                    DEBUG_PRINTLN(OutdoorTemp);
               if (message.type == V_VAR2){
                   OutdoorHumidity = atoi(message.data);
                   DEBUG_PRINT(F("OutdoorHumidity recieved:"));
                   DEBUG_PRINTLN(OutdoorHumidity);
              if (message.type == V_VAR3)
                  etc...
            if (message.sensor==CHILD_ID_LED){
                    DayMessage = atoi(message.data);
                    DEBUG_PRINTLN(DayMessage);
                   AlarmStatus = atoi(message.data);
                   DEBUG_PRINT(F("House is:"));
                   DEBUG_PRINTLN(AlarmStatus);
                 etc...
    • Tomas
    • korttomaK korttoma
                    etc...
                   etc...
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @korttoma
      thanks, I'll give it a shot.
      another method for dispatching messages (with delays in between) from Vera with this type of lua function:
      (thanks to @RexBeckett for the assistance)
      function SendWeatherData(strstep)
      	local step = tonumber(strstep)
      	if step == 1 then
      		local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 60)
      		luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_1", value=temp}, 85)
      	elseif step == 2 then
      		local humid = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel", 63)
      		luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_2", value=humid}, 85)
      	elseif step == 3 then
      		local low = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 61)
      		luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_3", value=low}, 85)
      	elseif step == 4 then
      		local high = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 62)
      		luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_4", value=high}, 85)
      	elseif step == 5 then
      		local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Condition", 59)
      		luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_5", value=conditions}, 85)
      	end
      	step = step + 1
      	if step <= 5 then
      		luup.call_delay(1,tostring(step))
      	end
      end
      SendWeatherData("1")
      • korttomaK
        korttomaK
        korttoma
        wow, don't understand what that lua function does but I'll give it a try. Thanks @RexBeckett
        • Tomas
        BulldogLowellB 3 Replies Last reply
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @korttoma
          "The following code calls the function SendWeatherData immediately and the function calls itself with a one second delay. Each time the function runs, it uses a step counter to chose a value to be read and sent. The step gets incremented on each run until it exceeds five after which the function stops calling itself." - rex
          This way, it shouldn't affect vera's watchdog.
          Rex is really helpful on matters of lua ;)
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @korttoma
            I was thinking that perhaps it may be easier/better to recycle V_VAR1 and transmit messages to the node with a leading char. then have the arduino sort out the message based on the header:
            for example:
            conditions = "#" .. conditions
            then sort and strip out the char arduino-side... you could move a lot more message types through one variable
            new message types need to be hard coded into Arduino and Vera, so if we want to expand the data flow... it becomes easier this way, no? Perhaps there is a better message type to use for this type of effort...
            This device is in our guest house and since I have it open I want to add capabilities like:
            1: Message of the day
            2: quick SMS type of message
            3: alarm clock settable by mobile app
            4: twitter feed
            stuff like that...
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              #28
              @korttoma
              Tomas, I just wanted to say thanks for the help. My (almost 100% completed) code is here and a couple of videos showing how it works:
              first
              link text
              #define STATES 7
              #define DEBUG
              #ifdef DEBUG
              #include <avr/pgmspace.h>
              #include <Time.h>
              #define RADIO_ID 11
              #define CHILD_ID_SCENE 3
              #define CHILD_ID_LED 4
              LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
              void (*lcdDisplay[STATES])();
              byte state = 0;
              byte lastState;
              byte timeCounter = 0;
              unsigned long lastTime;
              unsigned long refreshInterval = 3000UL;
              unsigned long lastClockSet;
              boolean isMessage = false;
              float insideTemperature;
              float humidity;
              int OutdoorTemp = -99;
              int OutdoorHumidity = -99;
              int todayHigh = -99;
              int todayLow = -99;
              String conditions = "Not yet Reported";
              String tomorrowWeather = "Not yet Reported";
              String messageOfTheDay = "**Hello There!**";
              unsigned long motdTimer;
              int ledStatus;// to toggle LCD backlight led
              boolean buttonPushed = false;
              DHT dht;
              MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
              MyMessage msgOff(CHILD_ID_SCENE, V_SCENE_OFF);
              MyMessage msgVAR1(CHILD_ID_SCENE, V_VAR1);// outdoor temperature
              MyMessage msgVAR2(CHILD_ID_SCENE, V_VAR2);// outdoor humidity
              MyMessage msgVAR3(CHILD_ID_SCENE, V_VAR3);//today's low
              MyMessage msgVAR4(CHILD_ID_SCENE, V_VAR4);// today's high
              MyMessage msgVAR5(CHILD_ID_SCENE, V_VAR5);//conditions
              MyMessage lightMsg(CHILD_ID_LED, V_LIGHT);
              MyMessage msgMOTD(CHILD_ID_LED, V_VAR1); // message of the day
              MyMessage msgAlarm(CHILD_ID_LED, V_VAR2); // alarm status
              MyMessage msgBrite(CHILD_ID_LED, V_VAR3); // led briteness (nice idea!!!!)
