  3. Using Sensebender gateway MYSX_D3_INT Interrupts
14 Posts 4 Posters 2.0k Views 3 Watching
  • tbowmoT tbowmo
    @didou
    I sort of decided that a GW never has to sleep, as it is usually connected to a good powersource (usb, wallplug etc), so we do not need to conserve power by going into sleep..
    Didou
    @tbowmo I have seen that no issue but it still should be able to catch interrupt when in wait state ?
    • D Didou
      @didou could you clarify what you mean by "wait state"?
      • scalzS scalz
        • if you're planning to use it as a gateway, then don't use sleep function else it will miss messages..it won't wake up on receive like you said.
        • as you noticed sleep is not implemented for SAMD mcus, like sensebendergw
        • mapping of SAMD does not work like well known avr8 328p for example. Did you use digitalPinToInterrupt ?
          https://www.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/
          like attachInterrupt(digitalPinToInterrupt(3), myisr, CHANGE ) for your "D3.
        Didou
        @scalz Yes I did try even with something different as CHANGE like FALLING
        But seems I was tracking the debug message :white_frowning_face: which it is never displayed in that case !
        But the Serial message is sent (0;255;3;0;5;1)
        It is working only one time after a GW reset, further test do not fire up the interruption
        loop()
        attachInterrupt(digitalPinToInterrupt(MYSX_D4_INT), myInterrupt , FALLING);
        wait(60*1000); // Wait one minute between each probe (60 * 1000)
        void myInterrupt()
        detachInterrupt(digitalPinToInterrupt(MYSX_D4_INT));
        #ifdef MY_DEBUG
        Serial.println("Motion Interrupt");
        send(MotionMsg.set("1"));
        D 1 Reply Last reply
        • D Didou
          loop()
          void myInterrupt()
          #ifdef MY_DEBUG
          Didou
          @didou I have also noticed thta I have to wait for a (0;255;3;0;5;0) reset message to be able to capture a new interrupt. I do not send it I guess it is sent by the core ?
          • D Didou
            Didou
            @didou It is reset after 2 minutes then I can send a new interrupt. Where does come from the 120 sec hold time ?
              seems arduino learning related ;)
              you mentioned sleep in your first post, and I think wait might delay your irq processing too
              • is it your full loop() function ? if so, why do you place attachinterrupt inside of it? looks weird, it would be better in setup for instance
              • "ok" for debug but serial.print in isr is bad.. ideally, it's better to trigger a boolean (volatile) and process its value in loop() . Same for sending msg from isr, not good..
              • are you saying that you get one interrupt at least? which would mean the attachinterrupt(digitalpintointerrupt...) mapping is working, and your sketch logic is wrong (like above mentioned points)
              just in case, in theory (no time for testing), D3=PA05(gpio name under the hood)=IRQNUM is 5 so you could replace the digitalTointerrupt function by the irq mapping name; 5 for D3, or 7 for D4.
              so just as an example, revamping your example, the logic should look something like this
              volatile bool myIsrTriggerVar = false
              setup() {
              	attachInterrupt(digitalPinToInterrupt(MYSX_D4_INT), myInterrupt , FALLING); // means attachInterrupt(7, myInterrupt , FALLING);
              loop() {
              	if (myIsrTriggerVar) {
              		// process your irq here
              		#ifdef MY_DEBUG
              		// reset flag
              	// wait(60*1000); // Wait one minute between each probe (60 * 1000)
              void myInterrupt()
              	myIsrTriggerVar = true
              • scalzS scalz
                setup() {
                loop() {
                		#ifdef MY_DEBUG
                		// reset flag
                void myInterrupt()
                Didou
                @scalz Great help yes I get one at least but need to wait 120 sec to get an other one ?
                Agree for the attachInterrupt in setup
                My loop does also have few sensors read every minutes so I need to both wait for one minute and also been able to catch interrupts
                scalzS 1 Reply Last reply
                • D Didou
                  @didou
                  then check your sensors in an async way, far better than using wait.
                  there are different way of writing this, but here an example, maybe easier to read when new to programming : https://www.arduino.cc/en/tutorial/BlinkWithoutDelay
                  In this example, instead of toggling leds, process your sensors.
                  Also, maybe start simple, like a sketch processing your sensors as you wish, then once it's working well, add MySensors lib
                  • scalzS scalz
                    @didou
                    Didou
                    @scalz will try that as proposed ovoiding wait and let you know. Thanks again.
                    • D Didou
                      Didou
                      @didou Tryed it today with no luck.
                      The behavior is globally simillar
                      loop()
                      // Check Sensors global timer
                      if (currentMillis - previousMillis >= intervalMillis)
                      readSensors();
                      // Check Triggers
                      if (myIsrTriggerVar1)
                      #ifdef MY_DEBUG
                      // reset flag
                      myIsrTriggerVar1 = false;
                      I got the interrupt then mysensor message -> 13:13:07.719 -> 0;255;3;0;5;1 (Motion/V_trigger -> 1)
                      Then I have to wait for 120 seconds before being able to do an other interrup
                      Not before I have this message 13:15:07.621 -> 0;255;3;0;5;0 (Motion/V_trigger -> 0) which is not in my own code
                      How often i do read the sensors do ot have any impact within the 120 seconds or outside of them.
                      I have roufly checked the mysensor code and haven't seen any such define behavior for Motion/V_trigger)
