  3. OpenHAB
  4. Connect humidity sensor to OpenHAB
openhab mqtthumidityconnectingopenhabsensor
4 Posts 2 Posters 4.3k Views 2 Watching
  • vladimirV
    vladimirV
    vladimir
    Hello!
    Please help to deal with the humidity sensor (http://www.mysensors.org/build/humidity) connection to OpenHAB through MQTT gateway (http://www.mysensors.org/build/mqtt_gateway). I just started to deal with OpenHAB and MySensors. Unfortunately, I do small experience to do everything on their own, and there is no documentation in my language.
    XanderX 1 Reply Last reply
    • vladimirV vladimir
      Hello!
      XanderX
      XanderX
      Xander
      @vladimir I had the same problem. Very helpful for me is the MQTT-client MQTT.fx. It shows you the messages from your gateway.
      See my post: http://forum.mysensors.org/topic/953/how-to-know-the-node-ids-assigned-by-the-mqtt-gateway-to-the-sensors
      vladimirV 1 Reply Last reply
      • XanderX Xander
        vladimirV
        vladimirV
        vladimir
        @Xander, thank you for your answer! As it turned out, I have a problem in the gateway. I use a network module ENC28J60, and full of reason to it do not reach the packets, it is not visible on the network. I connect it directly to a computer. Maybe you and repel such a problem?
          XanderX
          XanderX
          Xander
          @vladimir No, I use a WIZ5100 module. Search the forum. Many users (try) :-)) to use ENC28J60.