                DEBUG_SERIAL(115200);
                DEBUG_PRINTLN(F("Serial started"));
                attachInterrupt(1, PushButton, CHANGE);
                lcdDisplay[0] = lcdDisplay0;
                lcdDisplay[1] = lcdDisplay1;
                lcdDisplay[2] = lcdDisplay2;
                lcdDisplay[3] = lcdDisplay3;
                lcdDisplay[4] = lcdDisplay4;
                lcdDisplay[5] = lcdDisplay5;
                lcdDisplay[6] = lcdDisplay6;
                gw.begin(getVariables, RADIO_ID);
                gw.sendSketchInfo("WeatherClock", "1.0");
                gw.present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                gw.present( CHILD_ID_LED, S_LIGHT);
                lcd.init();
                lcd.clear();
                lcd.backlight();
                lcd.setCursor(0, 0);
                lcd.print("Syncing Time");
                lcd.setCursor(0, 1);
                int clockCounter = 0;
                while(timeStatus() == timeNotSet && clockCounter < 60)
                  gw.requestTime(receiveTime);
                  Serial.println("getting Time");
                  delay(1000);
                  lcd.print(".");
                  clockCounter++;
                  if (clockCounter > 16)
                    lcd.clear();
                    lcd.print(F("**Failed Clock**"));
                    lcd.setCursor(0,1);
                    lcd.print(F("*Syncronization*"));
                    delay(2000);
                lcd.clear();
                lastTime = millis();
                if (millis() - lastClockSet >= 60000UL)
                  lastClockSet = millis();
                if (millis() - lastTime >= refreshInterval)
                  state++;
                  if (state > STATES - 1) state = 0;
                  DEBUG_PRINTLN(F("State:"));
                  DEBUG_PRINTLN(state);
                  lastTime += refreshInterval;
                  getTempHumidity();
                if (state != lastState)
                  fastClear();
                  lcdDisplay[state]();
                lastState = state;
                if (buttonPushed)
                  activateScene();
                if (isMessage)
                  if (millis() - motdTimer > 86400 * 1000UL)
                    isMessage = false;
              void fastClear()
                lcd.setCursor(0,0);
                lcd.print("                ");
                lcd.setCursor(0,1);
                lcd.print("                ");
              void lcdDisplay0()
                lcd.setCursor(0,0);
                lcd.print(F("Time: "));
                if (hourFormat12() < 10) lcd.print("0");
                lcd.print(hourFormat12());
                lcd.print(":");
                if (minute() < 10) lcd.print("0");
                lcd.print(minute());
                if (isAM()) lcd.print(F("am"));
                else lcd.print(F("pm"));
                DEBUG_PRINT(F("Time:"));
                DEBUG_PRINTLN(hourFormat12());
                lcd.setCursor(0,1);
                lcd.print(F("Date: "));
                if (month() < 10) lcd.print("0");
                lcd.print(month());
                lcd.print("/");
                if (day() < 10) lcd.print("0");
                lcd.print(day());
                lcd.print("/");
                lcd.print(year());
                DEBUG_PRINTLN(F("Date: "));
                DEBUG_PRINT(month());
                DEBUG_PRINT("/");
                DEBUG_PRINT(day());
                DEBUG_PRINT("/");
                DEBUG_PRINTLN(year());
              void lcdDisplay1()
                lcd.setCursor(0,0);
                lcd.print(F(" Indoor Temp:"));
                lcd.print(int(round(insideTemperature)));
                lcd.print(char(223));
                DEBUG_PRINT(F("Indoor Temp:"));
                DEBUG_PRINT(int(round(insideTemperature)));
                DEBUG_PRINTLN(F("F"));
                lcd.setCursor(0,1);
                lcd.print("    Humidity:");
                lcd.print(int(round(humidity)));
                lcd.print(F("%"));
                DEBUG_PRINT("   Humidity:");
                DEBUG_PRINT(int(round(humidity)));
              void lcdDisplay2()
                lcd.setCursor(0,0);
                lcd.print("Outdoor Temp:");
                lcd.print(OutdoorTemp);
                DEBUG_PRINT(F("Outdoor Temp:"));
                lcd.setCursor(0,1);
                lcd.print(F("    Humidity:"));
                lcd.print(OutdoorHumidity);
                lcd.print(F("%"));
                DEBUG_PRINT(F("    Humidity:"));
              void lcdDisplay3()
                lcd.setCursor(0,0);
                lcd.print(F("Today's High:"));
                lcd.print(todayHigh);
                DEBUG_PRINT(F("Today's High: "));
                DEBUG_PRINTLN(todayHigh);
                lcd.setCursor(0,1);
                lcd.print(F("         Low:"));
                lcd.print(todayLow);
                DEBUG_PRINT(F("Today's Low: "));
                DEBUG_PRINTLN(todayLow);
              void lcdDisplay4()
                lcd.setCursor(0,0);
                lcd.print(F("Today's Weather"));
                DEBUG_PRINTLN(F("Today's Weather: "));
