  3. Mysensor usb gateway serial problem
7 Posts 4 Posters 1.0k Views 3 Watching
  • D Offline
    dany17
    Hello, could somebody help me and say why it doesn't work?
    //#define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define CHILD_ID 3
    #define BUTTON_PIN  3
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
      for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
    int gate = 23;
    int relay1 =  22;
      Serial.begin (115200);
        pinMode(BUTTON_PIN,INPUT);
        pinMode(relay1, OUTPUT);
        digitalWrite (relay1, LOW);
        pinMode(gate, OUTPUT);
        digitalWrite (gate, LOW);
        pinMode(24, INPUT_PULLUP);
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_BINARY);
       byte value = analogRead(0);
     if (value == LOW){
      delay(10);
      digitalWrite(gate, LOW);
     digitalWrite(relay1, LOW);
     delay(2000);
     digitalWrite(gate, HIGH);
      if (value == HIGH){
      delay(10);
     digitalWrite(relay1, HIGH);
      delay(2000);
      if (message.type==V_STATUS) {
        // Change relay state
        digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
    mfalkviddM K 2 Replies Last reply
    • D dany17
      #define CHILD_ID 3
      void before()
      int gate = 23;
      int relay1 =  22;
       if (value == LOW){
        delay(10);
       delay(2000);
        if (value == HIGH){
        delay(10);
        delay(2000);
      Welcome to the MySensors community @dany17
      Would you mind sharing what you mean by "it" and "doesn't work"?
      If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to troubleshoot them efficiently.
      • S Offline
        @dany17
        Hi.
        My crystal ball :) told me you need to uncomment this line in your sketch if you're planning to use nrf24 :
        to
        If it doesn't help, like mfalkvidd said please show us your debug logs.
        • D Offline
          dany17
          @scalz said in Mysensor usb gateway serial problem:
          OK i do //#define MY_RADIO_RF24 because for now I wanted to make a base station via usb
          I will tell you my idea and you will tell if it is possible here because I am slowly losing faith XD
          I want to use mega2560 to control several devices. One of them is the roller blind that I converted into electric motor control (currently I have two. The first classic 2 wires and I have connected to 3 contactors which control the direction and time of operation. The second stepper motor).
          I now want to use my sensor to control the blind in domoticz with 1 switch or if it could be slider.
          The next thing would be INA219 but maybe later for the time being on this roller blind, is it possible to do?
          • D Offline
            dany17
            wrote on last edited by dany17
            I would like to use this program in mysensors with a switch from domoticz
            #include <Stepper.h>
            #define STEPS 32
            Stepper stepper (STEPS, 8, 10, 9, 11);
            int val = 0;
            void setup () {
              Serial.begin (9600);
             stepper.setSpeed (800);
              pinMode(4, INPUT_PULLUP);
            void loop () {
              if (digitalRead (4) == LOW)
                val = 20480;
                stepper.step (val);
                Serial.println (val);
             if (digitalRead (4) == HIGH)
                val = -20480;
                stepper.step (val);
            • D dany17
              #define CHILD_ID 3
              void before()
              int gate = 23;
              int relay1 =  22;
               if (value == LOW){
                delay(10);
               delay(2000);
                if (value == HIGH){
                delay(10);
                delay(2000);
              K Offline
              K Offline
              kimot
              @dany17
              If you want to use arduino connected via usb to computer and your sensors connected to that arduino with MySensors, I recommend starting with sketch "GatewaySerialRS485" from MySensors examples and present your sensors in this sketch.
              But honestly, I don't think you have enough experience for this task yet.
              For example:
               if (value == LOW){
                delay(10);
               delay(2000);
                if (value == HIGH){
                delay(10);
                delay(2000);
              You compare analog readed value if it matches the exact value?
              In how many cases does this occur?
              And you know the value of the definition values LOW and HIGH in Arduino?
              D 1 Reply Last reply
              • K kimot
                @dany17
                For example:
                 if (value == LOW){
                  delay(10);
                 delay(2000);
                  if (value == HIGH){
                  delay(10);
                  delay(2000);
                dany17
                @kimot
                yes I know this is an error but I wanted to read the value from pin 4. this example worked for me (RelayActuator) I wanted to use this ordinary switch to control the rest of the program. that's all I need at the moment