                lcd.setCursor(0,1);
                lcd.print(conditions);
                DEBUG_PRINTLN(conditions);
              void lcdDisplay5()
                lcd.setCursor(0,0);
                lcd.print(F("Forcast Tomorrow"));
                DEBUG_PRINTLN(F("Tomorrow's Forecast: "));
                lcd.setCursor(0,1);
                lcd.print(tomorrowWeather);
                DEBUG_PRINTLN(tomorrowWeather);
              void lcdDisplay6()
                if (isMessage)
                  lcd.setCursor(0,0);
                  lcd.print(F("**NEW  MESSAGE**"));
                  DEBUG_PRINTLN(F("****Message****"));
                  lcd.setCursor(0,1);
                  lcd.print(messageOfTheDay);
                  DEBUG_PRINTLN(messageOfTheDay);
                  motdTimer = millis();
                  lcd.setCursor(0,0);
                  lcd.print(F("****Welcome!****"));
                  lcd.setCursor(0,1);
                  lcd.print(F("Have a Nice Day!"));
                  DEBUG_PRINTLN(F("Have a Nice Day"));
              void getTempHumidity()
                insideTemperature = dht.toFahrenheit(dht.getTemperature());
                if (isnan(insideTemperature))
                  DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                humidity = dht.getHumidity();
                if (isnan(humidity))
                  DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                DEBUG_PRINTLN(F("Time value received: "));
                DEBUG_PRINTLN(time);
                setTime(time);
              void PushButton()
                  buttonPushed = true;
              void activateScene()
                DEBUG_PRINTLN(F("ButtonPushed"));
                fastClear();
                for (byte i = 0; i < 10; i++)
                  lcd.noBacklight();
                  delay(50);
                  lcd.backlight();
                  delay(50);
                lcd.setCursor(0,0);
                lcd.print(F(" A/C Boost Mode "));
                lcd.setCursor(0,1);
                lcd.print(F("**** ACTIVE ****"));
                delay(2000);
                lastTime = millis(); //Reset the timer to even out display interval
                ledStatus = gw.loadState(CHILD_ID_LED);
                if (ledStatus > 0)
                  lcd.backlight();
                  lcd.noBacklight();
                if (message.sensor == CHILD_ID_SCENE)
                    todayLow = atoi(message.data);
                    DEBUG_PRINT(F("Received Today's LOW:"));
                  if (message.type == V_VAR4)
                    todayHigh = atoi(message.data);
                    DEBUG_PRINT(F("Received Today's HIGH:"));
                  if (message.type == V_VAR5)
                    int locator = newMessage.indexOf("@");
                    newMessage = newMessage.substring(0, locator);
                    conditions = newMessage;
                    DEBUG_PRINT(F("Received today's Conditions:"));
                if (message.sensor == CHILD_ID_LED)
                  if (message.type == V_LIGHT)
                    int ledState = atoi(message.data);
                    if (ledState > 0)
                      lcd.backlight();
                      lcd.noBacklight();
                    // Extended Forecast
                    tomorrowWeather = newMessage;
                    DEBUG_PRINT(F("Received Two Day Forecast:"));
                    messageOfTheDay = newMessage;
                    DEBUG_PRINT(F("Received Message of the Day:"));
                    isMessage = true;
              fixed it
              • korttomaK
                korttomaK
                korttoma
                4 spaces in front of every line will be displayed as code. Please update your post. And I could not play the videos either.
                • Tomas
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  #30
                  @korttoma
                  all fixed. I had to take the text into another editor
                  here is the lua
                   luup.sleep(750)
                   luup.sleep(750)
                   luup.sleep(750)
                   luup.sleep(750)
                   luup.sleep(750)
                   local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Forecast.1.Condition", 59)
                   luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_2", value=conditions}, 85)
                   luup.sleep(750)
                  • korttomaK
                    korttomaK
                    korttoma
                    Nice job on the sketch Jim, I especially liked the idea with "#define DEBUG". There were allso some other ideas I will be stealing some day when I find time to update my sketch.
                    So I guess you did not use the function by @RexBeckett then? I could not get it to work either. I'll try your suggestion with the delays.
                    • Tomas
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @korttoma
                      Thanks for your help and time, you made it a lot easier! I'm trying to write the code for an audience rather than myself so I'm focused more on what I'm putting into the sketch versus just 'getting it to work.' I'm going to get that led dimming next!
                      I messed around with the function but lost patience with it,,. I'll get my lua book out and tackle that one rainy day. Meanwhile, I have been using these delays without any issues (no Vera re-starts) and can probably work on shortening the delay times now that I have my Ethernet gateway working so well!!!
                      best network performance ever for me since I started with MySensors :)
                      I keep looking at your scene controller (and the one Henrik did) and I guess I just have to pick one to make!!
                      • korttomaK
                        korttomaK
                        korttoma
                        It was all my pleasure Jim, it is nice to have someone to exchange ideas with. I take it you mean the dimming of the backlight right? Let me know if you need some details.
                        I have also put together a Ethernet GW some time ago but newer got around to take it in to use. And then there was all this about the SPI issue so I guess I need to take it on again at some point. A bit unclear if it will work with the Ethernet board I have anyway.
                        • Tomas
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @korttoma
                          yeah, I meant dimming the LED backlight, a nice touch to your project.
                          your ethernet board uses the same Wiznet chipset, so you may want to try what was posted on the other thread. I got frustrated with my Serial gateway losing its communication with Vera.
                          • C
                            C
                            cleight
                            Hello, I am building this same thing and have used the sketch and luup code above thanks to @BulldogLowell & @korttoma!
                            I am having issues though pulling a variable to send to the lcd screen via luup. I put this device under the Light Variable 4 code is at the bottom of the Lua below. This device is another mysensor that is visible in Vera so I am not sure what is wrong, any help someone could provide would be great.
                            Luup code:
                            local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 7)
                            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_1", value=temp}, 103)
                            luup.sleep(750)
                            local humid = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel", 10)
                            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_2", value=humid}, 103)
                            luup.sleep(750)
                                luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_3", value=low}, 103)
                             luup.sleep(750)
                            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_4", value=high}, 103)
                            luup.sleep(750)
                            local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Condition", 6)
                            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_5", value=conditions}, 103)
                            luup.sleep(750)
                            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_2", value=conditions}, 103)
                             luup.sleep(750)
                              local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
                             luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 103)
                              luup.sleep(750)
                            Sketch: weather_station.ino
                            • BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              luup.sleep(750)
                              it looks like you are making a call for the variable "conditions" and passing "HTTemp" in the two last commands. here:
                              local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98) -- you get "conditions"
                              luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 103) -- you set "HTTemp"
                              luup.sleep(750)
                              that could be it...
                              C 1 Reply Last reply
                                luup.sleep(750)
                                luup.sleep(750)
                                that could be it...
                                C
                                C
                                cleight
                                @BulldogLowell I was under the impression that the value could be named what ever you want, is that not the case? changing the value to temp should fix the issue you think?
                                • C cleight
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  #38
                                  now I am confused.
                                  You are (it seems to me) retreiving a value from device 98, no?
                                  You are then writing that to device 103, at VAR_4... yes?
                                  please clarify for me.
                                  (reference the snippet of code in my last post)
                                    now I am confused.
                                    C
                                    C
                                    cleight
                                    @BulldogLowell Thanks for pointing that out, I actually need to write VAR4 to device 105. I have made the necessary changes but still isn't working.
                                     local temp = luup.variable_get("urn:upnp-   org:serviceId:TemperatureSensor1","CurrentTemperature", 7)
                                    luup.sleep(750)
                                     luup.sleep(750)
                                     local low = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 8)
                                     luup.sleep(750)
                                     local high = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 9)
                                     luup.sleep(750)
                                     luup.sleep(750)
                                     local conditions = luup.variable_get("urn:upnp-micasaverde-com:serviceId:Weather1","Forecast.1.Condition", 6)
                                     luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_2", value=conditions}, 105)
                                      luup.sleep(750)
                                      local temp = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
                                      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;4", variableId="VAR_4", value=HTTemp}, 105)
                                      luup.sleep(750)
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      You are stil not giving HTtemp any value!
                                      • Tomas
                                        C
                                        C
                                        cleight
                                        wrote on last edited by cleight
                                        #41
                                        @korttoma Can you elaborate on HTTemp not getting any value? I am not following what HTTemp should be either changed to or how to give it value.
                                        Here is a snippet of the debug window:
                                        Indoor Temp:20F
                                        Hot Tub:0Fsend: 11-11-0-0 s=255,c=3,t=1,pt=0,l=0,st=ok:
                                        read: 0-0-11 s=255,c=3,t=1,pt=0,l=10:1423665003
                                        1423665003
                                        • korttomaK
                                          korttomaK
                                          korttoma
                                          Try replacing the last section with this:
                                          local HTTemp = luup.variable_get("urn:upnp-micasaverde-com:serviceId:TemperatureSensor1","CurrentTemperature", 98)
                                          luup.sleep(750)
                                          • Tomas
